Bilstein 5100 + 2" AAL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco157, Apr 16, 2010.
  1. Apr 16, 2010 at 4:27 PM
    taco157
    taco157 [OP] Active Member
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    Just orded a lift for my 06 Double Cab Long Box..... I got 5100's for the front... planning on setting them at 2.5" . I also got the ToyTec 2" Add-a-leaf... Is this too much for the rear?? Does anyone have this set up in their truck?? Just second guessing what i ordered... i dont want it too look dumb... pics would be a big help. I'm running 265/70R17 Mud Terrains...
  2. Jun 26, 2010 at 10:28 AM
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    I went with the 5100 at 2.5 and a 1" lift in the rear to level it. Looks great!
  3. Jun 26, 2010 at 10:29 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    check my build thread. I have that exact setup. As you can see the rear was a little taller at first, but then it settled and now sits right imo.
    and i'm now running 285/65-18's with a lot of trimming
  4. Jun 26, 2010 at 10:55 AM
    hoeflich
    hoeflich Its all mod on the inside
    florida
    96 3.4L 4X4
    Stuff
    Got the setup you have, and I like it. Like Mx stated...the rear is higher...havent seen it settle yet...but I've only had it for a week.
  5. Jun 26, 2010 at 10:59 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    My stock leaf pack was horribad (bowed the wrong way), so my AAL's are taking a lot of the weight. I think thats why they settled so fast.
  6. Jan 24, 2011 at 7:43 PM
    preston
    preston Active Member
    preston
    remlap alabama
    06 tacoma 4x4
    flow master dual exhaust, husky liner floor mats, bilstein 5100s all around,
    what size tire are you running hoeflich?
  7. Jan 25, 2011 at 5:59 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    5100s set at 2.5 up front. Icon progressive 3 leaf in rear. Was supposed to be a 1.5" but right now it's about 2 1/4 higher in the rear than it was. Hasn't settled in 3 weeks but I'm expecting it to come down some.
  8. Jan 25, 2011 at 6:04 AM
    xGManx
    xGManx Well-Known Member
    Garrett
    South
    06 DC LB
    black rims, blacked out grille, blacked out exhaust tip, 5100's 1.75" with 2" rear block, pioneer head unit
    pic?
  9. Jan 25, 2011 at 6:11 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    05 Taco 4x4 SR5 TRD AC
    Where did you order your stuff from. Thats about what I need to replace the spacer lift my truck came with.
