Bilstein 5100's
Discussion in 'Suspension' started by BobSaget916, Oct 13, 2009.
  1. Oct 13, 2009 at 9:05 PM
    BobSaget916
    BobSaget916 [OP] Active Member
    Seth
    Lafayette, LA
    06 Access Cab PreRunner 4-cyl MT
    Volant CAI Magnaflow Cat-Back HID's 6000k bi-xenon Fog Light Kit mod w/6000k HID's Tinted Tail Lights Kicker CVR 10'' Sub in Super Crew Sound Sub Box Alpine MRP-350 Monoblock Amp Pioneer Premier Head Unit JL 6x9's up front 6.5's in the back Tweets up front Mud Flap Delete 5 over 20% Tint in the back, 20% on the front, 35% on the WS EGR In-Channel Wind Guards Coming Soon -Doug Thorley Headers -Color-Matched Front and Rear Bumpers, Overfenders, Mirrors, Door handles, and Grille -Billet Grille or Mesh Grille -Bilstien 5100's front and rear -OME Coilover Springs -Rear Add-a-Leaf -33's after suspension work is done -TRD Skidplate
    Hey, I know there are probably 50 threads dealing with this but I just wanted a few opinions. My truck is stock hight right now...i'm running 265/75/16 BFG Rugged Trails and they fit just fine, no rubbing or anything. I need new tires pretty soon and i want to upgrade to 33's. I know I need to lift it but i'm still questioning which route to go. I want to put the Bilstein 5100's all the way around using the stock springs in the front. I also want to do the 1.5" block in the rear in addition the the Bilsteins. If i crank the front coilovers all the way to 2.5 will that give me a somewhat level ride hight? Will that clear the 33's in the front? If not, what should i do? AAL in the rear? Comments are much appreciated!! THANKS!!
  2. Oct 13, 2009 at 9:11 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    you will still have front rake with 2.5 billys and adding 1.5" back. lots of trimming with the 33's and that setup in front. definetly go the aal route
  3. Oct 13, 2009 at 9:13 PM
    BobSaget916
    Seth
    Lafayette, LA
    So you're saying ditch the block and do the aal? Or do both?
  4. Oct 13, 2009 at 9:20 PM
    08pretaco
    az
    no no lol ditch the block and do the aal for sure. otherwise your gonna do 3" lift in the back and 2.5" front which will give you a pretty huge rake going forward lol
  5. Oct 13, 2009 at 9:21 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    set the 5100s at zero and replace the coils with totec coils (eibach)
  6. Oct 13, 2009 at 9:21 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    you won't have as bad of a factory rake as you would now with the billie's at 2.5 and a 1.5 aal ( i would recommend the aal over the block any day). you will have some trimming to do with 33's but nothing horrendous or anything like that.
  7. Oct 15, 2009 at 8:31 PM
    BobSaget916
    Seth
    Lafayette, LA
    Thanks for the help guys!!! Much appreciated!! Probly gunna go with the billies all the way around with the stock springs and the AAL. I'm also contemplating doing the OME coils in the front, i've heard they make the ride quality better.
  8. Oct 26, 2009 at 6:48 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Can 5100's work with the factory set up or do you have to realign the front end?
  9. Oct 26, 2009 at 6:53 PM
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    im kinda new to this whole forum thing and not to familiar with most abbreviations.....what does aal mean and what is rake? i have a 04 tacoma and thinking of doing the same minus the 33's.
  10. Oct 26, 2009 at 7:44 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    aal = add a leaf, make the rear end higher & stiffer
    rake = the difference between height of the front of your truck comparred to the rear. Tacoma's, as with most trucks, are higher in the rear
    Also, welcome to tacoma world
  11. Oct 26, 2009 at 8:07 PM
    IamJorgeEdward
    Jorge Edward
    Orlando, FL
    Completely stock
    Thanks for the info, I'm looking forward adding some new mods to my truck. Hope this forum can get me on my way!
  12. Oct 26, 2009 at 8:19 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    is your name actually Bob Saget? Cause that would just rock.. I see it says "Seth" but i hope that really just stands for "Bob Saget"
  13. Oct 26, 2009 at 10:39 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I am also looking to get lifted, what im wondering, is if I do the aal, does that take out my overload spring? and how will it work if i put a quad back there with an aal and no overload?
  14. Oct 27, 2009 at 8:21 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I noticed that my truck sits lower than TRD Sports and TRD Off Road (all 3 stocked). Will my truck be the same height as the TRD Sport and Off Road if we ALL have Bilstein 5100's and AAL?
    Also, I have not seen a lifted Tacoma in person yet. Which truck's stock height is the same height as a Tacoma lifted with Bilsteins at 2.5?
  15. Oct 27, 2009 at 8:35 AM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Your overload spring stays, the AAL goes at the bottom of the leaf pack and above the overload.
  16. Oct 27, 2009 at 11:52 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    They work with the factory setup AND you have to get your front realigned. Anytime the front is disassembled (coilovers, UCAs or shocks) you should get it realigned.
  17. Oct 27, 2009 at 12:33 PM
    AzogSS
    Andy
    Soda City, SC
    Ok. Thanks.
  18. Oct 27, 2009 at 1:11 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    thanks
