Bilstein 5100 bushing replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by AzTaco98, Jan 23, 2021.
  1. Jan 23, 2021 at 2:23 PM
    AzTaco98
    AzTaco98 [OP] Member
    Anyone ever had any luck replacing the lower eyelet bushings on a pair of Bilstein 5100s? Mine are only a year old and I just need to replace the bushing.
  2. Jan 23, 2021 at 2:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tons of places offer the bushings for like a few bucks.
  3. Jan 23, 2021 at 3:15 PM
    AzTaco98
    I can't find them anywhere. Called Bilstein and they're no help. I have the b8 5100s. Maybe I'll try these:
    Kwikvette likes this.
  4. Jan 24, 2021 at 5:45 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    you are lucky. My Icon lower bushings cost big $ and I am angry about it. Wish I had stock struts.....
  5. Jan 24, 2021 at 8:34 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It helps if you have the size you need.
    It is not that hard ( for Me) to get the round stock and make your own
    AzTaco98[OP] and Kwikvette like this.
  6. Jan 24, 2021 at 9:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This.
    I needed to replace the lower set on some Fox shocks because the inner diameter was smaller than needed for my truck; found them online for the size I needed.
    AzTaco98[OP] likes this.
  7. Jan 24, 2021 at 10:29 AM
    AzTaco98
    Thanks for the help, Ill have to get the measurements tomorrow and double check the size. Are they a bitch to press out?
  8. Jan 24, 2021 at 10:35 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    they don’t use standard spherical bearings like all of the other coilovers on the market? Those are like $15 each
  9. Jan 24, 2021 at 10:47 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Edit - disregard if this is about the rear shocks, thought we were talking fronts
    Performance coilovers don't use bushings in the bottom they use com10 spherical bearings, they're like $15 each. Unless you mean the labor to get them sent out and replaced, but it's easy to DIY and save the money. Just push the old bearing out and push the new one in, c clamp and a socket works well
  10. Jan 24, 2021 at 3:45 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Silicone spray is your friend makes putting them in easy.
    Cleaning the dirt out is a must .
    Did you forget something the bushing failed so quick ??
    AzTaco98[QUOTED][OP] likes this.
  11. Jan 25, 2021 at 7:42 AM
    AzTaco98
    No anti-sieze on the strut bolt, so the bolt seized to the inner bushing sleeve. When I went to loosen the bolt it took the bushing with it and tore it in half. One step forward, two steps back.
    Wyoming09[QUOTED] likes this.
  12. Jan 25, 2021 at 12:07 PM
    Actionjackson
    Jack
    MA
    2004 Tacoma
    Wow that is a big help. I did not know they are called spherical bearings. Thank you. Icon wants 60$ each. I think the ones for 15 you showed me on Amazon will work. Again THANK YOU!
  13. Jan 25, 2021 at 12:11 PM
    eon_blue
    Azusa, CA
    Here's a thread that shows what it all looks like...no bushings - just bearings, misalignment spacers and clips. They might even still sell these kits
    https://www.tacomaworld.com/threads/icon-coilover-lower-bearing-service-kit.537507/
    Honestly, $60 for the full kit (both sides) doesn't sound so bad. Keep in mind those $15 bearings are just part of it, but if you source the misalignment spacers and snap rings yourself you can probably come out cheaper than the kit.
    I was able to reuse my misalignment spacers when I did mine
  14. Jan 25, 2021 at 6:43 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I've heard making your own poly bushings isnt that hard, especially if you can pour directly in rather than a mold. You just need to extract the center pins from your existing bushings
  15. Dec 29, 2023 at 8:02 PM
    BatteredTaco
    BatteredTaco Well-Known Member
    J Lo
    SoCal
    02 3rz stick 4wd ext
    JDM 3rz@300k Yota1 cylhead@400k ARB-OME 880/5100s
    Do not replace lower eye bushing with Moog bushing. Super squish immediately. Not sure if oem toyota bushing will fit.
    kctmet likes this.
