bilstein 5100"s and stock prerunner suspension???
Discussion in 'Suspension' started by tacomaman06, Aug 21, 2007.
  1. Aug 30, 2007 at 4:56 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Sounds awesome! Hey, maybe for the Carolina Meet we should skip the whole off-roading thing and just get drunk at your lake house and cook out
  2. Aug 30, 2007 at 1:59 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man, we are still having the meet(sometime......i guarantee it!!), but we can do the lakehouse thing anytime..........and i'll be there fishing and getting sloshed;)!!
  3. Aug 30, 2007 at 5:06 PM
    nd
    Nate
    Greenville, SC
    I don't fish but i sure as hell drink :)
  4. May 4, 2008 at 9:23 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    When it's time to replace the 5100's are great. And at that time you will have everything settled out and know if you want any lift in the front or not?
  5. May 5, 2008 at 12:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats what i was thinking, but now im thinking of getting a 3 inch toytec lift, so we'll see if i decide to go with the 5100's afterall.
  6. May 6, 2008 at 5:05 PM
    xrico
    xrico Member
    Texas
    2005 Tacoma prerunner SR5
    None
    Does anyone know approximately how much the labour cost would come to for installing new leaf springs and four shocks for a tocoma. :)
  7. May 6, 2008 at 9:48 PM
    joedart
    joedart Active Member
    socal
    08 prerunner sr5
    i got an invoice right here. the local 4 wheel parts performance center wanted $568.00 for labor to install four 5100's, an add-a-leaf in the rear, and an alignment...... they ain't gettin' my money!
  8. May 7, 2008 at 12:37 AM
    xrico
    xrico Member
    Texas
    None
    Althogh my warranty ended in November 2007, the dealer here agreed to the suspension TSB but I had to pay $80. So they will replace the leafs and the four shocks. I think its a good deal since my warranty ended 7 months ago.
  9. May 7, 2008 at 6:06 AM
    Khaos
    Khaos Big Member
    Bryant
    Tallahassee FL
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    :eek:
    Exactly why I will be installing them myself. Thats double what it originally would cost to buy the 5100s.
  10. May 7, 2008 at 9:53 PM
    xrico
    xrico Member
    Texas
    None
    Can I level my truck by just adding the 5100's up front.
  11. May 8, 2008 at 4:46 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  12. May 10, 2008 at 12:56 AM
    xrico
    xrico Member
    Texas
    None
    "recommended NOT to lift more than 3 because it will likely cause premature wear and stress to your CV boots and ball joints. If you're looking for more lift in the front, consider a drop-down setup or a solid axle swap"
    Does the above statment apply to a 2WD or only a 4WD. Can you get a drop down for a 2WD?
    Thanks
  13. May 10, 2008 at 8:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If you are refering to a Pre Runner, then, yes. You can get a drop bracket lift. Also, you can get 4" lift spindles. There are no Cv boots, or shafts on a Prerunner, so lifting is a piece of cake. If you are wanting to know about the 5 lug pick up, then Im not sure. :)
  14. May 10, 2008 at 10:01 AM
    xrico
    xrico Member
    Texas
    None
    Trying to find the best way to level the truck (3" front lift), would 5100's and and a 1" diff drop, be the best way to go for my 2005 D-Cab Prerunner. Any ideas? and what about Steel 3" Strut Spacer would they effect the suspension geometry.
  15. May 10, 2008 at 10:04 AM
    #35
    xrico
    xrico Member
    Texas
    None
    "If you have a PreRunner then you have no CV's and a diff drop is not necessary."
    Does this mean I only need a spacer or 5100's for my prerunner.
  16. May 10, 2008 at 10:19 AM
    #36
    rick
    rick `
    +1. put them on the 2nd or 3rd notch.
  17. May 10, 2008 at 2:42 PM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You do not need a diff drop as you are not a 4x4. Yes, a lift would affect your suspension geometry. You will loose caster. Total Chaos, Camburg, and I think Icon make UCA's that return your caster to near factory. :) Also, 5100 adjustable shocks are no different than adding preload spacers to your current strut assembly. The only advantage is you get better shocks. :)
  18. May 10, 2008 at 3:25 PM
    #38
    Ridingontrd
    Richard
    Laughlin,N.V
    Keep reading. T/C is the way to go. :D
  19. May 10, 2008 at 10:32 PM
    #39
    xrico
    xrico Member
    Texas
    None
    What are the UCA's?
  20. May 10, 2008 at 10:38 PM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Upper Control Arms
