billies 5100 set to 2.5" alignment specs needed
Discussion in 'Suspension' started by yetiman, Jun 28, 2012.
  1. Jun 28, 2012 at 7:14 AM
    yetiman
    yetiman [OP] Member
    2012 TRD OFF ROAD Tacoma black
    Torklift camper mounts,Firestone Ride-Rite air bags,TRD performance exhaust, Avid offroad light bar,Bilstein 5100 shocks,front: Total chaos UCA 2in lift,rear: 2in Toytech AAL, TRD Trail Team black wheels w/ BF Goodrich All Terrain tires
    Please, anyone has the front alignment specs for bilsteins 5100 set to 2.5" on 12' trd off road Tacoma. Thankx ;)
  2. Jun 28, 2012 at 10:37 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    When you take your truck to a decent shop for alignment, their computer has all the factory specs already. It does not matter if you have Bilsteins or a lift, the specs are the same.
    Search this section and you will see plenty of alignment printout scans that show what the proper numbers are.
  3. Jun 28, 2012 at 10:40 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    zero camber, zero toe & somewhere around 2.4 - 2.8 degrees of caster so it doesn't wander. Mine was perfect like that. Not thinking the frame or suspension has changed from 05s - 11s. Check with Chris4x4, he'll know for sure..............
  4. Jun 28, 2012 at 10:43 AM
    BTO
    California
    Actually you want some toe else it will wander. Between +.05 and +.1 degree is correct. You need that because it's a rear wheel drive and the bushings give a little.
  5. Jun 28, 2012 at 10:54 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    We'll both be out of toe doing much of anything on these trucks, never had toe stay put. That is what I was always having adjusted every time I had an alignment. I had 3 yr alignment so I went at least twice a yr maybe more if mods occurred but yeah, slightly pointed in so they roll straight and not scrub the edges. OP, you may want to save for or invest in some aftermarket UCAs to get the caster back because you won't have enough caster with oem UCAs lifting 2.5. Caster will not wear tires but will annoy the shit out of you wandering on uneven surfaces or in wind on frwy. Toe and camber out is what wears tires. I ran mine with low caster just long enough to score some LR UCAs. If they go for caster then the camber suffers with oem adjustability. You can go with less lift until you get some and compromise tho by living with 1.75 but then that means multiple strut disassembly/reassembly to change the settings. Truck was magically better with the caster right.
  6. Jun 28, 2012 at 8:13 PM
    yetiman
    yetiman [OP] Member
    Thanks guys for reply!!!!!
