Bilstein 5100 adjustable struts, what heigth to adjust to? I need help!!!
Discussion in 'Suspension' started by R.etheridge, Apr 15, 2010.
  1. Apr 15, 2010 at 4:24 PM
    R.etheridge
    R.etheridge [OP] Well-Known Member
    Middle GA
    03 Tacoma TRD 4x4
    I just got some bilstein struts, my question is it is 1-3 inch adjustable so where do I set the ring if I want the full 3? The bottom groove or the top groove? I thinking the top groove but just wanna make sure before I go through all the trouble. And I also got some rev teck extender spacers for the front that I put in with some 3in add a leafs and bilstein 5100's rear shocks in the back. Will my truck sit level or should I make an adjustment on the strut? Its a 03 double cab 4x4 TRD. Thanks
  2. Apr 15, 2010 at 4:28 PM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    it only goes to 2.5, and adding a spacer to that is not recommended. you should get the desired height you want with the 2.5. your truck may lean toward the front a bit once you get the aal added, but you have to give the leaf time to settle.
  3. Apr 15, 2010 at 4:42 PM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    what about the settings I have on the adjustable struts? are they right? I need to be on the top groove to be at 2.5? and wheelers recommended me to get the spacers
  4. Apr 15, 2010 at 7:10 PM
    ComeOnToIt
    ComeOnToIt Member
    Northern New Hampshire
    '10 DBL.CB. TRD OR & '07 DBL.CB. SR5 4X4
    Bilstein 5100's- front, Rear spring TSB, Toytec 1.5" AAL, Goodyear Duratracs, Extang Trifecta Signature Series Tonneau
    There are 4 grooves and a snap ring on the shocks which snaps into the setting you want. There should be instructions that came in the box... but the bottom groove is 0 lift, then .85, 1.75 and 2.50 on the top one.
  5. Apr 16, 2010 at 1:05 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    no instructions came with them. I was pretty sure it was the top one for 2.5 i just wanted a second opinion before I put everything back together. Thanks buddy
  6. Apr 30, 2011 at 7:38 AM
    greyes85
    greyes85 Member
    Gabe
    lake jackson
    -6inch lift Rough Country -20% window tint all around -MagnaFlow Pro Series Exaust -Total Chaos control arms -K&N CAIT -Firestone Ride-Rite Airbags
    i set mine @ 2.5 with top spacer and the guy from toytec doesnt recommend that to set the clip at the second setting which the coils make up for that and add a 1/2 spacer to get a complete 3 like mine i set it @ 2.5 which has maxed it out which mwans ill need to get uca's and my cv boots are at an angle which can cause damage
  7. Apr 30, 2011 at 12:26 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The 5100's for 1st gens have settings for 0, 1.25", and 2.5", they do not have 4 settings.
    You can add a very thin top-plate spacer (1/4" thick) to go up to 3" if you like (you will probably need new uca's if you do this), but DO NOT add any spacer that will take you over 3" of lift total.
