Bilstein 5100 install thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by rescuek10, Sep 20, 2010.
  1. Sep 22, 2010 at 4:27 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Where did you get the aal (some are not designed right, can damage the pack, and cause poor ride quality)? Usually if you set the front at 2.5" you will need a 1.5" aal.
  2. Sep 22, 2010 at 5:35 PM
    rescuek10
    rescuek10 [OP] Member
    Andrew
    Charlotte, NC
    04 Tacoma 4x4
    All terrains, window tint, and strobed out.
    On the middle notch...hopefully about 1" will do all I want it to do. Plus when I get more $$ I'll go back and get an AAL or a set of leafs and pull the shocks off and move the spring seat up to the top notch.
  3. Sep 22, 2010 at 6:38 PM
    .Trdtaco315.
    .Trdtaco315. Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    i got it online with my leveling kit, its made by pro comp
  4. Sep 22, 2010 at 9:27 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Good information. I just got a set of the Bilsteins for the front of my Tacoma. I have to admit though I am a little concerned with the small snap ring thing that sits in the groove to hold up the coil perch. It just seems like a flimsy idea to me. It kind of scares me to think that the one little snap ring in a groove is all that is holding everything up. I guess that no one has had issues with this set up have they?
  5. Sep 22, 2010 at 9:38 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    you would be surprised on how much pressure that little snap ring can hold.
  6. Sep 22, 2010 at 10:03 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    I guess that I am used to shocks that have the coil perch welded on so it seemed a little flimsy in comparison.
  7. Sep 23, 2010 at 7:56 AM
    vegetopia
    vegetopia newbie
    Jamie
    Houston
    08 DCSB TRDOR 4x4 MANUAL
    2008 Toyota Tacoma 4x4 TRD Off Road SR5 Double Cab 6.0L 6MT
    Bilstein is one of, if not the best, shock manufacturers in the world. You can rest assured that they would not have designed it, if it wasn't going to work.
  8. Sep 23, 2010 at 8:02 AM
    JLee
    Jerry
    Grass valley CA
    X2
  9. Sep 24, 2010 at 10:37 PM
    rescuek10
    Andrew
    Charlotte, NC
    04 Tacoma 4x4
    Thanks for the help everybody! I wound up not even having to take anything off, just put my truck up on the lift and used a pry bar to pull the LCA down in order to fit the shock in. I'll try to post a pic tomorrow. Very easy and straightforward install, and the truck rides 1000000000000000000000000x better.
  10. Nov 19, 2010 at 8:46 PM
    keeganfl
    keeganfl Well-Known Member
    Keegan
    Martin County,FL
    2001 SR5 Prerunner,5 inch lift
    offroad fog and lights,pa,rough country suspension kit 2.5 inches,and leveling kit in the front.bilstein 5100,4X 150 watt lights
    the control arm will drop allowing you to remove and install the shock and strut without being a pain in the ass when i did my 5100 billy's. the only problem was reattaching the sway bar we had to use allen keys and a wrench since the bolt would spin
  11. Nov 19, 2010 at 10:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    12 million sets of 5100's says its strong & your good to go !! :D:D
  12. Nov 21, 2010 at 5:41 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  13. Mar 25, 2011 at 1:14 PM
    96greengoblin
    96greengoblin Active Member
    Hayden
    Michigan
    96 Extended Cab 4x4
    Billy's on all 4 corners!
    can i install a set of 4 of these with the stock springs on the front and without an aal in the rear?
  14. Mar 25, 2011 at 8:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Sure, what you can't do is getting the AAL & NOT the 5100's for the rear, the stock shocks are too short to compensate for the lift & also the pass. side rear shock is longer than the drivers side rear shock for 1st gens.
    pretty sure 2nd gens are the same....;)
  15. May 24, 2011 at 10:34 AM
    #35
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    thank you for answering that b/c i was literally about to ask it. and do u know of a good place to order the 5100's all around that comes with a nice new set of polyurethane bushings? everytime i look it doesnt say whether it comes with em and theye kind of a must... :confused:
  16. May 24, 2011 at 4:39 PM
    #36
    keeganfl
    Keegan
    Martin County,FL
    wheelersoffroad
  17. May 24, 2011 at 4:42 PM
    #37
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    and of course.... pics after they are installed!!
    its pretty straight foward. shouldnt take you more than an hour if you run into problems. thats if the coils are already on the shocks
  18. Jul 10, 2011 at 9:51 PM
    #38
    mountainman94
    mountainman94 awwwwww yeeeeeeeeahhhhh
    Cory
    A Place of Higher Learning
    '98 TRD SR5
    5100's/Eibach coils; 2 inch toytech AAL, Black Pacer 15x8 wheels, 32x11.5 BFG AT K/Os
    Pics > No pics. thinking about doing the same here, would like to see how it turns out.
  19. Jul 11, 2011 at 8:55 AM
    #39
    FishinTaco
    FishinTaco Well-Known Member
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    5100's all the way around, OME 880's and AAL, BF's 265/75R16. Switched beds from Stepside to Fleetside
    I'm thinking pretty similar, 5100' in the front with original coils, and add a leaf in the back with 5100's. Would this be good to get my 2002 TRD stepside sitting good? (going to have it done while she's getting a new frame).
  20. Jul 11, 2011 at 11:00 AM
    #40
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    I'm putting my 5100's on this week, I will post pics of mine too :)
