Billie 5100s, OME 885x, and Spindle lift? Anyone run this.
Discussion in 'Suspension' started by Pluffmud13, Jun 22, 2012.
  1. Jun 22, 2012 at 6:03 PM
    Pluffmud13
    Pluffmud13 [OP] Well-Known Member
    Charleston
    06 Silver SR5 TRD Off Road
    So I had Bilstein 5100s and OME 885x's installed on my truck a few months back,(got about 2.5" of lift or so) I love the look but want a little more. Is it possible to put a spindle lift (Camburg or Maxtrac) on with my existing set up? Obviously I would bring the rear up too not trying to have the most intensely squatting truck ever.
  2. Jun 22, 2012 at 6:08 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    The spindles will get you 4 inches of lift and you dont need to preload the 5100's either IIRC
  3. Jun 22, 2012 at 6:10 PM
    Pluffmud13
    Charleston
    I forgot to include they are set at 0"
  4. Jun 23, 2012 at 12:02 AM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    to answer your question yes. Are you running stock rims too? if so you will need wheel spacers, 1.25"
  5. Jun 23, 2012 at 12:11 AM
    markmatters
    markmatters Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    i've got 5100's at .85 and eibach 1.6"...plus maxtrac spindles...3.75"....not 885's...but very possible. if you're at 2.5" now...maxtrac will give you 3.75" more...camburg gives you a true 4" supposedly...
  6. Jun 23, 2012 at 12:19 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    that will give ya bout 6.5 inches of lift in the front roughly. what are you using for the back? blocks? all pro expo leafs are real good for the back if you can sacrafice a little in the front....I have billies set at .85 w/stock coils and expos in the back sits almost level and rides great.
  7. Jun 23, 2012 at 12:25 AM
    markmatters
    markmatters Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    i'm at 27.75" front and 26.75" (center of hub to bottom fender) roughly 5.5" front and 4.5" rear...running all pro standard leaf pack and 1" block...rides smooth..inch higher up front just like I wanted...
  8. Jun 23, 2012 at 7:05 AM
    Pluffmud13
    Charleston
    Thanks guys. I wasn't sure exactly what I was going to run in the back to compensate, but now I have a starting place.
    Anyone else running anything different on the rear?
