bilstein 5100 with 3"spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by achirdo, Jun 6, 2010.
  1. Jun 6, 2010 at 8:29 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i already have the 3"suspension spacers in the front and 2" blocks in the rear, i was wondering if it was possible to put the bilstein 5100 shocks on it to, too give it another 2.5" of lift, or can i not do that for some odd reason?
  2. Jun 6, 2010 at 8:32 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I don't know much about anything, but that sounds like a bad idea.
  3. Jun 6, 2010 at 8:32 PM
    achirdo
    Adam
    North DFW
    why?
  4. Jun 6, 2010 at 8:39 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Cv's
    Joints
    Ride quality
    UCA's
  5. Jun 6, 2010 at 8:43 PM
    05TacomaCO
    05TacomaCO T800
    Paul
    Pueblo West, CO
    2010 CM Platinum 4x4
    spacer compresses the spring, the Bilstein 5100 @ 2.5 compresses the spring more. don't do it
  6. Jun 6, 2010 at 8:44 PM
    achirdo
    Adam
    North DFW
    could i get a different spring and have it be fine?
  7. Jun 6, 2010 at 8:45 PM
    boss1041
    boss1041 Well-Known Member
    chad
    valdosta, georgia
    07 dc 6 speed trd or, 95 auto
    i think that would be about the same as havin cinder blocks for tires nothing would be left to absorb shock
  8. Jun 6, 2010 at 8:45 PM
    05TacomaCO
    05TacomaCO T800
    Paul
    Pueblo West, CO
    loose the spacer, get the Bilstein 5100 @ 2.5. or go a different route.
  9. Jun 6, 2010 at 8:49 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Do a body lift if you really want the extra height, but they suck so nevermind.
  10. Jun 6, 2010 at 8:50 PM
    05TacomaCO
    05TacomaCO T800
    Paul
    Pueblo West, CO
    look under suspensions and lifts
  11. Jun 7, 2010 at 5:43 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Stacking a spacer lift on the billy's @2.5 will give you basically no down travel on the shocks. you will top them out and damage them easily.
  12. Jun 7, 2010 at 4:14 PM
    jaylab98
    jaylab98 Member
    New Hampshire
    The spacer lift i have puts the spacer above the bearing plate so it does not compress the spring. would this set-up with the 5100 be safe?? Not planning it yet but to leave my options open for later. Thanks for all your help and I've got say ditching the diesel F250 and down scalling to a 2010 DC was great, I love this litle truck.
  13. Jun 7, 2010 at 4:17 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    no you cant you will fuck your ball joints
  14. Jun 7, 2010 at 4:18 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    you won't be able to do it... since the bilsteins have about 4" of travel up and down... the stacked lift will be at 5.5" which is not physically possible with only 4" inches of travel up or down.
    but that is the least of your problems...
    just get spindles if you want that much lift... or a pos body lift
  15. Jun 7, 2010 at 7:10 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
  16. Jun 7, 2010 at 7:17 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Don't ghetto rig your truck...shit breaks that way...just do it once and correct! I wish I woulda been a member before I bought my Front 3" spacer. I gotta AAL in the rear so i'm good there. Just Get the Camburg 4" Spindles...Its the best quality of lift you can get from what I've heard...plus it uses all factory components like UCAs etc...
  17. Jun 7, 2010 at 8:01 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    how this is even asked is amazing to me. just look at your suspension and if u have any idea how it works u will understand it cant be done. u can not leave your lower controle arms in factory location and just stack lifts together. do u know what the angle of your upper and lower contole arms would be and your cv joints and your rack and pinion? there is a reason that for more then 3" of lift there are drop bracket lifts like procomp and fabtech. it is because it is necessary to keep your geometry inline. not just cause it sounds like a good idea.
  18. Jun 8, 2010 at 2:02 AM
    ColtsTRD
    Scott
    AZ
    He's new and NO... He probably doesn't understand and thats why he asked! No need to scold him! He asked, we answered and now he knows :cool:
    We're here to help not judge!
