Bilstein 6112 with 650lb springs
Discussion in 'Suspension' started by NYCTaco52, Apr 24, 2019.
  1. Mar 2, 2021 at 9:08 AM
    #41
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    650# and 5th notch on both sides with 1/4” spacer on the driver’s side to counter the taco lean.
    Ride is much better than when i had 700# on max 6th notch. I know i know...LOL
    Kerbouchard![QUOTED] likes this.
  2. May 13, 2021 at 12:24 AM
    #42
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    Just received my 6612s and waiting for 5160s to arrive for the full install, keeping stock height so no leaf springs required. Should I just run the 600# that come with the fronts or go 650#? Running stock bumper, TRD Pro skid plate with Prinsu cab rack loaded with Road Shower 4 (120lbs when full) and a full cargo case but besides that I don't plan on adding any more weight to the front the rest of weight is in the bed. I installed Hellwig 7719/7744 sway bars to stiffen up the ride and reduce roll because I drive on tarmac 95% of the time.
  3. Jul 29, 2022 at 11:01 PM
    #43
    TacoZmtn
    TacoZmtn Well-Known Member
    2022 TRD Off Road LB
    OTT-6112’s~5160’s rxt's~ShmellFab Sliders
    What'd you end up going with? I was curious about the stock leaf with the 5160's...
    fullsend604[QUOTED] likes this.
  4. Jul 30, 2022 at 10:15 AM
    #44
    Suspender
    Suspender Well-Known Member
    Colin
    IE, CA
    i can’t speak from experience but I’ve been researching like crazy for my own purchase and it’s gonna ride stiffer than stock either way so if you want it real stiff go 650 and if you just want it a little stiffer go 600, you don’t have much added weight. Really you would need a bumper and winch to go 650 as that would be closer to 200 pounds added.
  5. Jul 30, 2022 at 10:21 AM
    #45
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    600 lb coils will be fine.
  6. Jul 31, 2022 at 12:24 AM
    #46
    fullsend604
    Ended up going with 6112s stock springs set at max height and 5160s with ICON RXT leaf springs on option #1. Ride is night and day difference vs stock, love driving the truck even more now! Will be adding the extra leaf that came with the leaf packs to go up to option #3 as I'll be adding a hard shell RTT and Diamondback HD cover which will increase my bed weight by 280lbs so total will be over 400lbs along with the other things already in the bed.
    71tattooguy and TacoZmtn[QUOTED] like this.
  7. Aug 1, 2022 at 11:40 PM
    #47
    TrailToy867
    TrailToy867 Member
    2013 trd off-road
    Blistein 6112/5160
    I just put on the icon rxt option 3/b110s in the rear and love the ride with the 6112s up front, but now have a tad too much rake. The 6112 600lb coils have sagged pretty bad after steel skid set, bamf sliders and heavier tires went on. I’m looking into 650lb coils and wondering if the the icon 14” coil springs would be a good combo, since the rear icon rxt/b110 setup is working nicely off-road. If their coil springs are nothing special I’m also considering the 650lb kings.
    71tattooguy likes this.
  8. Aug 2, 2022 at 5:10 AM
    #48
    71tattooguy
    Dino
    Petaluma , Ca (707)
    https://www.headstrongoffroad.com/s...00Lb_Coil_spring_-_1400.300.0700S_(PAIR).html
    buddy of mine is running these he is pretty heavy with bamf skids bumpers etc.
  9. Aug 2, 2022 at 6:33 AM
    #49
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Unfortunately your only option for going with a heavier spring on the 6112s is the 650lb spring that is made by Bilstein. They have a pigtail end (unlike flat top/bottom) and a tapered upper portion of the spring. I'm sure this is Bilstein's move at making sure folks stay in their ecosystem.
    EDITED: RESPONSE BELOW
  10. Aug 2, 2022 at 2:13 PM
    #50
    TrailToy867
    TrailToy867 Member
    2013 trd off-road
    Blistein 6112/5160
    This makes a lot of sense, thanks for the info. So the icon coil definitely seems to have the flat top/bottom, but wheelers has an option for king or wheeler coils on the 6112. Possibly those are the only options besides a bilstein coil on the 2nd gen.
  11. Aug 2, 2022 at 3:22 PM
    #51
    memario1214
    Colton
    Missoula, MT
    Interesting... I wonder how they get around the fact that the top and bottom of the spring being different diameters. They might have access to a different spring seat or something? I might make a couple of phone calls tomorrow because I am genuinely curious. Absolutely news to me.
  12. Aug 8, 2022 at 8:20 AM
    #52
    BugJuice
    BugJuice Well-Known Member
    Is there a benefit to running a taco lean spacer over a mismatched notch height?
  13. Aug 8, 2022 at 9:03 AM
    #53
    71tattooguy
    Dino
    Petaluma , Ca (707)
    IMO No just up to the person.
  14. Aug 8, 2022 at 9:12 AM
    #54
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Is this a new change? Folks in my off-road club that got the 6112s in 2020 had closed and ground ends.
  15. Aug 9, 2022 at 10:14 AM
    #55
    memario1214
    Colton
    Missoula, MT
    Nope - Just some brain fog by yours truly. You're correct. Occasionally I like to get Bilstein stuff mixed up. Appreciate you saying something :thumbsup:
    Tacoma 6112s - 3"x3" shaved flat springs
    Tacoma 5100s - Pigtailed springs
    Tundra 6112s - Shaved flat, but ID from top to bottom are different so standard springs won't work.
    71tattooguy and 3JOH22A[QUOTED] like this.
