Bilstein 5100s at 1.75!
Discussion in 'Suspension' started by Jareds Toyota, Sep 27, 2011.
  1. Feb 9, 2018 at 7:29 AM
    #261
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    Every truck is different. The factory leafs on all Tacoma’s are weak and eventually will sag. The TRD sport came with the 4 leaf pack stock. All or most off roads came with the 3 leaf pack. All the tsb leafs are 4 pack. Neither is more superior. A few of my buddies got the tsb because their factory leafs were sagging. Initially, they thought the tsb fixed the saggy stock leafs. After only a few months they started to sag just like the stock leafs. Just search the forum for stock leafs or tsb leafs. I’ve owned 3 Tacoma’s and on each one the leafs have sagged. I don’t haul much and only tow a mowing trailer. Wheeling will also stress the leafs more than regular daily driving. I can’t really tell you when they will sag because of all the different variables. If you want to lift it 1.75 in the front I would at least put a 1.5 aal in the rear. Doesn’t really matter what company you go with. I’ve had good luck with Wheelers Offroad.
  2. Feb 9, 2018 at 7:34 AM
    #262
    Czeleznick
    Czeleznick Well-Known Member
    Philadelphia Area
    2022 White OR DCSB
    Eibach Pro Stage 1, Bronze SCS F5’s on Falken Wildpeaks
    Thanks man, ill take a look.
    Would something like this suffice?
  3. Feb 9, 2018 at 7:51 AM
    #263
    poseytaco
    Nicholas
    Indiana
    2012 Off-road
    :thumbsup:
  4. Feb 9, 2018 at 10:17 PM
    #264
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    1.75 made mine too close to nose high for me. I added bags and it bumped it up an inch, riding at 15lbs.
    Anyway, I should have done .85, or whatever the next lowest setting is. Thing rides like a damn dump truck with all the preload. I actually just purchased some of the clearance TRD pro suspension setups, so I'll be selling my 5100's if you want to hold off, lol.
  5. Feb 12, 2018 at 4:41 PM
    #265
    kwhitley762002
    kwhitley762002 Member
    2013 Tacoma TRD Sport
    Just wondering, but where did you find the TRD pro suspension?
  6. Feb 13, 2018 at 7:24 AM
    #266
    Zacowacko
    Zack
    SW, OK
    https://www.tacomaworld.com/threads...-pro-kit-upgrade.530072/page-55#post-17130742
    Check out that thread. Conicelli and Oempartsworld . I ordered one from each, fearing i would miss out, and both are back ordered. Guys on there saying there is like 100 something left, so i didnt want to take a chance. I'll either end up with 2 sets or none when they cancel them, lol. Cant live with the 5100's eatin my tires. Probably wouldnt have the issue if i didnt have the extra weight. Who knows, maybe i have the same issue with the Pro setup, but others seem to think it will work out better, heavier spring/shock and all.
    If i end up with 2 i'll just sell them for what i got in em.
  7. Feb 22, 2018 at 11:26 AM
    #267
    tacoczar
    tacoczar Member
    Brian
    Big Sky Country
    2007 Radiant Red TRD Off-Road Access Cab
    No mods
    So.... I just installed 5100s all around. On the first install I set the fronts to the second setting. According to Bilstein this would lift my front about 7/8" - perfect for leveling. However, I got about 2". On the second install I lowered the setting to the first setting which should have been a factory stock ride height. But it now sits about an 1-1.25" higher than the rear. Did I miss something? BTW, the rear springs are stock packs which were replaced this past October via the Toyota recall and the front springs are the stock originals. Thanks for any advice you can offer.
  8. Feb 22, 2018 at 11:44 AM
    #268
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    Make sure the strut perch is not upside down.
  9. Feb 22, 2018 at 12:45 PM
    #269
    tacoczar
    tacoczar Member
    Brian
    Big Sky Country
    No mods
    Perch appears to be as factory installed. For reference, approx ground to wheel well measurements are: 37" front / 35" rear. Also, the rear also appears a bit higher than stock. Is that standard for the 5100s?
  10. Feb 23, 2018 at 6:57 AM
    #270
    Czeleznick
    Philadelphia Area
    2022 White OR DCSB
    Mine is probably different since i have a 3rd gen and also my 5100s were 3rd gen but when i installed just the 5100's in the rear it gave me ~.70" of lift.
    I also chose the 4th setting on my 5100s in the front hoping for a 1.55" lift and i am got just a hair over 2" of lift in the front on my stock coils.
  11. Feb 23, 2018 at 7:14 AM
    #271
    Zacowacko
    Zack
    SW, OK
    2nd Gen. I set mine at 1.75" and got over that. Cant remember how much.
  12. Feb 26, 2018 at 2:37 PM
    #272
    Drunkdad
    Drunkdad Active Member
    Salt Lake City
    2016 Tacoma SR 4X4
    What do you mean when you say "eating my tires"? just ordered 5100...
  13. Feb 26, 2018 at 2:53 PM
    #273
    Zacowacko
    Zack
    SW, OK
    Its more do to the extra 120lbs i have up front. Should be fine stock.
  14. Mar 3, 2018 at 12:49 AM
    #274
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    So 5100s all around with TSB springs and a toytec AAL I’d have to set the shocks at 2.5” for the truck to be level? I’d imagine the ride would be pretty rough with this setup?
  15. Mar 3, 2018 at 11:44 AM
    #275
    Zacowacko
    Zack
    SW, OK
    It'll ride like a damn dump truck. :bikewhoops:
    Some people are fine with it though.
    Get yourself some ome springs from Mary at headstrong if you want to go that high and have a pleasant ride. And be prepared for possible uca.
    I'm changing mine out. Don't even like 1.75 on mine, but that may have something to do with my extra weight up front.
  16. Mar 3, 2018 at 12:34 PM
    #276
    NBourque
    Nick
    Maine
    ‘21 PRO
    Haha thanks for the info. I’m thinking of going just 5100s on TSB leafs set at 1.75”. What do you think?
  17. Mar 5, 2018 at 5:21 AM
    #277
    Zacowacko
    Zack
    SW, OK
    Probably fine if you like a stiff ride. If not, get you some ome springs to go with.
  18. Apr 10, 2018 at 8:46 AM
    #278
    dvmpete
    dvmpete New Member
    New to the site. Have just bought first Tacoma...2017 TRD Off road. I've been reading about lifts/leveling. My question is why does Toytec recommend the front Diff drop kit on 4x4 models with their complete lift kits, but I have not read any mention of this for kits using the 5100's? Will 5100s without diff drop create problems down the road?
  19. Apr 11, 2018 at 2:11 PM
    #279
    Zacowacko
    Zack
    SW, OK
    No. Not on my second gen it didnt. How big a lift are you talking about? 5100's are minimal.
  20. May 14, 2018 at 9:13 AM
    #280
    Mxmili
    Mxmili Well-Known Member
    Max
    Philadelphia
    2011 base 4x4 2.7l
    Bilstein 5100s at 0 Ome 883
    love it!
    lynyrd3[QUOTED] likes this.
