Bilstein 5100s at 1.75!
Discussion in 'Suspension' started by Jareds Toyota, Sep 27, 2011.
  1. Jan 16, 2014 at 11:07 AM
    #141
    Zilla
    Zilla Well-Known Member
    snah
    los osos ca
    Red Tacoma SR5 4X4 6speed
    thanks guy.. right now i have it at .85 thinking about going higher to 1.75
  2. Jan 16, 2014 at 10:20 PM
    #142
    Zilla
    snah
    los osos ca
    So with the front shocks set at .85 or 1inch. what size tires do you guy recommend ????
    would 1.5 add a leaf work we'll with that set up
  3. Jan 17, 2014 at 4:41 PM
    #143
    Jareds Toyota
    Jareds Toyota [OP] Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    You should go 265/70/17 or 265/75/16 depending on your wheel size. That's a 31.6 inch tire. I personally wouldn't get an aal with the .85 setting
  4. Jan 18, 2014 at 10:17 AM
    #144
    Zilla
    snah
    los osos ca
    Cool
    For the future if i do go to 1.75 an add a leaf would help
  5. Jan 26, 2014 at 12:08 AM
    #145
    MCM78LC
    MCM78LC Well-Known Member
    Saint Paul, MN
    2021 Toyota Land Cruiser
  6. Jan 28, 2014 at 10:35 AM
    #146
    GeauxLSU
    GeauxLSU Member
    New Orleans
    13 PreRunner V6 SR5
    Need some advice -
    On my '13 DCSB, I'm about to install Bilstein 5100's all the way around, plus a 1.5" Toytec AAL for the rear (my truck came with the 4 leaf TSB set-up on it). Should I set the front Bilstein's to 1.75 or 2.50? I'm good with the truck sitting level, but I want to avoid any scenarios of sitting nose high (don't care for the bro lean look). I'm even ok if I end up maintaining the factory rake, with the front sitting slightly lower than the rear.
    What do you guys think, 1.75 or 2.50??
  7. Jan 28, 2014 at 4:54 PM
    #147
    sevkev
    sevkev Member
    north california
    DCLB SR5
    5100s at 1.75" on stock coils and Wheeler's progressive 1.5". RCI metalworks IFS skid. Cooper ATP 265/75/16
    I just put 5100's on all four corners, fronts at 1.75 (on stock SR5 coils) and a Wheelers 1.5 in the back (removed the overload) and this is how it turned out:
    sorry not the best pic. There is a bit of rake, the ride is way better than stock. Hope that helps.
  8. Jan 29, 2014 at 8:37 AM
    #148
    GeauxLSU
    GeauxLSU Member
    New Orleans
    13 PreRunner V6 SR5
    Thanks Sevkev. That definitely helps. It's good to see another rig with the setup I'm looking to go for to give some perspective. Few questions for you if you don't mind:
    1. What size wheels / tires are you running in that pic? Once the lift is done, my plan is to keep stock wheels, but upgrade to some 265/75/R16 BFG A/T's.
    2. What was the reasoning behind removing the overload leaf? The AAL I'm looking at from Toytec states that it will work with the TSB overload leaf, so I was planning on leaving it in. Just curious if I'm setting myself up for problems.
    3. Ever have any regrets not putting the fronts to the 2.50 setting? After looking at your set-up I'm leaning more and more towards the 1.75 setting. I like the way that looks.
    Nice looking truck, by the way!
  9. Jan 29, 2014 at 9:41 AM
    #149
    sevkev
    sevkev Member
    north california
    DCLB SR5
    1. Stock 16" wheels with Cooper ATP 265/76.
    2. I think my truck (2013) came with the 3 leaf+overload from the factory. No TSB has been performed. After some correspondences with Wheeler's regarding the ability of the 5100's to accommodate anything more than the 0-2" lift range, I decided that keeping the rear lift to less than 2" would be a good idea. Wheeler's said that going over 2" would be pushing it with the 0-2" 5100s. After reading tons of threads on here it looks like some folks leave the overload in without any apparent issues. My primary goal was to improve the ride quality and accommodate loads, not necessarily going for a lift for clearance or aesthetics. I'm going to keep track of the height of the rear, and if over time it starts to sag, I might put the overload back in.
    3. I've only had the setup for a week, so I can't find anything wrong with the 1.75 setting. I really didn't want to open a can of worms with putting it to 2.5 and potentially needing UCA/LCA or compromising the longevity of other components. that might not be as much of an issue with a prerunner though.
  10. Jan 29, 2014 at 7:21 PM
    #150
    Fltac0
    Fltac0 Active Member
    Jay
    Central Florida
    04 Prerunner Sr5
    Real Tree AP cover king seat covers, Kenwood head unit, took off the beauty rings and mud flaps
    after lots of help from everyone, and a few of the guys tellin me that with only 53,000 on my truck i decided to hold of on the bilstiens and just do the 2" leveling kit. new rims and tires set me back for a lil while. but heres how she sits nowIMGP0011.jpg
  11. Jan 30, 2014 at 7:06 AM
    #151
    bumpkin1
    bumpkin1 Active Member
    I've just been where you are. I just had Billie's put on all the way around, with the 1.75 setting up front and the 1.5 Icon progressive AAL leaf pack in the rear. I also was very nervous about taking the overload out. I still have about .75 of rake, and I just towed with it for the first time this week. I pulled my 600 lb. quad, on a trailer that weighs about 600 lbs., for a total of 1200 lbs. I didn't figure the math on what the actual tongue weight is though. Anyway, the truck didn't squat any more than factory. And the ride was sooooo much better. With the amount of squat that was on the truck, I wouldn't have been on the overload had it been in anyway. I don't ever plan on towing much more than this, but I feel much better now knowing that I can haul my stuff without any issues. I wouldn't sweat the overload. Get the Icon AAL pack, you won't be disappointed. If in the future it starts to bro lean on you, then you can put the overload back in.
