Billy 5100 shocks + what coils to get 3" in front?
Discussion in 'Suspension' started by PLYDRTY, Mar 7, 2012.
  1. Mar 7, 2012 at 6:55 PM
    PLYDRTY
    PLYDRTY [OP] Well-Known Member
    Jeff
    Manassas, VA
    08 TRD Sport DCSB
    I have a 2006 DC w/ a 3" spacer lift on it at the moment. I am considering the 5100 series adjustable shocks up front. I know thay will adjust to 2.5" with the stock springs. My question is what coils do I need to get it up to a full 3". I want to get 33's under it & 'wheel it.
  2. Mar 7, 2012 at 7:32 PM
    06tacomakev
    06tacomakev Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    I am undergoing the same dilemma. I believe you have a choice between the Eibach coils from Toytech or the OME coils.
    I do not like the idea of using my stock coils on the 2.5 setting.
  3. Mar 7, 2012 at 7:34 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You have two options with the 5100s to achieve 3" of lift
    1. stock coils @2.5 with 0.5" top plate spacer
    2. Eibachs coils at 0.85" with 0.5" top plate spacer.
    Keep in mind you will likely need new ucas to get your alignment in spec at 3" of lift.
  4. Mar 7, 2012 at 7:59 PM
    PLYDRTY
    Jeff
    Manassas, VA
    08 TRD Sport DCSB
    Which coils? The 1.6"? The UCA's will be next. How well does this set-up work off road?
  5. Mar 7, 2012 at 8:01 PM
    TexasTacoma37
    1.6" yes. If you are into hardcore offroading I'd recommend icon, fox, or king coilovers.
  6. Mar 7, 2012 at 8:25 PM
    PLYDRTY
    Jeff
    Manassas, VA
    08 TRD Sport DCSB
    Not hardcore. Trails, a little mud.
  7. Mar 7, 2012 at 8:29 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Get the 5100 with the toytec/eibach coils.
    Set the billies at .85 and you should have a great ride and 2.5" of lift. That should level your truck, then cab mount chop and some minor plastic removal from the wheel well and you're good to go.
  8. Mar 7, 2012 at 8:51 PM
    PLYDRTY
    Jeff
    Manassas, VA
    08 TRD Sport DCSB
    I've done some plastic trimming. Cab chop will be done as well.
  9. Apr 6, 2012 at 9:02 PM
    PLYDRTY
    Jeff
    Manassas, VA
    08 TRD Sport DCSB
    Ok... looking at a set of 5100's and OME 885 coils. Set them at .85? Will this give 2.5 or 3" up front?
  10. Apr 6, 2012 at 10:22 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    885's and 5100's @ 0 plus a 1/4" top plate spacer will get you 3" on a DC
  11. Apr 6, 2012 at 10:27 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Yop
    What happened to your post count..... lulz
  12. Apr 7, 2012 at 9:02 AM
    PLYDRTY
    Jeff
    Manassas, VA
    08 TRD Sport DCSB
    Who makes a 1/4" top plate spacer? I know Toytec has a 1/2" (I think). That's why I was asking if I could use the 885's and set the 5100's at .85 to avoid a spacer.
  13. Apr 7, 2012 at 9:15 AM
    OZ-T
    Peter North
    British Columbia
    Toytec makes a 1/4" top plate spacer which provides approx 1/2" of lift
  14. Apr 7, 2012 at 9:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Setting the 5100s at .85 abd using the 885s will give about 4 " lift.
  15. Apr 7, 2012 at 9:23 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    For a little bit more money why don't you go OME. They key not be adjustable but they will get you a full 3 inches of lift over stock.
  16. Apr 7, 2012 at 9:26 AM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    ^^Why doesn't anyone run this? What would be so bad with setting the billys at .85 w/ 885 coils? Everyone seems to reccomend against this, but i just don't recall seeing a reason for not doing it.
  17. Apr 7, 2012 at 9:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Because your suspension only has 4 inches of town travel as it is. Lifting 4 inches will net you 0 down travel.
  18. Apr 7, 2012 at 9:41 AM
    OZ-T
    Peter North
    British Columbia
    885's will only net 2 1/2" on a 2nd gen DC
  19. Apr 7, 2012 at 9:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Many have gotten 3" from the 885's with no spacer.
  20. Apr 7, 2012 at 9:45 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    OK here is a noob question. I know this thread kinda proves wrong but.... :crapstorm:
    I thought billies only went up to 2.5. Would putting them up to 3 over extend them?
