Billstein 5100 easy install method
Discussion in 'Suspension' started by Holyfather, Mar 24, 2012.
  1. Apr 6, 2012 at 9:16 PM
    Holyfather
    Holyfather [OP] Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
    I agree. I used this method without spring compressors and felt perfectly safe doing it. When I need new shocks I will do it this way again.
  2. Apr 9, 2012 at 1:11 PM
    dmb
    dmb Well-Known Member
    Boise, ID
    I used this method over the weekend to put OME 885x's on my 5100s. Worked like a charm. Definitely beats paying a shop to take them out and put them back together.
  3. Apr 10, 2012 at 11:05 AM
    1FSTLS1
    1FSTLS1 Well-Known Member
    Any one done this method with the Eibach springs. I am assuming it will work.
  4. Apr 10, 2012 at 8:11 PM
    Holyfather
    Arizona
    2011 TX Pro TRD
    No I used my stock springs
  5. Apr 13, 2012 at 6:08 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Used this method last night to help a fellow TW user install 5100's and OME 885 coils on his tacoma. It worked awesome! I've always used spring compressors to do the installs. I didn't even have to pull them out of the tool box.
    I have done more suspension jobs than I can count over the years both lifting and lowering vehicles and IMO this is much much safer than using spring compressors.
    dmoyers likes this.
  6. Apr 13, 2012 at 6:13 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    totaly legit. I did mine this way and it worked great. No spring compressor needed :thumbsup:
    I kept putting off my install untill I found this video.
  7. Apr 13, 2012 at 11:17 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Its funny. I have got nothing but good comments on my video from people who have tried this method.
    But the admins feel that it's too dangerous. That's fine, I am just glad they are no longer closing threads that discuss this method.
  8. Apr 14, 2012 at 6:56 PM
    socal147
    socal147 Active Member
    patrick
    Apple Valley Kalifornia
    12 PreRunner SR5
    Just Bought It = NONE
    I did it today. Total control over spring decompression.
  9. Apr 17, 2012 at 6:12 PM
    Swampmonkey
    Swampmonkey Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    Awesome. When i get my OME front shocks in im going this route with my 885s. Just not clear on where to mark tabs. they already marked from the factory. Do i just mark them to make sure i put them back in the right position when i tighten them back?
  10. Apr 17, 2012 at 8:33 PM
    DDD
    Derek
    Santa Clarita, CA
    Yep.
  11. Apr 26, 2012 at 1:21 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    On my previous Tacoma, I had the 5100s at all three settings so I have a good bit of experience doing this install with a compressor. Today, I removed my 2" spacer lift that was on my truck when I bought it and installed OME 885 springs using the method in the video. Much easier doing it this way.
    One note: I did not loosen the alignment bolts in the lower control arm. When I needed more droop I just used my pry bar to push down on the lower arm. My pry bar comes to a point on the end. I just put the end in one of the holes in the lower control arm and pushed down. I'm going to have to have an alignment anyway since the 885s lifted my truck about 1/2" more, but I didn't want to fool with alignment bolts.
  12. Apr 26, 2012 at 6:17 PM
    macgyver
    Brad
    Canton, GA
    So the REAL WORLD consensus is IT'S MUCH SAFER AND EASIER THIS WAY!
  13. Apr 27, 2012 at 6:26 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I used this method after watching this video and it is by far safer and easier then using a spring compressor.
  14. Apr 27, 2012 at 6:44 AM
    Bama_TACO
    Winfield, AL
    The only way this method could become unsafe is if you were trying to remove a spring that was so long that it still had tension on it after you were at full droop.
  15. Apr 27, 2012 at 6:53 AM
    #35
    Stockmonester
    Stockmonester Well-Known Member
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    in channel vent visors
    instead of loosen the lower control arm couldnt you just lift up the entire upper control arm assembly with the floor jack to get more clearence to take the shock assembly out?
  16. Apr 27, 2012 at 6:57 AM
    #36
    Bama_TACO
    Winfield, AL
    That won't help, because the spring/shock assembly is held in place by the upper strut mount and the lower control arm. The only way to get the spring/shock out is to get the lower control arm to move down further. Like I said above, I didn't loosen the bolts in the lower control arm.
  17. Apr 27, 2012 at 1:12 PM
    #37
    Swampmonkey
    Wes
    Fairhope, AL
    Used this method last night to install my 885s and ome 90000 shocks, and yes much easier for backyard install.
  18. Apr 27, 2012 at 3:11 PM
    #38
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I used this method last weekend to install Bilsteins. Works perfect and safe as can be. Be sure to follow the video to the letter and mark the LCA adjustments with white paint before you loosen them.
    I went and had the alignment done at Les Schwab yesterday and the cambers weren't even off.
  19. Apr 30, 2012 at 6:59 AM
    #39
    MikeluvstheTaco
    MikeluvstheTaco Well-Known Member
    Michael
    Saskatchatoon
    TRD Sport
    I did this yesterday, it was a bit of a pain. Things that helped me were taking off the sway bar bushings, this helped with sliding the coil downwards because it was easier to move the spindle around. I used a block of wood as well to pry down the lower control arm, it was stubborn. Thanks for posting this! Saved me 625 for front and back (quoted at the stealership)
  20. May 21, 2012 at 6:43 PM
    #40
    09 Redneck
    09 Redneck Well-Known Member
    Ga
