Bike fork mount for bed rail system. Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mjordan, Apr 12, 2015.
  1. Apr 12, 2015 at 11:04 PM
    Mjordan
    Mjordan [OP] Well-Known Member
    Michael
    Denver, Colorado
    2015 Super White DCSB 4WD TRD Offroad
    TRD Beadlock Wheels, Bilstein 5100s all around, BFG K02 265/75R16, 20% tint, WeatherTech Floormats, LED Interior Lights, Tailgate lock, Salex Organizers, Shorty 5" Antenna, LED license plate lights
    I'm in need of a bike fork mount for my truck bed so that I don't have to keep tossing mine and my mates mountain bikes in the bed to get all tangled up. No way i'm paying premium for such a simple system. The OEM one from Toyota is $100, and the rocky mount one pictured below would be $150 for two!!
    My question is, what can I use for the little metal tabs that attach to the rail? Assuming I buy a fork mount from Amazon for $15 then use whatever I figure out for the metal tabs, that's much cheaper than the alternatives. See pictures below for visualization of what I want...
  2. Apr 12, 2015 at 11:11 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Attach it to the bed rail. It's way easier.
  3. Apr 12, 2015 at 11:16 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Drill the rail from top down and bolt it down. I remove the axle tab when not in use, so it doesn't rattle.
  4. Apr 12, 2015 at 11:54 PM
    Mjordan
    Michael
    Denver, Colorado
    Sorry maybe I wasn't clear, but yes that's exactly what I want to do. Buy a fork mount and attach it to the track system. Basically how the OEM cleats are attached. Except I would use hex bolts or something similar. I just don't know what/where to get something like that to fit in the tracks...
    What I'm asking is if I buy the fork mount pictured in my first post, do you have any ideas on what I can use to attach it to the tracking system?
    @MeefZah I would prefer not to have to make any physical changes like drilling since it's not necessary. Just trying to figure out what/where I can buy some attachments for the track system so I don't have to pay $100+ for two simple fork mounts.
  5. Apr 13, 2015 at 6:03 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Carriage bolts with the round heads ground down on the sides should work. Look at the cheap DIY thread to see how some guys used them to mount ammo cans to the rails. You would be doing the same, but mounting the fork mounts instead. Before you ask, no, I don't have a link... it's a big thread and the idea is buried in it somewhere..... :)
  6. Apr 13, 2015 at 6:11 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    I used to have my mounts attached to the bed rail. I just used some washers and bolts, it wasn't pretty but it worked. Once I got my topper I had to bolt the mounts to a 2X6. You may want to consider this option. It's nice because you can just remove the board when you aren't using it.
  7. Apr 13, 2015 at 6:24 AM
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    There are some very informative threads on here about the different options. I suggest searching "bed rail attachments" or something along those lines.
    Personally, because I couldn't find anything ideal at the hardware store and didn't have time to order online, I bought huge round washers and used tin snips to cut two sides off. I then used loctite to align a nut on the back. I then slid it in the channel on the rail and was ready to go...just bolted the fork mount right on.
  8. Apr 13, 2015 at 8:11 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  9. Apr 13, 2015 at 8:14 AM
    Mjordan
    Michael
    Denver, Colorado
    Thank you that's exactly the kind of info I was looking for!
    I've thought about that as an alternative, but I'm in college living in a small apartment. Storing the board when not in use would be a problem, whereas I can just throw the bed rail mounts in the behind-the-seat storage when not in use.
    Perfect! I'll do some searching under "bed rail attachments" on here. And the washer/loctite thing is a great idea so I can screw it on from the outside versus the carriage bolt idea above.
    Thanks so much guys! Just needed a couple ideas to get the brain juices flowing.
  10. Apr 13, 2015 at 8:17 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    This is exactly what I do, so nice to just drop it in when you need it! and you can put in the front of the bed or the depending on what else you've got going on back there.
  11. Apr 13, 2015 at 8:19 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    FYI. Amazon does not have the best prices.
  12. Apr 13, 2015 at 8:32 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    It's already been addressed, but I used small carriage bolts with washers from a hardware store. Slid them into the rail and bolted the fork mounts using nylock nuts. I have t had any issues with them moving around or rattling. I think it cost me around $25 (including the fork mounts).
  13. Apr 13, 2015 at 8:38 AM
    TacOoLa
    TacOoLa Well-Known Member
    Jp
    Quebec
    Toytec 3'' lift kit/add leaf bilstein5100
    this kind of rack exist for a lefty fork?
  14. Apr 13, 2015 at 8:42 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    I'm totally doing this :)
  15. Apr 13, 2015 at 9:03 AM
    scottfarm
    scottfarm Well-Known Member
    Florida
    tacoma 4X4
    aires 3D mats, scan gauge II, rear differential breather relocation, and bakflip G2 bed cover.
  16. Apr 13, 2015 at 9:10 AM
    The109
    Fort Collins
    A couple of tips:
    Cut the board so that it fits snugly, then it won't wiggle around.
    If mounting two bikes, stagger the mount locations so that your bar ends don't hit each other.
    Enjoy.
  17. Apr 13, 2015 at 10:08 AM
    sixtytooze
    sixtytooze Well-Known Member
    I bought 2 mounts from a bike shop for $19.99 each. I cut and tapped metal slugs to fit rail system. These mounts do not lock however a typical bike lock through a d-ring would solve that problem.
  18. Apr 13, 2015 at 10:35 AM
    SprtBkr
    SprtBkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 5.7L Double Cab 4x4 Inferno
  19. Apr 13, 2015 at 10:39 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Spring bolts for Unistrut.
  20. Apr 14, 2015 at 6:23 PM
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
