Bilstein 6112 Install
Discussion in 'Suspension' started by 12ProTaco, Apr 18, 2015.
  1. Jun 10, 2015 at 9:07 PM
    #61
    Three0Three
    Three0Three Well-Known Member
    Jay P.
    Denver city
    2010 Off Roads
    TRD pro suspension with Toytec Baja spacer for full 3 inch lift front.tsb leafs with Toytec 1.5 Aal in rear. Light Racing uca's 285/75/16's on XD Hoss 16x8's customized Bakflip tonneau, Protech headache rack, Custom Satoshi-homemade with both horns relocated.led pod lights,rear led flood spot combo HID Projector's and fogs,
    That needs some rear.
  2. Jun 10, 2015 at 9:27 PM
    #62
    619rockstar
    619rockstar Well-Known Member
    Ray
    San Diego
    2015 DCSB TRD_OR MGM 4X2
    6112 Bilsteins
    Yes it does, but I might put in 3rd setting, hopefully levels out
  3. Jun 10, 2015 at 9:44 PM
    #63
    Three0Three
    Jay P.
    Denver city
    2010 Off Roads
    I did the same thing for about month. And then readjusted to 3rd ring until rear add a leafs.
  4. Jun 12, 2015 at 10:53 PM
    #64
    619rockstar
    Ray
    San Diego
    6112 Bilsteins
    Yes I really like the ride, it's a little stiff but I bet it's a lot better in the 3rd setting, and for sure I can take you for a ride, are you at El Cajon?
  5. Jun 15, 2015 at 12:05 PM
    #65
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Hope everyone is enjoying these by now.
    Update, Chas ran into some of the guys at bilstein yesterday and they said the next batch of 6112 will be out shortly. Anyone who is interested in a set please call 702.979.1577 and someone will be able to help.
    They were also impressed that Total Automotive Performance was responsible for selling 70-80 percent of the first run across all platforms including fj, 4runner, tundra, and Tacoma. WOW!
    thanks to Chas for hyping these way ahead of time, the great price, and giving us all the info to make a decision, I'm very pleased.
  6. Jun 15, 2015 at 12:18 PM
    #66
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Any news on what the travel of the 6112 is for a Tacoma? Because looking at pics of them side by side with a 5100 they have a longer shaft and shorter body.
    Yota64 likes this.
  7. Jun 15, 2015 at 2:06 PM
    #67
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    I do not know myself. I can try to find extended length and collapsed length of 6112 and 5100 if that will help...
    Are you comparing 5100 to 6112? Do you need a customer length coilover for your application?
  8. Jun 15, 2015 at 2:09 PM
    #68
    JBecker
    Virginia
    I've already got the 6112s on my truck. Was just curious.
  9. Jun 15, 2015 at 2:37 PM
    #69
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    Oh ok. I mean they were designed by the same people for the same vehicle I think the numbers wi be very close. The real difference is the valving which the 6112 have a much stiffer rebound than the 5100 for when you are hitting a sequence of bumps ie washboard or whoops.
  10. Jun 15, 2015 at 6:20 PM
    #70
    619rockstar
    Ray
    San Diego
    6112 Bilsteins
    Nice, you won't be disappointed with the 6112s, Yea I'm not sure if I'm gonna go with an AAL or bring the front down a notch
  11. Jun 16, 2015 at 12:30 AM
    #71
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    how are these different from 5100's?
  12. Jun 16, 2015 at 9:06 AM
    #72
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    I think he's asking because some of us are wondering if they have the slightly extended travel like the pro and baja models have. I know these are closely related to those shocks. I personally do not like giving up downtravel for ride height but if they have extra droop to compensate then thats legit.
    WRT valving, I am pretty sure I read somewhere they have the same valving as the 5100's ; I'll try and find that data when I am on a real computer.
    ETA: It seems as though these have 255/70 valving which allegedly is the same as the 5100's, therefore the damping characteristics will be the same. I cannot find these data on bilstein's site so I reserve the right to be mistaken. That being said I have found multiple threads stating that is the case.
    Also, you state that they have a much firmer rebound for washboard roads. First, this statement appears to just simply be false but secondly even if it was true why would you want an extra stiff rebound? Would this not cause the shock to pack down as it repeatedly hits bumps and is unable to return to proper ride height before hitting another? Is this not why the hardcore guys run bypasses?
    There seems to be a lot of hype and FUD coming from your direction surrounding these shocks; why is that?
