Bilstein 5100/5125/5165 Split Digressive Valving?
Discussion in 'Suspension' started by Sublime, Oct 8, 2011.
  1. Oct 8, 2011 at 8:31 AM
    Sublime
    Sublime [OP] Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Found this about 5100's being a digressive shock!
    "The shocks feature vehicle specific split digressive valving…..”
    What's the split digressive mean? (compression/rebound?)
    The 5125s just say they have deflective self adjusting valving……can anyone elaborate? That would be different than the 5100’s? I can feel a difference now that I have them on. The rear end feels a little less stable (the shock compresses easier) but my rear springs have softened up to some degree!
    Also, anyone running the 5165’s? These things look mean and have the stem top already. Wonder what the measurements are on the 10” travel ones and if they would work well with the 3” AllPro leafs I’ve got my eyes on!
  2. Oct 8, 2011 at 10:33 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Sub'd. :popcorn:
  3. Oct 9, 2011 at 11:49 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Anyone? What do u guys think?
  4. Nov 7, 2011 at 9:58 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Split digressive valving is a fancy way of saying that a digressive piston is being used and the valving is not 50/50 but actually split (usually more rebound resistance than compression). In a digressive piston design, the shocks dampening capabilities are felt more rapidly because the piston is concaved and the shims are slightly bent (preloaded) into the dish shape of the piston. The benefit to this over using just heavier grade shims is that the dampening response is felt much quicker but the max yield doesn't really change. So it's sort of a way to get more performance out of the same shock without using thicker valving shims.
    Self adjusting deflective valving is pretty much standard issue in any decently made after market shock (sway-away, fox, etc.) Not really special unless your compairing it to bone stock car shocks. It's essentially like the digressive shock described above (uses a piston with multiple shims stacked in a pyramid on both sides for dampening) only the piston is NOT digressive (concaved). This is known as linear valving. Some companies tend to use digressive valving while others use linear. Typically the digressive valving will have a firmer feel to it and is considered more advanced. Both designs have their purpose so pick your poison. Icon shocks are digressive which is why many people talk about Icons having a firmer ride than some other brands.
    Hope this helps...
  5. Nov 7, 2011 at 11:02 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Thanks man, good info! I realize the 5100's and 5125's all have the same valving!
  6. Nov 8, 2011 at 12:07 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    I believe they are the same shock. Only difference is the external features because one is universal and the other is specific to a particular vehicle.
  7. Nov 8, 2011 at 7:49 PM
    Norton
    Thank you!
  8. Nov 10, 2011 at 8:36 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Quite welcome :)
    Bilstein must have a great marketing crew working for them. Their verbiage could sell water to a fish haha. However, I remain firmly convinced that when it comes to quality and reputation, there is none better than bilstein. Even their inexpensive shocks seem to outlast all others under hard conditions. I can't wait to see the day that Toyota comes up with an answer to the Ford Raptor. Some bilstein 2.5" coilovers that come factory would be the cat's meow. I'd be the first to buy :D
  9. Nov 11, 2011 at 12:32 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Hell ya......maybe a 2" over similar to AllPro and a SUA pulling 12" front and rear! Still keeping it looking stock, but able to out perform the raptor! Damn, this forum alone should give them ideas of what "should" be done to the tacoma!
    PS - 4.10 gears in all models too! Lol
  10. Nov 11, 2011 at 8:23 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Mmmmm :drool::drool:
    Hey! don't tease me like that :p
    The 4.10 gears would just be icing on the cake. Man Toyota needs to quit screwing around with that Baja edition and just go all out.
  11. Nov 11, 2011 at 4:49 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Dude, just noticed your sig says you have a DMZ bedcage and 14" smoothbody's with an aal? Did you relocte your shock mounts? I want more info....and pics lol!
  12. Nov 11, 2011 at 4:52 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
  13. Jun 1, 2012 at 11:24 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    What are the rear 5100 and 5150's valved at for the 2nd gen tacoma for compresion and rebound? I'm really liking the 5165's and doing alot of research on them
