Bilstein 5100 lift
Discussion in 'Suspension' started by AZtacoma07, Jan 24, 2011.
  1. Jan 24, 2011 at 11:13 AM
    AZtacoma07
    AZtacoma07 [OP] Member
    Mesa, AZ
    K&N, Coverking seat covers, Magnaflow, pop n lock,AT tires, Suspension TSB,Undercover tonneau cover,
    I know this has been hashed over and over but I have decided to get the 5100 shocks and put them on my 2007 Sport doublecab. I would rather do this myself than pay someone....so I clicked on the link and all the photos on the how to install are not available....I searched and googled for photo install help. Can anyone provide a link to where I could get install help/photos on the bilstein 5100 front and rear install? I am just worried about the spring compressor part...
    Thanks everyone
  2. Jan 24, 2011 at 11:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The rear shocks are easy....IIRC, theres a thread on it on here. As for the fronts, you can always have someone compress the springs for ya, then just put them on the truck.
  3. Jan 24, 2011 at 11:48 AM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I have put on and taken off 5100's many times now, so I've gotten to the point where I could do it blindfolded.
    At first, I was really sweating the issue of compressing the coils, so the first time I put the 5100's on I had Midas compress the coils and switch over to the new set of struts for me -- they charged $50 to do it.
    Last time I compressed the coils on my own to change the lift height setting .. I borrowed coil compressors from O'Reilly auto parts for free and was surprised at how easy it was and how well they worked. Just make sure you have a good bench vise and a wrench with a long handle, and lube the threads of the compressors. It was a piece of cake.
    I'm not sure which threads to dig up, but I would suggest NOT doing the methods that involve undoing the LCA or tierods. All you need to undo are the UCA-to-spindle balljoint by tapping the spindle with a hammer, remove the sway bar, and take the struts out. Basically the goal is to do the bare minimum of linkage disassembly to get the struts to come out. It also helped to have the Chilton manual on hand, opened up to the suspension chapter.
  4. Jan 24, 2011 at 11:50 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
  5. Jan 24, 2011 at 11:52 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Jan 24, 2011 at 11:54 AM
    krimson
    krimson Nothin
    TRD Off Road
    True, but he didn't say he clicked the links at the bottom.
  7. Jan 25, 2011 at 10:32 PM
    AZtacoma07
    Mesa, AZ
    Thanks fellas. I am thinking of taking the shocks into a shop or finding a place that rents the compressor free.
    One more question...I have had the rear TSB AAL done a while back. Right now the rear sits exactly 2 inches higher than the front...If I add the 5100's up front at 2.5, is it possible to add an additional leaf in the rear, or would I be looking at a 1.5 block or something to keep the back slightly higher? Thanks for the help.
  8. Jan 25, 2011 at 10:37 PM
    BenWA
    Boston burbs
    You can buy an AAL that fits with your TSB leafs that will give you around 1.5" of lift. I just ordered a set from wheelers offroad, in fact. I ordered the 3 leaf progressive AAL -- supposedly you can omit one of the leafs for less lift if you desire.
  9. Feb 2, 2011 at 9:33 AM
    AZtacoma07
    Mesa, AZ
    The 5100's will be here tomorrow...install this weekend...can't wait. I got the 5100 for the front and a 1.5 AAL (to add to the TSB that is already done). Will post before and after pics.
  10. Feb 2, 2011 at 10:00 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    One thing to be careful of is not to stretch the ABS sensor wire. I stretched one of mine too far and the ABS light came on afterward.
  11. Feb 5, 2011 at 2:13 PM
    AZtacoma07
    Mesa, AZ
    Ok. got the 5100's installed. I have a problem with the passenger side shock. I went to a parking lot and went over some speed bumps and heard a clank noise. I looked and the shock is not compressed. At the top of the shock where the bushing, washer and nut are, there is about 1/2 inch between the bushing and the top plate of the shock? So when I hit the bump, the shock didn't compress, it just banged the top of my wheel well....anyone have any idea on where I screwed up?
  12. Feb 5, 2011 at 5:14 PM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    Double check the top of the shock. Are all the bushings, washers where they are supposed to be? Did you remember to put the stock "cushion" washer back on before you slid the shock back up into the shock plate?
    just rhetorical questions, just double check that area.
    BTW, I have the same setup. 4x Bilstien's , Toytec 1.5" non-TSB AAL. Set at 2.5" in front.
