Bilstein 6112 Install
Discussion in 'Suspension' started by 12ProTaco, Apr 18, 2015.
  1. Jul 23, 2015 at 10:11 AM
    #141
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I don't have experience with those particular ones. But with Air Bags the concern is that when you flex the suspension, especially after installing longer rear shocks, you run the risk of over extending the bag and tearing it. Depending on your driving, that may never be an issue.
  2. Jul 23, 2015 at 10:37 AM
    #142
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I will have Daystar cradles so the bags will only be mounted on one side, free floating on the other. I am all street driven except for camping roads which are usually not at all what I would call "off-road" as they tend to be minivan friendly.
    YotaDan likes this.
  3. Jul 23, 2015 at 10:40 AM
    #143
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Haha! Well you should be good to go then. The Cradles are a pretty sweet setup.
    Giffmann likes this.
  4. Jul 23, 2015 at 10:47 AM
    #144
    T4RFTMFW
    I'm hoping they pair nicely with the 884X coils up front.
  5. Jul 23, 2015 at 11:31 AM
    #145
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    The 5160s are just a hair over 1/4" longer than the 5100s, so there's not a whole lot more extended travel there. Sure you can run them with say a 2" lift (depending on lift application) however they will see more top out (full extension) the higher you go.
  6. Jul 23, 2015 at 11:32 AM
    #146
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    What would you recommend then for the rear Tacoma with leaf pack?
  7. Jul 23, 2015 at 11:35 AM
    #147
    HeadStrong Off-Road
  8. Jul 23, 2015 at 12:17 PM
    #148
    HeadStrong Off-Road
    PM SENT...:p
  9. Jul 28, 2015 at 6:59 PM
    #149
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    What setting would y'all recommend if i go with HS AAL made by deaver that give 1.5in of lift to make the truck sit slightly nose high? [​IMG]
  10. Jul 28, 2015 at 8:07 PM
    #150
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Mine are on four with like 2.25-2.5 inches lift. Maybe settled a little in like the 2 months I had em. I would do 4 if you already have control arms I am gonna need them to run 285s for sure with good alignment.
    Working fine now but rear is sagging. Probably gonna get allpro springs expect to be slightly rear high which I like the look and handling of.
  11. Oct 9, 2015 at 5:48 PM
    #151
    drknsurfur
    drknsurfur Well-Known Member
    Nick
    Port angeles, Wa
    2008 Silver TRD Sport S/C
    I know this thread is kinda old but does anyone have more insight to this question? I keep hearing that i should go with the big name guys (Fox, Icon, King) but is the Fox 2.0 nonadjustable going to be as good as the 6112s? The rear set up ill be running is the Dakar leafs in the back with the 3rd leaf removed and probably icon/fox 2.0 extended travel so i think it should be 2.5 lift in the rear. I would need to put spacers on the Fox set up in the front to achieve 2.5. Would the FOX 2.0 with spacers be a better buy than the 6112's set at 2.5?
  12. Oct 9, 2015 at 7:27 PM
    #152
    Josh828
    Josh
    Avery NC
    I ended up going with fox 2.5, and love it! Honestly starting comparing the price and it wasn't much more to go ahead and get the Fox 2.5
    drknsurfur[QUOTED] likes this.
  13. Nov 6, 2015 at 11:16 AM
    #153
    12ProTaco
    12ProTaco [OP] Well-Known Member
    Jesse
    Detroit
    12' Tacoma T/X Pro
    285/75-16 K02's, Bilstein 6112, 1.5 lift blocks, LR UCA, Grillcraft Grill, Kenwood stereo, Sub
    I haven't been on in awhile, I just got out of the Army and moved back home to Michigan. An update to this is you are definitely going to need upper control arms. I would highly suggest it.
  14. Feb 27, 2016 at 8:31 AM
    #154
    Bandit455
    Bandit455 Member
    Oley, PA
    2014 silver ac Tacoma 4 cyl
    265/70/17 Kelly tsr's, 3" rc lift
    Anyone install these on a 4cyl access cab yet. Curious to see what the top setting nets lift wise on on a lighter truck. Currently have 3" spacers and would like to get down to the 2.5" range.
  15. Feb 27, 2016 at 11:07 AM
    #155
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    You can get that with 6112 for sure I have 2 inches on the third setting prerunner v6
  16. Mar 10, 2016 at 10:39 AM
    #156
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Did you replace the UCAs? If not, were they able to get it aligned?
    UnconqueredNole likes this.
  17. Mar 10, 2016 at 10:45 AM
    #157
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Any setup over about 2.25" is going to start to be hard to get back into spec. The Caster will end up a little on the low side.
    lynyrd3 likes this.
  18. Nov 14, 2016 at 5:03 PM
    #158
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    I haven't been able to find much about uprated CV joints. Could anyone point me in the right direction?
    lynyrd3 likes this.
  19. Feb 23, 2017 at 7:57 AM
    #159
    lynyrd3
    Bill
    East Central Upstate NY
    :popcorn::popcorn:
    urban[QUOTED] likes this.
  20. May 7, 2017 at 9:24 AM
    #160
    SNOWTACO72
    SNOWTACO72 Member
    SoCal
    2011 2WD DC LB TRD SPORT
    Bone Stock.
    Hello there 619rockstar. i know its been a while since this thread went down, but was curious if your ever dropped your 6112'w down to the 3rd setting?
