Bilstein 5100 question
Discussion in 'Suspension' started by stanman9, Feb 12, 2009.
  1. Feb 12, 2009 at 5:19 AM
    stanman9
    stanman9 [OP] Well-Known Member
    Toytec co's and aal, tc uca's
    I already have the Toytec 3" lift, and want another 1" of clearance. Will 5100's all around set at 1-1.5 give me any more lift???
  2. Feb 12, 2009 at 5:46 AM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    I'm assuming you have the OME coils? if so you shouldn't adjust your shocks for more lift you should use them set at the lowest setting.
  3. Feb 12, 2009 at 5:52 AM
    stanman9
    i have stock coils and shocks, spacers up front and AAL in the rear.
  4. Feb 12, 2009 at 6:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What you are wanting to do wont work. If you want more that 3" lift, you have a couple of choices. You can get a drop bracket lift, like a Fabtec, Pro Comp, or whatever, or you can add a 1" body lift to your truck. Stacking lifts, which is what you are considering, never works, and leads to breakage of other components.
  5. Feb 12, 2009 at 6:20 AM
    stanman9
    i didn't think it would, because I hadn't seen anyone on here with it. I Just want more lift!!!!!! without going all out for the 6"
  6. Feb 12, 2009 at 6:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, many people want alot more money but dont want to work. If you want more lift, only one way to get it.
  7. Feb 12, 2009 at 8:13 AM
    Snyperx
    Snyperx Seniore Marcos
    x2 Big no no!
