Bilstein 5100 review
Discussion in 'Suspension' started by PATTRD2011, Oct 26, 2012.
  1. Nov 23, 2012 at 3:40 PM
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    Ya see your lucky with the free shipping, that's what usually ruins it for us up in the north cause we get killed with shipping... Essex is a good choice for us in Canada but the 299.99 from DSM is a sweet deal..... But I have found a local guy near me CT Motorsports that deals with toytec and he beat DSM when u including shipping and me getting hit with duties and taxes he beat them by $10.00 which isn't much but shipping them here I don't know how to figure the exact duties ill get hit with so.. CT works out better unless something changes
  2. Nov 23, 2012 at 3:42 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    What's your setup?
  3. Nov 23, 2012 at 4:41 PM
    Kolunatic
    Kolunatic dont tread on me!
    Texas
    07 DC
    sucks about all the ''duties'',i call it pocket lining. at least ya found a place.
  4. Jul 19, 2014 at 11:45 AM
    xenadogs
    xenadogs Active Member
    LA / OC
    2011 Sport DC MGM
    Debaged, Matching Tonneau cover, Grill Craft, Seat covers
    I desperately need new shocks for my Taco sport. I need to keep my truck at stock height for work, will 5100's work on stock height?
  5. Jul 19, 2014 at 12:08 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Ya they will sit same as stock if u leave the ring at the bottom
  6. Jul 19, 2014 at 12:12 PM
    xenadogs
    LA / OC
    2011 Sport DC MGM
    Thanks Bro! Curious to see what the ride will be like. Now it's pretty bumpy with the worn out OEM's.
  7. Jul 19, 2014 at 12:13 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Better then brand new factory man
  8. Apr 4, 2016 at 1:21 AM
    zert808
    zert808 Well-Known Member
    D
    Mililani, HI
    2015 White Tacoma OR
    Did all of put bilsteins front and back?
  9. Apr 6, 2016 at 5:44 AM
    PUBCRAWL
    PUBCRAWL MIGHTY TACO
    Ontario, Canada
    Tacoma TRD DCLB
    I did.
    Way, way, way better than stock. Mine are a year old now and I'm very pleased with them.
  10. Apr 6, 2016 at 10:21 PM
    bergey
    bergey Member
    '13 Tacoma TRD Sport [Pyrite Mica]
    Kelly Safari TSR [P265/65/R17] Bilstein 5100
    Im pretty new to leveling a tacoma, i've read nothing but good reviews on the 5100 series shocks. If i replaced my front shocks with the 5100's at 1.75", would that level the trucks out nicely? Or is there a rear AAL or 5100 set required to give it a better look? I dont haul anything heavy, the truck is just a daily driver and brings my kayaks to the lake.
  11. Oct 5, 2016 at 5:25 PM
    nedwards0421
    nedwards0421 Member
    2012 DCLB TRD Sport
    I'm thinking of doing the same set up. Are you running stock uca's?
  12. Oct 6, 2016 at 10:58 AM
    Vulcan
    Vulcan Member
    Arizona
    2002 Toyota Tacoma Prerunner TRD Crew Cab
    Airbox (deck plate) mod, Air-Raid intake, Gibson cat-back exhaust
    I just finished a big project on my 02 Prerunner Crew Cab. Having dealt with the axle wrap issue for years I decided to do something about it. I did the helper spring for a bit and the problem was solved but knew this was only a short term fix and did this until I could decide what I ultimately wanted to do. I decided to take a slightly less expensive route and opted for the Wheelers 3 leaf AAL pack. I removed the overload spring on the stock leaf pack and installed. The result was a 2" lift in the back (Wheelers claims 1.5" with this kit). My front struts were crappy after market assemblies and replaced those with Bilstein 5100's (from Wheelers and used stock springs) set on the middle setting. I replaced the back shocks with Rough Country N2.0's (also from Wheelers).
    The truck now sits level with a measurement of 38" from the top center of each wheel well and the ride is definitely better. On regular roads I find myself exceeding the speed limit as it's more smooth and dirt roads are much, much better.
  13. Aug 29, 2017 at 12:05 AM
    Bryguy9
    Bryguy9 New Member
    Taco-ma
    I just bought a 2002 4wd SR5 Tacoma. I wanna change worn out stock shocks and put on 5100 bilsteins. I want a little lift but don't want to destroy ride quality. What's a good lift height and will these shocks destroy ride quality. I will be doing no off-roading. And will I be fine using stock coils?! HELP
    Brigadesdado likes this.
  14. Aug 31, 2017 at 6:20 AM
    Brigadesdado
    Brigadesdado Member
    Kevin
    2015 Black Tacoma TRD
    Max Shoes on stock suspension
    Has anyone tried this 5100's on all 4 with one setting up from stock paired with firestone ride rites & stock leaf springs???
    I'm looking into this .. I do like the factory rake .. I get a tiny bit of rubbing with 265/75 R16 BF KM2's would like to take away the rubbing and have a nice ride on a regular day .. and pump up the bags when towing ..
  15. Sep 6, 2017 at 12:17 AM
    #35
    Bryguy9
    Bryguy9 New Member
    Taco-ma
    Does it ride bumpy ?! I wanna do this to mine but I want a smooth factory ride
