Billstein 5100 easy install method
Discussion in 'Suspension' started by Holyfather, Mar 24, 2012.
  1. Feb 28, 2014 at 9:04 AM
    #141
    Fatherof2
    Fatherof2 Well-Known Member
    Massachusetts
    2004 DC TRD
    Good luck.
    Keep us posted.
    I really want to give this a shot when it gets warmer.
    I need to get clear on the process first.
    If you are able, please let us know the torque specs you used.
    Thank you.
  2. Feb 28, 2014 at 9:19 AM
    #142
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    If I remember I'm going to video it with my iPad for the 1st Gen guys. From the sounds and looks of it it should be pretty easy. I'm going to find the torque specs in the factory service manual hopefully.
  3. Mar 1, 2014 at 8:26 AM
    #143
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Anyone know what size nut, the top nut for the strut rod is on the 2nd Gen Blstn 5100's? I can't tell if it is the M12 1.50 or the 1/2"x20. Thanks in advance.
  4. Mar 2, 2014 at 11:00 AM
    #144
    rruhl48
    rruhl48 Active Member
    Rick
    union county NJ
    07 access AFE 3 inch volant ram air. sounds.p
    AFE 3 inch sounds amazing.. volant ram air intake
    Ok guys I'm.lifting my 07 sr5 bilstien 5100s and fox 3 inch rear long aal dif drop spacer skid plate spacer drop carrier bearing spacer sway bar drop brackets I know I need new brake lines and haven't heard much about proportioning valve will look into and the e brake extensions?. Going cooper atp lr e 265 75 16 on stocks for now my real question is can I put the 5100s on there stock hight or even like 1.75 and put.2 inch leveling lift spacers on top to help give them more extension and keep my stock ucas thanks any opinion at this point really helps
  5. Mar 3, 2014 at 5:34 AM
    #145
    Tribull
    Little Rock, AR
    Well, I ended up getting the stock coils out using this method, and using a strut spring compressor to get the ToyTec/Bilstein struts assembled. Was still a very easy process. I just didn't want to loosen my LCA's to get it done.
  6. Mar 3, 2014 at 9:00 AM
    #146
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    Is a 3.5 ton floor jack big enough for this project or do I need to buy something bigger????[​IMG]
  7. Mar 3, 2014 at 9:08 AM
    #147
    Tribull
    Little Rock, AR
    My 3 ton was plenty high enough.
  8. Mar 3, 2014 at 11:33 AM
    #148
    Fatherof2
    Massachusetts
    2004 DC TRD
    So is the video at the beginning of this thread good for the Gen 1 Taco?
    I just want to change my shocks.
    I don't want to replace anything else.
    Thanks Tribull.
  9. Mar 3, 2014 at 7:38 PM
    #149
    SilverSurfer
    Mark
    Los Angeles
    2013 4X4 LT
    Damn before I get too ahead of myself and start ripping my suspension apart for this method does this work with the Eibach spring? I would hate to get to that part and not be able to compress that bad boy.
  10. Mar 4, 2014 at 5:02 AM
    #150
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Did it with my 885's, no problem.
  11. Mar 4, 2014 at 5:19 AM
    #151
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  12. Mar 4, 2014 at 9:11 AM
    #152
    Tribull
    Little Rock, AR
    If you are running stock coils, and doing nothing other than replacing your struts, this should work like a charm!
  13. Mar 5, 2014 at 5:32 AM
    #153
    Fatherof2
    Massachusetts
    2004 DC TRD
    I don't want to replace my struts.
    Did you mean to say "shocks"?
    I really need step by step instructions, so I was hoping that the video at the beginning of the thread would provide all that I need.
    Do you feel that it does?
    Thank you!
  14. Mar 5, 2014 at 5:35 AM
    #154
    rruhl48
    Rick
    union county NJ
    Setting at 2.5 adding shock extensions 2 inch. Do you think.I need to worry about swapping the brake lines looking at a 2 "4 inch extension set braided with vcs for a 2007 sr5 front back but it doent seem to have the extension for the e break axle drop when I add the aal and 3 inch fox shocks. My real other question is do you think the drop carrier and skid plate /dif drop is necessary I also.Will install the sway bar drop. Let me know what you guys think thanks
  15. Mar 5, 2014 at 5:44 AM
    #155
    motionridr8
    motionridr8 Well-Known Member
    Drew
    Greenville, SC
    2012 Tacoma 4x4 DCSB
    5100's/886's/JBA UCAs, ICON RXT Rears, US Offroad Winch Front Bumper, BAMF Rear Bumper, 235/85r16 Skinnies
    I also did this with my 885s and it worked with no issues. I'm surprised to hear that it worked with 886s. Even when re-compressing my 885s I could see the front end of the truck starting to come off the jack stands, but good to know that it is possible to do 886s.
  16. Mar 5, 2014 at 6:19 AM
    #156
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I think the weight of the bumper and winch may have helped out in that respect.
  17. Mar 5, 2014 at 7:26 AM
    #157
    Tribull
    Little Rock, AR
    If you are wanting to change the shocks that run inside of your coil springs on the front of your truck, they are not actually called shocks. They are struts. That's why it, when all put together, is called a strut assembly. That is also why, if you decide to use a compressor to disassemble/reassemble it, then you would need a Strut Spring Compressor, and not a Coil Spring Compressor.
    As far as all of the proper instructions, the video more or less gives you what you need. Here is another good thread to do some research on:
    http://www.tacomaworld.com/forum/suspension/31862-how-front-shock-spring-removal.html
    Make sure you have all the tools necessary before you start the job. And I think it's a good idea to stop by your local O'Reilly or Auto Zone and rent a Compressor, just in case.
  18. Mar 5, 2014 at 10:28 AM
    #158
    Fatherof2
    Massachusetts
    2004 DC TRD
    Great stuff!
    Thank you!
  19. Mar 5, 2014 at 11:11 AM
    #159
    Tribull
    Little Rock, AR
    Anytime! :thumbsup:
  20. Mar 8, 2014 at 1:13 PM
    #160
    SilverSurfer
    Mark
    Los Angeles
    2013 4X4 LT
    Just installed my Eibach with 5100's, wasnt too bad just was a P.I.T.A getting everything lined and torqued with very little clearance but saved 300 bucks to do it my damn self. Now its at the alignment shop getting lined up!!!! Cheers!!!
