Bilstein 5100 at .85 with OME 885 Coils?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by soflasurfr, Sep 23, 2010.
  1. Sep 23, 2010 at 5:38 PM
    soflasurfr
    soflasurfr [OP] Well-Known Member
    Bilstien 5100's all around, OME 885 coils, AAL, Total Chaos UCA's
    With my current set up the bilsteins are at 0 and the coils are giving it all the lift, with a spacer. However, the ride is really jarring. Someone here recommended I remove the spacer and set the bilstein at .85.
    Anyone tried this? Does it ride ok? I think I need that extra lift for the tier clearance, it rubs pretty good already.
    Thanks for the help
  2. Sep 23, 2010 at 5:57 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Make sure you installed lift correctly. Shouldnt ride that bad
  3. Sep 23, 2010 at 6:12 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    The spacer does the same thing as moving the collar up to .85.
    The difference is in the thickness of the spacer. If it is less than .85" or more. If it was a 2" space it would have been stiffer than the .85
    Both preload the spring and as you compress the spring more the ride will get stiffer.
    Might want to go with 886 springs which will be stiffer but longer so they will ride better.
    The 5100s may be a little over matched with the extra stiff springs and preload.
  4. Sep 23, 2010 at 6:13 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    if you ride is jarring...this set up will be the same... check to see if your lift is installed correctly