    FWIW, I will be running the 6112/5160 combo so not hating on the shocks, just the apparent FUD.
  13. Jun 17, 2015 at 7:39 AM
    #73
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    Im saying they rebound quickly meaning the shock is returning to the normal position quickly after hitting bumps. Which means the shock will do well on washboard or multiple large bumps. Normal shocks are designed for the road. They take a hit and slowly return to position. If your offroading it will feel great for a second but the shock will end up floating near the top of its compression as multiple hits come.
    The 6112 will be able to rebound quicker so by the time you are hitting the third consecutive bump the shock isn't totally bottomed out.
    I think the confusion is that im trying to explain suspension stuff and how it works via a keyboard and not by showing you or giving you a ride.
    I dont know the valving or travel difference but they dont feel like 5100. i used to go 40mph through a dirt lot by my house and the truck was near rattling apart. I can increase the speed to 70 in the same space and it rides so much smoother. The faster you go the better these get.
  14. Jun 17, 2015 at 8:05 AM
    #74
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    from t4r-i can relate to this explanation of going from 5100 to 6112.
    Flyfisher4822
    It's all about what you find acceptable. I too am a 99.5% daily driver. I went the Bilstein5100/FJ coil route. I tried three different height adjustments on the fronts. The valving on the shocks does not match that of the coils, and road vibration at 50-70 mph became intolerable. After three months I bought the 6112's, and like you, thinking it might be overkill.
    What I do know is that the ride is COMPLETELY different. Firm but forgiving and smooth at all speeds; minimizes nose dive and body roll. It's definitely an investment, but for me it was MORE than worth it.
  15. Jun 17, 2015 at 9:16 AM
    #75
    12ProTaco
    12ProTaco [OP] Well-Known Member
    Jesse
    Detroit
    12' Tacoma T/X Pro
    285/75-16 K02's, Bilstein 6112, 1.5 lift blocks, LR UCA, Grillcraft Grill, Kenwood stereo, Sub
    Quick update, I went ahead and used 2" lift blocks from wheelers to level out the truck. It really looks great now! Also, the cv axles in the front haven't shown any signs of wear and I'm not having any second thoughts on buying these. I did get an alignment done and the camber is really close to being perfect, may need upper control arms eventually.
    ensaladas likes this.
  16. Jun 17, 2015 at 11:45 AM
    #76
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    Sounds good. Let everyone know when you take them out and feel them in the dirt
  17. Jun 17, 2015 at 12:58 PM
    #77
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Per the above equation, Kd is the term that describes the valving (although admittedly 6112's are not linear). A larger Kd means a stiffer shock which would create a slower rebounding motion not a faster one.
    urban likes this.
  18. Jun 17, 2015 at 2:19 PM
    #78
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    Are you an engineer or mathmatician? I don't do great with math but I am using these myself in real life. So I'm speaking on what I am feeling from these. No one is going to be able to extrapolate the differences given that equation there alot more factors involved in how the performance is overall when being used on the truck.
    Do you think I could answer a customers question about the ride of these by saying the Kd = 2.5378?
    I will not comment on any mathematic calculations regarding this shock. If you want to compare options with this level of precision you need to procure all of them and take them to a professional with tools to measure the differences.
    I can also tell you no one else buy shocks based on this calculation. Sonny at dsm does not valve shocks by calculating, he does it from experience and feel.
    If you compress a 6112 and a 5100 the 6112 will come back to full ext first.
    Does that equation apply to rebound and compression because I am speaking specifically to the rebound characteristics of this shock and provided eibach spring.
    While I have used a lot of products and sold a lot of products with very good reviews, I actually think I cannot help you with this. You might want to call bilstein and talk to someone who knows more about he technical aspects of the shock.
    I simply go off of what the manufacturer tells us and my personal experience with them over the last 2 months
  19. Jun 17, 2015 at 2:26 PM
    #79
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Yes, I am an engineer. If you are going to throw out terms and advise, get it right.
    I did explain, Kd describes the "stiffness" of the shock, granted in the above equation Kd is linear and not digressive.
    Kd for compression and Kd for rebound are different values, but I believe they are the same as the 5100's. If this is true 6112's and 5100's would rebound the same.
  20. Jun 17, 2015 at 2:48 PM
    #80
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    they don't perform the same in real life on the same terrain. I'm sorry I can't help you compare them in that way.
