Bilstein 5100 Installation
Discussion in 'Suspension' started by tr0gd0r, Jul 18, 2009.
  1. Jul 18, 2009 at 5:28 PM
    tr0gd0r
    tr0gd0r [OP] Well-Known Member
    Pullman, WA
    2012 Silver Streak TRD Offroad DCSB V6 4x4
    TRD Catback Exhaust - 265/75/16 BFG KM2s
    Anyone know if a Toyota Dealership will install front 5100s? Im afraid they might not because they will be lifting the truck. Anyone tried before?
    What price can I expect to get the front shocks replaced? Will it require an alignment? I really dont feel comfortable using a spring compressor. I did the back by myself.
    I tried talking to a couple of local auto shops and they dont really like installing parts that they didnt provide.
    Thanks for helping.
  2. Jul 18, 2009 at 6:56 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    You are looking at a good 2-3 hrs labor. Dealer should install without any issues. But they will charge an arm & a leg. If they give you any BS, ask why they warranty the Pro Comp 6" lifts.
    My advice is to go for it. Not that hard, trial and error may come into play, but way cheaper than a $300-$400 install fee.
    Oh and here is a great example:
    http://www.tacomaworld.com/forum/suspension/44949-my-5100-installation-experience.html
  3. Jul 18, 2009 at 7:01 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You can totally do it yourself without much output of money...I went to a local Firestone with all the parts (the only real issue is getting the springs and top plates off your truck now- unless you have a second set) and they set up the struts for me...Everything else was just bolts and sweat.
    Yes-If you are lifting you need an alignment.
  4. Jul 18, 2009 at 7:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    dont get the stealership to replace the front 5100's.....i was quoted $300, and they already had some of the front end apart cause they were replacing my lower ball joints in the recall.....so i took the coil assembly off myself and got a shop to swap the shocks out....$40.
  5. Jul 18, 2009 at 7:23 PM
    tr0gd0r
    Pullman, WA
    Does the dealership charge $300 to replace front shocks no matter what, or is it just because they are 5100s? Because that seems awful high considering I was quote like $100 for rears from a local shop.
  6. Jul 18, 2009 at 7:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Rears are a simple bolts out, parts swap, bolts in.
    The fronts require some additional parts to be moved and the building the struts back up. And at the shop labor rate- 300 comes quick....
  7. Jul 19, 2009 at 2:10 AM
    Kenny650
    Kenny650 Well-Known Member
    I got quoted $600 at my local dealer ship for the install of front bilsteins. LMFAO!!
  8. Jul 20, 2009 at 10:48 AM
    tr0gd0r
    Pullman, WA
    I just called the dealership and was quote $144 for install of two front shocks.
    Is it worth it to have them install for that price?
    Looks like most of you were getting prices over $300.
    BTW, the $144 does not include alignment, but Im sure an alignment can be had for under $100.
  9. Jul 20, 2009 at 11:07 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    I got all of my stuff (excluding the parts) done for $89.00+ a $60.00 alignment
    $210 for 5100 and AAL
    and $936.00 for my tires
  10. Jul 20, 2009 at 11:10 AM
    tr0gd0r
    Pullman, WA
    Was this done at a dealership or elsewhere?
  11. Jul 20, 2009 at 11:12 AM
    Lentsnh
    No I did it with 06BLUEDBLSPORT and Lifesaflaw in my garage
    Took us all day... only had 2 "oops" moments
  12. Jul 20, 2009 at 11:12 AM
    Lentsnh
    If you know alot about trucks it shouldnt be a problem
  13. Jul 20, 2009 at 11:14 AM
    tr0gd0r
    Pullman, WA
    Come do it for me, Ill gladly pay $89.
    I did a rear AAL and the Rear shocks myself. Not sure I trust myself with the spring compressor.
    Plus I had instructions for the rear. You got any instructions for the front, maybe its easier than I thought.
  14. Jul 20, 2009 at 11:17 AM
    Lentsnh
    Chris4x4 and PackerfanXD put up a tutorial on how to change out the front struts.
    Follow that and you will be a-ok :thumbsup:
    The spring compressor might sound bad but just make sure you tighten the bolts on the compressor at the same torque and nothing will go bad (knocking on wood)
  15. Jul 20, 2009 at 11:35 AM
    tr0gd0r
    Pullman, WA
    Where would I find this tutorial?
  16. Jul 20, 2009 at 8:09 PM
    Lentsnh
  17. Jul 20, 2009 at 8:27 PM
    tr0gd0r
    Pullman, WA
    I have a first gen truck. Are the steps the same?
  18. Jul 20, 2009 at 8:30 PM
    Lentsnh
    Yeah they should... all suspension components are basically the same... the only thing that might be different is the bolt size, coil size etc
  19. Jul 22, 2009 at 1:10 PM
    BradleyJ33
    BradleyJ33 Geaux Tigers
    Brad
    Brandon, MS
    2010 TRD Sport 4x4 DCSB S/C'd
    TRD Supercharger with URD 2.825" Pulley, Toytec Ultimate Lift, LR UCAs, BFG All Terrain 275/70R17s on Procomp 7089 17" wheels, BAMF rock sliders, Viper 5902 alarm/remote start with smartstart, Pioneer Avic-Z110BT dvd/navi head unit, 2 Pioneer 7" monitors in headrests, 2 Rockford Fosgate Shallow-mount 10" subs pushed by RF Punch 500.2 amp, RF 5.25 components (front doors) and 5.25 full range (back doors) pushed by RF Power 400.4 amp, sound deadened, Whistler pro remote radar detector, scangauge II, debadged, Sockmonkey decals, blacked headlights with FX-R projectors, DDM Tuning HID fogs, Grillcraft upper and lower MX grill with Hella 500ffs converted to HIDs behind, AFE Stage 2 Cold Air Intake, Walbro 255 Fuel Pump upgrade, Dynomax Super Turbo muffler, Bestop Supertop, Wet Okole seat covers, Weathertech floor liners, Pop & Lock tailgate handle, Lighted 4x4 switch mod, 2 110v AC outlets in cab mod, Always at 400W mod, Maplights on with dome light mod, homelink in headliner mod, foglight
    This might be a dumb question, but if I wanna use 5100s all around to get a 2.5" lift, do I need to replace anything else (springs, etc.), or just all 4 shocks? Thanks!
  20. Jul 22, 2009 at 2:30 PM
    Lentsnh
    the front 5100 are adjustable.
    Notches:
    1st- 0"
    2nd-.85"
    3rd- 1.65"
    4th- 2.25
    Or somewhere close to those measurements
    if you want 2.5" in the rear your going to have to get AAL and maybe a 1" block
