Bilstein 5100 Information
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nedwards0421, Sep 26, 2016.
  1. Sep 26, 2016 at 6:34 PM
    nedwards0421
    nedwards0421 [OP] Member
    2012 DCLB TRD Sport
    Hello, I just purchased a 2012 pre runner and I want to make look a little bigger as it is sitting on stock suspension, wheels and tires right now. I did some research and concluded that bilstein 5100s in the front only were the best option for me as I'm mainly using this truck as a daily driver combined with some light to medium off roading. I've read in some threads that leveling out the truck with these shocks improves the ride quality, but haven't seen it enough to fully believe that it does. I'd like your input on a few things below:
    - Does leveling the truck out with stock springs and 5100s actually improve ride quality and handling?
    -I was think of putting either 285/70r17 or 275/70r17 a/t tires on with the level based on my research, just want some reassurance that this will work.
    - Along with the shocks, what other components/adjustments will I need for the truck to function properly?
    Thanks for your input, if there are any threads related to the information I need, then just paste the links below as I am fairly new to this site.
    ChadsPride likes this.
  2. Sep 26, 2016 at 7:14 PM
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    This is a really good option. I have the 5100's set at 1.75" and I love the way it corners compared to stock. The front feels much more planted. If you want to reduce/remove wheel hop (I think its called axle wrap) get an add-a-leaf. Cheap and easy to install and will also raise the rear between 1.5 and 2 inches as well as increase cargo capacity. After doing both my drive drives far better than stock and its doesn't really cost a lot.
  3. Sep 26, 2016 at 7:16 PM
    DuttonCD
    DuttonCD Well-Known Member
    Alabama
    2018 TRD OR CEMENT
    5100's front only with stock coils?
  4. Sep 26, 2016 at 7:16 PM
    ChadsPride
    Sponsored by TacomaWorld.com
  5. Sep 27, 2016 at 12:13 AM
    Thelgord
    Augusta, GA
    Yes
  6. Sep 27, 2016 at 12:52 AM
    neverstuck
    neverstuck Well-Known Member
    Vancouver Island
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    It's an improvement in some ways but if you'r replacing the shocks that means you need to reassemble anyway. replace the stock coils with OME 884 coils for 2" of lift and leave the billy's at 0 so you're getting lift from the springs instead of back-loading the shocks and losing your upward spring travel. Ride quality will be remarkable better for the sake of the price of a couple tanks of gas.
    ChadsPride and Thelgord[QUOTED] like this.
  7. Sep 27, 2016 at 5:11 PM
    nedwards0421
    2012 DCLB TRD Sport
    What size tires are you running currently?
  8. Sep 27, 2016 at 5:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    People.
    Regardless of lift height, you WILL NEED TO DO TRIMMING with 285/75R16 or 285/70R17 size tires... there is NO WAY AROUND IT. The tire size is simply TOO big for the wheel well. If you plan on going that size plan on removal of mud flaps, cab mount chop and beinding of the pinch weld / inner fender delete / trimming.
    That is unless your truck doesnt flex more than up a curb at the mall... and even then dont be turned when your doing it.
    Pigpen, T4RFTMFW and Bluegrass Taco like this.
  9. Sep 27, 2016 at 5:28 PM
    Seca40
    Seca40 Member
    Cedar Crest, New Mexico.
    '11 DCSB TRD OR
    5100s OME 884 AAL, All Pro front skid. Patches!
    After making myself crazy researching this topic, I came to this conclusion as well. I've only driven it about 100 miles since I installed them but the front end does seem stiffer without riding like a dump truck. I'm glad I didn't preload my stock springs.
    Thanks TW for the tons of good info.
    old55guy likes this.
  10. Sep 27, 2016 at 5:35 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    This^
    And much depends on tire choice. Some 285's are bigger than others. I'm looking at 2 different brands for my next tire. 285/75/16 Goodyear Duratracs are 33.1" diameter. Mastercraft MXT (made by Cooper) are 32.8" Not a HUGE difference, until you try to stuff 'em in a confined wheel well.... Then it's like the old man said as he was peeing in the ocean....."Every little bit helps".....
  11. Sep 27, 2016 at 5:39 PM
    Thelgord
    Augusta, GA
    265/75/16
  12. Sep 27, 2016 at 5:40 PM
    old55guy
    old55guy Well-Known Member
    mike
    2011 dcsb trd white
    none
    So how about a picture ??? Thats what I want on mine , also wondering if after market steel rock slider will make it sit any lower than 2" with 884 ?
  13. Sep 27, 2016 at 5:42 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It'll be sub 2" with sliders on your truck.
  14. Sep 27, 2016 at 6:35 PM
    nd4spdbh
    SoCal
    FYI i am running 5100's with TRD OR coils at the 1.75 in setting and i LOVE the ride over stock, its a much nicer firmer ride but not overly firm ride.
    That stated i lived with stock UCA's for a year then said F this and went with SPC UCA's...... i was kicking myself after i did, as it drives SOOOO much better now.
    T4RFTMFW likes this.
  15. Sep 27, 2016 at 6:35 PM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    I had stock coils set at 1.75 and now have 885 coils with 5100s. The stock coils were stiffer and I liked the ride better on road. The front also sagged less when I put my winch on than with the 885s. For general off road and rough road driving, the 885s are far superior.
  16. Sep 27, 2016 at 6:36 PM
    Pigpen
    Northwest Montana
    This
  17. Sep 27, 2016 at 8:17 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    NO, makes it worse. Stiffer and bottom out really easy. You will spend $200 for the parts and if you can not install yourself another $150-$200 for install. Better off just buying new springs and shocks. I did spacers with blocks, then 5100's with blocks, then broke down and bought new iron man springs and shocks and Deaver AAL. Now rides better than a Mercedes :) Could have saved a whole lot of money doing it right the first time :) Side note, I do run 5100's in the back, they are pretty good!
    I run 285/70/17 with 3" lift. They will be fine with 3" lift with SOME OEM wheels. Please specify which you have.
    None. Just a good alignment.
    Hope that helps :)
  18. Sep 27, 2016 at 8:20 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    New upper control arms with a 3" lift.
  19. Sep 27, 2016 at 9:01 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Yes, would be nice :) Travel is limited a bit by UCA's but as long as it aligns for minimal use he should be ok i think. :)
    side note:
    the UCA issue is a good point, when you do alignment, BUY THE LIFETIME ALIGNMENT! If you keep playing with the front (which I am sure you will, it is addictive) it helps to be able to bring it back anytime and have them check alignment :) Firestone lost about a ba-jillion dollars on me and alignments over the last 10 years :)
    GreyFox Ind likes this.
  20. Sep 27, 2016 at 9:34 PM
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
