Bilstein 5100 adjustable paired with EIBACH 3" lift coils spring
Discussion in 'Suspension' started by Mainmoe02, May 22, 2013.
  1. May 22, 2013 at 12:34 PM
    Mainmoe02
    Mainmoe02 [OP] Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I went into 4wheel parts today to ask if they would install my new suspension that I ordered online. They thought about it and after asking what I was getting they said no. Their reason...
    He said that the Bilstein 5100 adjustable isn't long enough to be paired with the EIBACH 3" lift coil spring. The reason he gave was that "no matter where you set the height of the Bilstein that it would be preloaded. Basically he was telling me that the Bilstein 5100 adjustable and the 3"lift EIBACH coil spring is not a good pair. I told him that I've read plenty people who have this set up and are happy with it.
    Can anyone tell me for sure if the 2 will work together. If not can you explain why? And if they will work fine, can you explain why?
    My other thought was, since 4 wheel parts works mostly on jeeps, and how some jeeps have the shock and spring separate. Maybe he thought that was the same scenario on my truck. I'm not sure just taking a guess.
    If you can let me know what you think!
    Thanks for the help!
  2. May 22, 2013 at 1:47 PM
    BradyT88
    BradyT88 Well-Known Member
    I would just tell him you don't care about the pre-load. The eibachs are designed specifically for the 5100's so it will work. For 1st gens you get 3" out of them with the 5100's set at 0 don't you?
    If he knows enough to think they aren't a good pair he probably already knows that Tacomas run Coilovers instead of separate shocks and springs, maybe anyway. Wouldn't hurt to throw the word coilover around I guess.
  3. May 22, 2013 at 1:50 PM
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    i have them and they work fine,there a little stiff which is is gonna happen, i havent had any issues with alignment but i also have light racing ucs's, just make sure there set at the lowest setting on the 5100's
  4. May 22, 2013 at 2:57 PM
    Mainmoe02
    Moe
    Austin, Texas
    I've heard many people say they are a good pair, especially on our trucks. So I'm gonna take the word of all the people who have experienced this combo.
    Since you have the same set up I ordered, what size tires are you running? Do u know what would be the biggest that would fit with this suspension? I'm wanting 255/85/16 bfg km2. They are a little narrower than the stock 265/70/16 but they are much taller, about the height of a 33" tire. Let me know what you think or experienced. Thank!!!!!!!
  5. May 22, 2013 at 2:58 PM
    BradyT88
    Not sure about fitment, (I'll bet they will with a little trimming though) but that is the exact size and tire I am running and they rock!
  6. May 22, 2013 at 3:03 PM
    Mainmoe02
    Moe
    Austin, Texas
    I bet they do, they look awesome! Can't wait to get them.
    What size lift r u running?
  7. May 22, 2013 at 3:05 PM
    BradyT88
    Like 2-3". Not really sure exactly because mine was already kind of lifted when I bought it. It has all settled some too with all the armor I have added as well.
  8. May 22, 2013 at 3:06 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    4WP does not want to install equipment that you did not order from them.....that's what it boils down to.
  9. May 22, 2013 at 3:09 PM
    Mainmoe02
    Moe
    Austin, Texas
    Well hopefully at worst all I'll have to do is trim a little. Wonder if spacers may help? You running any spacers?
  10. May 22, 2013 at 3:10 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    They work great together! We have a dealer in San Antonio that can help you out. Diesel Toys 877-545-8699.
    I hope this helps!
  11. May 22, 2013 at 3:12 PM
    BradyT88
    Nope. 4.5" backspaced 16x8" wheels. I wouldn't run spacers, they will just make the rubbing worse on the wheelwells and such. Spacers help get your tires off of your frame but that shouldn't be an issue with 33's really.
  12. May 22, 2013 at 3:15 PM
    Mainmoe02
    Moe
    Austin, Texas
    Oh I c. So it rubs on the wheel well. So putting spacers would push them out and make it worse. Thanks for the help! It's reassuring :D
  13. May 22, 2013 at 3:18 PM
    Mainmoe02
    Moe
    Austin, Texas
    Awesome I had no idea! I'll be giving him a call. I ordered my Bilsteins on all 4 corners, eibach coils, and new OME 2.25" lift leaf spring pack. I'll give him a holler, I do have some questions. Thanks!
  14. May 22, 2013 at 3:22 PM
    BradyT88
    Yep. For on road driving I had to trim just a little bit of plastic here and there. Didn't take much really. But 1st gens and 2nd gens can be like apples and oranges sometimes. I believe Blackdawg is running 5100's with the Eibachs and he fit 33x12.50 even with spacers so I imagine you will be fine.
  15. May 22, 2013 at 3:34 PM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    im running 285/75/16 i had to run a 1" wheel spacer to clear the UCA but other than that no major trimming just plastics and hammer the pinch weld flat, with your skinner tires i bet they will fit good without a spacer
  16. May 22, 2013 at 3:37 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  17. May 22, 2013 at 3:47 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Only reason so,done would recommend it is cause our trucks don't like 3" of lift period. If makes the cv boots rub and then bust down the road.
    I do have wheel spacers to help keep my 12.5s off the UCAs and frame. But it puts the tire into fenders more so you have to trim there more.
