Bilstein 5100's installed along with new tires
Discussion in 'Suspension' started by scully, Jan 24, 2010.
  1. Jan 24, 2010 at 12:54 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    That's the exact setup that I want to do with the same billies and tires...looks amazing!
  2. Jan 24, 2010 at 1:43 PM
    rab44
    rab44 Well-Known Member
    pa
    10 toy tacoma
    Put my 5100 & bfg on today also set at 1.75 truck rides nice no vibes at all.
  3. Jan 24, 2010 at 3:15 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Looks good man!
  4. Jan 24, 2010 at 3:19 PM
    TimS
    TimS Well-Known Member
    Tim
    Maine
    2010 DC tacoma/2005 access cab
    Rebuilt with flatbed 5100's, new spring packs
    They hold up fine. However I will change them this week after work. I was always wondering why when set at stock ht, the truck was still an 1" higher than stock. The instructions are a bit vague. Or, the hollow spot between my ears had an echo. At least with this spring compressing session, the spring commpressor will pay for itself.
  5. Jan 24, 2010 at 5:37 PM
    intense
    intense Well-Known Member
    Georgia
    TRD OFF ROAD '07
    ASE Dry, Carbon filter removed, Grillcraft, 5100's. Low Pro Ameriweld box black powder. Tint / Vent Visors. Textured Black skid plate. Husky Liners. Design Seat Covers
    Do the 5100's make the truck ride better ? how much is the cost for 4, my '06 rides rough to me, and how much lift did you get ???
  6. Jan 24, 2010 at 5:38 PM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Your truck looks awesome! I can't wait to get 5100's and Duratrac's on mine :)
  7. Jan 24, 2010 at 6:54 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    The kit you've gone with sounds like what I'm leaning towards. Would you mind commenting on a few questions?
    - What you have in the front of your truck is an adjustable coilover kit (set to 1.75") that includes the Bilstein 5100 front shocks. Is this correct?
    - You had the factory TSB installed which added the fourth leaf to the rear. You also added the Bilstein 5100 rear shocks. Is this correct?
    - The Bilstein 5100 front and rear shocks are an upgrade over the factory OE TRD Off-Road and TRD Sport shocks? Is this right?
    - You did not say anything about a differential drop kit so I thinking is was not necessary with only 1.75" of lift in the front. Is this right?
    - Last question, after the install you did not have any problems getting the alignment back to factory setting. Is this correct?
    Your truck looks great and answering the above questions would sure help me either pull the trigger or avoid a lot of heartache. Thanks in advance.
  8. Jan 24, 2010 at 7:12 PM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Looks great man. Ive got myself the billies just gotta wait till im back in cali. Im going to set mine at 1.75 as well w/ a rear AAL. Then some nitto terra grapplers at 265/70/17's not sure if im going to get my sport rims powder coated black or not yet thats still up in the air.
  9. Jan 24, 2010 at 8:09 PM
    scully
    scully [OP] Well-Known Member
    San Diego, CA
    06 TRD Doublecab
    Rear TSB FJ Cruiser TRD anthracite wheels Bilstein 5100's allround Tint
    saf023, see my resopnse (CAPS below) to your questions. Good luck
    - What you have in the front of your truck is an adjustable coilover kit (set to 1.75") that includes the Bilstein 5100 front shocks. Is this correct? NO COIL OVER KIT, JUST THE BILSTIENS WHICH ARE FRONT ADJUSTABLE AND HAVE 4 SETTINGS. SET MINE ON THE 3RD FOR A 1.75" LIFT
    - You had the factory TSB installed which added the fourth leaf to the rear. You also added the Bilstein 5100 rear shocks. Is this correct? YES, DEALER DID THE TSB. WENT W/ 5100 IN REAR FOR IMPROVED RIDE
    - The Bilstein 5100 front and rear shocks are an upgrade over the factory OE TRD Off-Road and TRD Sport shocks? Is this right? YES AND THE OE ARE NOT FRONT ADJUSTABLE.
    - You did not say anything about a differential drop kit so I thinking is was not necessary with only 1.75" of lift in the front. Is this right? CORRECT, NO NEED FOR FRONT DIFF DROP UNLESS YOU GO GREATER THAN 2.5" OF LIFT
    - Last question, after the install you did not have any problems getting the alignment back to factory setting. Is this correct? NO, BUT AN ALLIGNMENT IS A MUST AFTER THE INSTALL.
  10. Jan 24, 2010 at 9:17 PM
    TheDavid
    TheDavid Member
    David
    Auvurn, WA
    Black TRD off-Foad
    Rear dif breather relocated Kenwood D700A
    any issues with having to trim for the tires to fit?
  11. Jan 24, 2010 at 9:36 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Looks Great! I have the FJ wheels on the way... just need the billys!
  12. Jan 25, 2010 at 2:06 AM
    saf023
    East Coast
    scully, thanks for the very straight forward answers. I VERY MUCH appreciate it.
  13. Jan 25, 2010 at 7:55 AM
    scully
    San Diego, CA
    06 TRD Doublecab
    Tires fit fine and no need to trim. Removed front mud flap as one broke loose while climbing some snow mounds. May reinstall trimmed mud flaps in the summer as again, there is plenty of room with the 265/75'-16's
  14. Jan 25, 2010 at 8:36 AM
    TheDavid
    TheDavid Member
    David
    Auvurn, WA
    Black TRD off-Foad
    GRATE! That sealed it, I am working twards this set up also.
  15. Jan 25, 2010 at 9:34 AM
    #35
    saf023
    East Coast
    scully, I lied, one more question. So if you are just adding the adjustable Bilsteins you are using factory springs. Would the reason for someone to replace the front factory spings be to lift more than 1.75"?
    When you were doing your research, was the reason for trying the Bilsteins without the upgrading the springs cost?
  16. Jan 25, 2010 at 9:56 AM
    #36
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    If you use lift springs it's highly recommended that you NOT set the Bilsteins above 0.85". Most people seem to go with the OME or Eibach springs and the 0.00" factory height setting on the Bilsteins. If you're going that route, it's also highly recommended to get the OME shocks and springs because the valving in the shock damper is specifically designed to go with the OME springs.
  17. Jan 25, 2010 at 7:20 PM
    #37
    scully
    San Diego, CA
    06 TRD Doublecab
    As xodeuce mentioned, it is only recommended to set the bili's at 0.00 if using an aftermarket spring. I considered it, but didn't see any advantages, plus its more $$$. If your looking for more height, set bili's at 2.5", although you have more chances for allignment and vibe issues.
  18. Jan 26, 2010 at 8:54 AM
    #38
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    I just wanted to make sure that you're saying this part circled in red is upside down?
  19. Jan 28, 2010 at 4:06 PM
    #39
    TimS
    Tim
    Maine
    Well, thanks to the photo with the upside down spring perch, I just got done correcting the mistake. I paid someone to put them together when I first got them because I did not have a strong spring compressor. Now I do thanks to craigslist. Mistake fixed. I put at the stock Hieght for now. I want to see how it works with the plow. I just read about the stock setting only for aftermarket lift springs. HMMMMM.
    Thanks for the picture Scully.
  20. Jan 28, 2010 at 6:40 PM
    #40
    scully
    San Diego, CA
    06 TRD Doublecab
    Simon2150, you are correct and thanks for showing it more clearly with the red circle. It's easy to make this mistake and hopefully these pictures will help prevent for those who are looking to install themselves (or have someone else do it).
