Bilstein 5100 with OME 885's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lo_cash78, Aug 20, 2017.
  1. Aug 20, 2017 at 1:25 PM
    lo_cash78
    lo_cash78 [OP] Well-Known Member
    Luke
    Colorado high country
    2007 DCLB TRD Sport
    Anybody running Bilstein 5100 with OME 885's? Any issues or alignment problems? What size tires can I use without tires rubbing? Thanks!
  2. Aug 20, 2017 at 1:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    lo_cash78[OP] likes this.
  3. Aug 20, 2017 at 2:17 PM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2021 Tacoma TRD Off Road
    That's what i am running. Aligns fine with stock UCA's. 275's no rubbing, had to remove small flaps up front though. I am just about done with my 275s and gonna try a 285 next.
    MattCowsmasher and lo_cash78[OP] like this.
  4. Aug 20, 2017 at 2:19 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
  5. Aug 20, 2017 at 2:28 PM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    Wish I had gone with 886
  6. Sep 7, 2018 at 1:58 PM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    What are you running in the rear? Thanks!
  7. Sep 9, 2018 at 9:39 AM
    PahalaTacoma
    Tucson, AZ
    Bilstein 5100 w/ Toytec 1.5 AAL
    Voltron4x4[QUOTED] likes this.
  8. Sep 12, 2018 at 7:00 PM
    Pyritemica15
    Pyritemica15 Well-Known Member
    Norm
    2015 Pyrite Mica Tacoma double cab
    Bilstein 5100 W/885's and deavers 1.5 AAL HS taco lean spacer,265/75/16 BFG's,aligns fine no rubbing or UCA issues,i took front small flaps off, think could go larger tire without issues on mine
    Voltron4x4 likes this.
  9. Sep 12, 2018 at 7:26 PM
    Voltron4x4
    Denver, Colorado
    This and that...
    Did you give any consideration on installing the ECGS bushing. Looking to do the same setup. Yours looks great.
  10. Sep 14, 2018 at 5:33 AM
    Pyritemica15
    Norm
    Thanks,No on the EGCS bushing, truck only has 23k miles on it and have had no issues at this time, will address it if i have to though, i have some of the relocation kits for truck but found that i didn't need them, when i brought it to alignment shop they said truck was barley out of align so i take that as a good set up for the Tacoma
  11. Sep 14, 2018 at 6:00 AM
    Voltron4x4
    Denver, Colorado
    This and that...
    Sounds good. Being on this site for awhile definitely helps, but also can inflate the concerns when lifting. Thanks.
  12. Sep 14, 2018 at 6:15 AM
    Pyritemica15
    Norm
    yea i think for the money the Bilstein set up is hard to beat, and yes this site can scare one out of these lifts but if you take your time and don't beat the lift into place it will serve you right
  13. Sep 14, 2018 at 6:21 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    That's what I'm running on my prerunner, do I will say I have now realized it would have been betterthou probably to do the 884 which I believe gives about 2.5 and then use maybe like a half inch v spacer, the reason I say this is that the shock doesn't really have much distance to they can travel down before it tops out which is kind of dumb.
    so I'm thinking if I shorten the spring but moved the whole assembly down that'll give it just slightly more downward travel.
  14. Sep 14, 2018 at 9:19 AM
    TRD2010SpeedwayBlue
    Brandon
    ugh i need to install my lift still. 2 years and counting sitting in the fkn box...........
  15. Sep 14, 2018 at 9:36 AM
    Voltron4x4
    Denver, Colorado
    This and that...
  16. Sep 14, 2018 at 9:37 AM
    Voltron4x4
    Denver, Colorado
    This and that...
    Working on pulling the trigger this month. Will be installing with a friend. Hopefully can fit it into our schedules...
  17. Sep 14, 2018 at 10:06 AM
    Pyritemica15
    Norm
    ouch,my lift was in the garage for a couple months before i installed it, i took me all day taking my time on my own, with someone else helping it def would have speed up the process but it wasn't all that bad on an install
  18. Sep 14, 2018 at 10:11 AM
    TRD2010SpeedwayBlue
    Brandon
    yeah pretty sure i have an idea what alignment specs should be i think
    this is basically what i have gathred
    0° toe
    0° camber
    2.5°ish caster
  19. Sep 14, 2018 at 11:20 AM
    Pigpen
    Northwest Montana
    After some time, I'm happy with my 885s. I think I would've been happy with 886 too though. The 885s just needed some top plate spacers to get me the lift I wanted. I do really like the way they ride paired with 5100s. I would like to compare with OME shocks though.
  20. Sep 14, 2018 at 5:14 PM
    nighthawk6
    nighthawk6 Member
    07 TRD Crew SB
    How do the 5100s compare to the 6112s
    greasegunner likes this.