    Also, I got much more than 1.75 of lift with the billies at that setting. I'm still at about 2" of lift, after a month. I still think that Bilstein had V6's in mind when they designed the heights for these shocks. I would think that the 4 banger is a little lighter up front, hence more lift.
  12. Mar 5, 2014 at 12:17 AM
    #152
    TacoTacoma96
    TacoTacoma96 The Lone Wanderer
    A.J.
    Cherokee,NC
    '96 Tacoma
    ARB Bumper, Hella 500FFs, OME 881 Coils and Front shocks, OEM style leafsprings with 2in ToyTec Shackles, Bilstein 5125 Rear Shocks, Aero 2525 Muffler, AEM Intake, Talyor Throttle Body Spacer, LCE Header, Bestop Soft Top.
    Gonna bump this thread:D. I have a '08 access cab 2.7 I4. I plan on using the stock coils with the 5100s set at 1.75. I have aftermarket leaf springs but there basically the same as OEM non TSB. I wanna keep the rear a little high and was wondering if I need a 1.5in AAL or a 2in AAL? Sorry in advance if this question has already been answered. Trying to decide before I purchase:).
  13. Mar 5, 2014 at 7:56 AM
    #153
    choppersx
    choppersx ZoMbiE aLeRt
    Frank
    SoCal
    1968 Ford Mustang
    Lifted Bilstein shocks 5100's Front set 1.75, Rear set 1.5 ICON 3 Leaf Progressive add on / Lights-Retrofit with Halos & interior Dome / Tinted windows/AFE PRo Dry Air Filter / Go Rhino Bars / Flowmaster Exhaust 50 series
    He is my Taco
    Installed Billies front set at 1.75 and the back with ICON 3 leaf pack add-on at 1.5 It rides good.
  14. Mar 5, 2014 at 9:41 AM
    #154
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    1.5" aal will level it, 2" aal will give you rake, ~1" higher in rear or so.
    I did the 2" aal, cuz I knew I was going to eventually get the OME springs for 3-3.5" lift up front, which pretty much leveled with the rear. I now want to get the dakar leaf pack, one day
  15. Mar 5, 2014 at 2:22 PM
    #155
    TacoTacoma96
    A.J.
    Cherokee,NC
    '96 Tacoma
    Thanks:thumbsup:. 1.5in AAL it is:cool:.
  16. Mar 5, 2014 at 4:30 PM
    #156
    bumpkin1
    1.5 AAL from Icon, or something similar. You won't have any issues, and you'll end up with .75-1.25 inches of rake.
  17. Mar 5, 2014 at 7:53 PM
    #157
    gospurs21
    gospurs21 Well-Known Member
    Brownsville, Texas
    05 x2 Cab Texas Edition V6 prerunner, TRD
    whats a tsb
  18. Mar 29, 2014 at 2:22 PM
    #158
    mmeist
    mmeist New Member
    CT
    2008 Taco base
    Bilstein 5100's, 265/75/16 Kuhmo Road Ventures, ATX Mojave wheels,
    5100's set at 1.75" with rear TSB and 265/75R16s
    yesmar likes this.
  19. May 24, 2014 at 1:30 PM
    #159
    dhdubey88
    dhdubey88 Well-Known Member
    Dubey
    Roseville, Ca
    09 Prerunner TRD sport
    Flowmaster 40series, debadged tailgate and bedsides, maxtrac spindles with 5100's at 0, OME Dakar leaf pack and OME Sport shocks in rear, pro comp 5001 rims with cooper s/t maxx 285/70/17
    just had my 5100's put on at 1.75 with stock rear with stock 265/65/17. very happy with the turnout
  20. May 27, 2014 at 11:52 AM
    #160
    spieler
    spieler Well-Known Member
    Jonesborough, TN
    13 white DCSB SR5 4x4
    3" Lift kit/265 Duratracs/SCS Stealth 6 matte black wheels, OEM White grille switcheroo, TRD skid derped white, CSjumper drtl map dome parking lights fog light bulbs, Lifetime LED headlights, **Reverse light mod, Foglight anytime Mod, Trimmed mudflaps, Fully Debadged, 3rd brake light cover by well...me, Liquid Innovations black carbon dipped front emblem, G-Tek Fab diamond plate white door sill protectors, SOS Bolt-on Sliders bedlined, MattGecko rear window security bar, Hardwired Radar Detector w/custom sucker mount, Horse Stall Bed Mat, Audiocontrol LC2i with custom mount ACR-1 remote, Custom sub box behind drivers rear seat, Mag light holder behind seat, Center console organizer , Passenger seatbelt flapper fix, Tailgate anti-theft Mod, Bed storage Locks Mod, hygieneboy ghetto gutter grille guard
    The never ending thread.... Have a 13 DCSB SR5 with 4 leaf from factory. I have carried a couple 1000lb loads in the bed and probably sagged my pack as the rear is only 1 inch higher than the front. IM going to do 5100s all the way around with front set at 1.75 on stock springs. Im also going to go with a wheelers 1.5 AAL for the rear. Should I take leave out the stock overload for an even rake?
