Bilstein 5100's set at 2.5?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LocoTaco, Jul 23, 2016.
  1. Jul 23, 2016 at 10:20 PM
    LocoTaco
    LocoTaco [OP] Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    2009 Tacoma Sport access cab, how will Bilstein 5100"s effect the truck if I set them at 2.5"? Will it be nose high, will it eat CV's? Should I set the Bilsteins at another setting?
  2. Jul 23, 2016 at 10:28 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you planning on doing anything to the rear? If not, and you're just wanting to level it out a little, I recommend setting it on the first notch which is 0.85". That number is based off a double cab since it's more popular, so you'll likely get a little more out of it with an access cab. Should be perfect.
  3. Jul 23, 2016 at 10:30 PM
    KILLINTIME
    KILLINTIME Like a Villain
    I done mine at .85 couldn't tell
    What I did, set them at 1.75 liked it a little better. Sits pretty level maybe a tad nose on schedule to have tbs done on the rear so that will Fix that.rides great. Had vibrations and done the ecgs bushing.(easy install) That fixed the vibes. Not keeping this too long will be going to 886 and AAL or dakars.
  4. Jul 23, 2016 at 10:31 PM
    KILLINTIME
    2006 Access cab 4wd with 32k miles rear springs still have an arch. .85 was not perfect on
    Mine.
  5. Jul 23, 2016 at 10:32 PM
    Bishop84
    Bishop84 Well-Known Member
    Max setting rides awful you're compressing the spring to get height, it wont eat the CV but it will likely get the front diff growl unless you upgrade the axle output shaft bearing.
  6. Jul 23, 2016 at 10:33 PM
    Pigpen
    Dan
    Northwest Montana
    I had 5100s set at 1.75 on my Access Cab. Actual lift was right about 2.5" I would strongly recommend not going any higher. 1/4" top plate spacers are fine though.
    KILLINTIME likes this.
  7. Jul 23, 2016 at 10:34 PM
    Pigpen
    Dan
    Northwest Montana
    It will eat the CV if the actual lift is close to 4 inches.
  8. Jul 23, 2016 at 10:36 PM
    Pigpen
    Dan
    Northwest Montana
    I replaced them with 5100s and 885 coils. The 885 coils yield the exact same lift as the stock spring at the 1.75 setting. I added 1/4" spacers to get near 3 inches.
  9. Jul 23, 2016 at 10:39 PM
    Pigpen
    Dan
    Northwest Montana
    I have Dakars with the AAL. It rides nice, but sits high AF. I wish I had taken the second overload leaf out or not added the AAL.
  10. Jul 23, 2016 at 10:45 PM
    KILLINTIME
    Do you have any weight in the rear? I was thinking with a high clearance with spare tire with jerry cans dakars MIGHT be fine. If I don't do all that aal on TSB might be fine. I know for sure I'm
    Getting an arb and winch so 886 on the front will be for sure. Don't really want to buy uca but I guess I will have to.
  11. Jul 23, 2016 at 10:46 PM
    KILLINTIME
    Not like jerry cans add that much weight lol
  12. Jul 23, 2016 at 10:48 PM
    Pigpen
    Dan
    Northwest Montana
    You'll be glad you did the UCA. I sure am.
    I have a fiberglass shell, a sleeping platform, my winch lives back there (with wire rope and extensions) and a bunch of other shit - around 500 pounds, I'm pretty sure.
  13. Jul 23, 2016 at 10:57 PM
    KILLINTIME
    Yeh uca will be nice. I really
    Need them now with my 5100
    Set on 1.75 but I
    Can live with it. Wonders on the highway. if I had dakars I wouldn't put an aal on them. But you Have a good bit more weight than I will I think.
  14. Jul 23, 2016 at 11:07 PM
    Pigpen
    Dan
    Northwest Montana
    Yeah, I went to 255 because of the road wander - that solved it, but the steering was still sporty. I had 265s with offset rims and they were miserable.
