Billie 5100 and tire sizes
Discussion in 'Suspension' started by BajaFishTaco, Feb 7, 2012.
  1. Feb 7, 2012 at 10:03 PM
    BajaFishTaco
    BajaFishTaco [OP] Member
    Ok, I've read everything I can find about the 5100s which are sitting in a box in my garage. I'd like to know what the biggest tire I can run if they are set at .85, 1.75, or 2.5. I have a 06 dc trd 4x4 with a shell on the bed and I want to go with bigger bfg a/t but I hate rubbing and I do spend time off road. I could run spacers if necessary but I'm not clear on if that allows for a bigger tire. Any help is greatly appreciated.
  2. Feb 7, 2012 at 10:05 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    265/75/16 set at .85 or 1.75"
    2.5" you can run a 285/75/16 with some trimming
  3. Feb 7, 2012 at 10:22 PM
    ColtsTRD
    Scott
    AZ
    oh and if you wanna run 285s then you will need wheel spacers of at least 1.25". Spidertrax is preferred around here. You won't need spacers if you have after market wheels with 4-4.5" Backspacing. Reason being is that you'll rub on your uca with stock wheels. Trimming in the wheel wells is necessary and your cab mount will need to be chopped in some cases cause they'll rub at full lock in some cases...that's with 285s mind you.
  4. Feb 8, 2012 at 8:55 PM
    BajaFishTaco
    Thanks for the good info! I should have mentioned its the trd sport with17s. I just read a thread that says to go 265/70 r17. So to help me clarify, at .85 or 1.75 I don't get any tire size advantage over no lift? Why do people prefer these settings then? It seems like all you get is less down travel. Thanks again for helping. I also don't mind doing some trimming inside the fender but I don't know what the cab mount is. Sorry, noob question I'm sure.
  5. Feb 8, 2012 at 9:00 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    They prefer those settings because they level the truck .85 at stock in the rear and 1.75 with the TSB 4 leaf pack.
  6. Feb 9, 2012 at 7:54 AM
    BajaFishTaco
    Gotcha, thanks. Will I be able to run 285/75r17 at 2.5? Not sure if wheel size will make a difference.
  7. Feb 9, 2012 at 9:19 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    You'll probably still have to do some trimming. Keep in mind, you'll be nose high at 2.5" without doing anything to the rear. Don't know what your full plans are.
  8. Feb 9, 2012 at 5:25 PM
    Fightnfire
    Marysville, WA
    On a stock wheel you'll have a lot of trimming/chopping to do. If you get a wheel with good backspacing you'll still need trimming just not as much. And yea, as above said, at 2.5" you'll be nose high.
  9. Feb 9, 2012 at 5:39 PM
    Tbones taco
    Tbones taco Well-Known Member
    Tony
    Carrollton
    07 PreRunner ext cab
    Flowmaster 40 smittybuilt bull bar smittybuilt nerf bars hella lights crome custome grill
    I just picked my Billys up. I'm running a 16x8 wheel with 255 70 16 A/T. If i set my new billys at .85 with the stock springs will i get the front level?? My truck is a 2wd prerunner v6 acc cab. Also i'm not adding a leaf yet so what should i do in the rear?
  10. Feb 9, 2012 at 6:14 PM
    Bryan139
    NJ
    '09 Sport
    Yes, you'll be level at .85". You don't have to do anything to the rear. When you do add a leaf you'll have to go up to 1.75 to stay level or you'll be back to almost factory rake. But for now .85 is level, anything more with nothing in the back will make you nose high.
  11. Feb 9, 2012 at 8:35 PM
    BajaFishTaco
    Can I run 265/75 r17 at no lift ( I.e. retain all my travel) with minor trimming? I like to take my bumps at high speed. :)
  12. Feb 10, 2012 at 6:20 AM
    Bryan139
    NJ
    '09 Sport
    Search "265/75/17" and see what other people's experience has been. I'd like to say yes, that would probably work, but I'd just be going off of what I've read from others. I don't run that size tire so I can't say for sure. Make sure you click the box that says "search titles only" and it'll be easier to find what you're looking for.
  13. Feb 10, 2012 at 8:59 PM
    TheDan
    TheDan Well-Known Member
    Dan
    Shasta Lake, California
    07 Double Cab Short Bed TRD OR
    265/70r17 and 265/75r16 are about the same diameter. I don't think there are many 265/75r17 tires out there (if any).
  14. Feb 10, 2012 at 9:10 PM
    PinkTaco24
    PinkTaco24 Well-Known Member
    NC
    06 prerunner
    5100s all around -- 1.75 fronts, 1.5 aal, spidertraxs, grillcraft mx, derped scoop & badges, AVID step bars....need.more.money.
    i am getting ready to get a set of billies as well. i wanna do 2.5 in the fronts w/ aal rear, but i don't know what height. i want more of a lift and less of a level without going nose high. any suggestions?
  15. Feb 10, 2012 at 9:11 PM
    PinkTaco24
    NC
    06 prerunner
    x2. would go w/ 265/70r17 if keeping stock
  16. Feb 10, 2012 at 9:21 PM
    ColtsTRD
    Scott
    AZ
    this
    265/75/16 = 265/70/17
  17. Mar 1, 2012 at 8:06 AM
    tiger041988
    tiger041988 Active Member
    07 4WD SR5 stock
    I'm going to be putting on my billy 5100s in the front with a 2" AAL in the rear. I'm gonna go with the wheelers offroad 16x8 type B steel wheel so I don't have to run spacers. I want to run duratrac 285s/33"s. From what I'm reading I'll have to do some minor trimming. Am I right? I'm not gonna be doing any offroading with it so I'm not worried about major bumps.
  18. Mar 3, 2012 at 7:41 AM
    tiger041988
    07 4WD SR5 stock
