Bilstein 5100 Install Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coldspire, Nov 9, 2009.
  1. Nov 9, 2009 at 5:28 PM
    Coldspire
    Coldspire [OP] Well-Known Member
    B-Rad
    AB, Canada
    2001 Xtra Cab, 2.7L 4cyl. Manual
    Grill guard, Helo rims on Wrangler 245/75 R16s, Altezza taillights, Kenwood DVD Player
    Hey where can I find install instructions for 1st gen bilstein 5100s? I'm sure that there are some on this site somewhere but all I could find find were fabtech, tuff contry, etc. lifts.
    Thanks in advance :)
  2. Nov 9, 2009 at 5:30 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    5100's install just like any shock. If you type in 5100 install in the search you will find tons of info. They took me about 3hours to put on.
  3. Nov 9, 2009 at 6:57 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    you talking about the front or rears?
  4. Nov 9, 2009 at 7:50 PM
    Coldspire
    B-Rad
    AB, Canada
    Preferably front and rear.
  5. Nov 9, 2009 at 9:09 PM
    MotoXXX
    MotoXXX Well-Known Member
    San Jose
    02 Pre-Runner
    Take the fronts to a tire shop to have the springs removed and swaped if you are not familiar with them, take off tires, un-bolt sway bar link, take off single bottom bolt, then the three little ones on top, they should drop out. DO NOT TOUCH THE BIG CENTER NUT! you can lose teeth on that one! Rear are a peice of cake, two bolts drop em out.
