Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Oct 6, 2016 at 7:41 PM
    #201
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Not sure if they sell them separately. If they increase preload, I'll probably go with another coilover. @ToyTec Lifts
  2. Oct 6, 2016 at 9:22 PM
    #202
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    Unfortunately they do not sell their top mount separately
  3. Oct 6, 2016 at 9:27 PM
    #203
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Guess they want you to buy the whole package from them, which seems to be higher. All that is is machined aluminum, guess I'm going a different route. Thanks for the heads up.
  4. Oct 7, 2016 at 4:38 AM
    #204
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Got caught up with work and forgot to reply the other day, guys. Thanks for the feedback, it settled my mind on it. Really appreciate it.
  5. Nov 7, 2016 at 3:55 PM
    #205
    uwjberg
    uwjberg Well-Known Member
    @Swiftks - I like your rationale and am thinking of duplicating your set up. A couple of questions:
    1. I don't see 6112's listed for 3rd gens - did you use 2nd gen part #'s? If so, I assume no issues there?
    2. For the rear, do you think that 5160's are worth it? Isn't the additional travel negated by the Sumo springs since they rest on the frame? Or are you thinking extra travel on extension, but not compression? Just curious here.
    The setup looks good and well thought out. Nice job.
    Swiftks likes this.
  6. Nov 7, 2016 at 10:27 PM
    #206
    Swiftks
    Swiftks Well-Known Member
    Spring, TX
    2016 TRD OR
    Bilstein 6112 (front) Bilstein 5160 (rear) Headstrong Progressive AAL ShiftSense Pro SumoSprings BakFlip F1 Tonneau Cover BAMF Grille aFe intake w/ scoop Custom Exhaust - URD Y-Pipe, Vibrant Ultra Quite Resonator & MagnaFlow Muffler 4Runner TRD Pro 17" Wheels Wrangler DuraTracs - 265/70R-17 Redline Hood Struts OPT7 LED Headlights (Highs & Lows) Baja Designs Squadron Pro Fog Lights LED Interior Lights Total Chaos Bed Stiffeners TRD Pro Skid Plate TRD Pro Tail Lights TRD Pro Shift Knob @CBoy808 Custom Bedside Decals FormulaOne Pinnacle Window Tint OEM Tacoma Bed Mat OEM Tacoma All Weather Floor Mats Fumoto Valve Amsoil Fluids
    Yes, I used the 2nd gen part #'s with no issues. And I paired with the 5160s for the extra travel on extension, and yes I think they're worth it... Much better shock over stock or 5100 series.
    Watt maker likes this.
  7. Nov 8, 2016 at 7:50 AM
    #207
    uwjberg
    Perfect thanks for the quick response.
  8. Nov 8, 2016 at 9:00 PM
    #208
    Djboi808
    Djboi808 Well-Known Member
    2015 white Tacoma 4x4 Trd Off Road
    Anyone install the 6112 at 5th setting to clear 285 size tires ? If so how's the ride debating on replacing my 5100 with ome 887 in the front and going with the 5160 in the rear
    lynyrd3 and Braunschwaga like this.
  9. Nov 8, 2016 at 9:03 PM
    #209
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You guys see Bilstein denied warranty coverage because of off-road use?
    Just a heads up.
  10. Nov 8, 2016 at 9:08 PM
    #210
    Djboi808
    Well that sucks
  11. Nov 8, 2016 at 9:58 PM
    #211
    Braunschwaga
    A-A-Ron
    Kauai, HI
    Just installed mine this past weekend, 6112's on the 5th setting with driver and passenger top mount spacer and 285's with 1.25" wheel spacers. Definitely a stiffer ride over stock, soaks up the rough roads fairly well but I imagine the ride would be better at the third setting. Even at this height and with an alignment done I still rub on the cab mount(was to be expected with 285's and spacers), only at full lock during daily commutes. Would definitely rub hard off road though, CMC will be done soon to allow proper clearance. You MIGHT be able to get away with 285's and no CMC depending on your wheel specs and the type of tire you plan to run.
    Durdy likes this.
  12. Nov 8, 2016 at 10:02 PM
    #212
    Djboi808
    Right now I'm using 5100 with 887 ome coils with 285/75/16 on fj special edition wheels and I have no rubbing my 887 has settled to 2.75 in
  13. Nov 8, 2016 at 10:10 PM
    #213
    Braunschwaga
    A-A-Ron
    Kauai, HI
    You should be fine then, 6112's tend to give more lift than what is spec'd out.
  14. Nov 9, 2016 at 9:30 AM
    #214
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    So these are designed for off road use, and they won't cover it? Bye Felicia
  15. Nov 9, 2016 at 9:35 AM
    #215
    T4RFTMFW
  16. Nov 9, 2016 at 5:12 PM
    #216
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    They cost 650 bucks are you guys really that cheap? I have them so i can go to the desert, have fun, make it home. If they break i probably caused it. Take responsibility for your actions and have fun!
    Crom likes this.
  17. Nov 10, 2016 at 10:23 AM
    #217
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    I just called Bilstein and they said, They have a 6112 coming out for 3rd gens this month. Separate part number (47-234413) and they are doing the first run this week. So it should hit stores this month. The rep said they were changing the stiffness of the rebound to handle the extra weight of the 3rd gen. I think the reason they declined the warranty is that he was running 6112 for a 2nd gen on a 3rd gen. She said if there was ever an issue just to tell them that I was "driving" and it broke. The only reason they wouldnt warranty is if some big rock punctured my 6112 and that makes sense.
    I just ordered the 5160 for the rear and I really wanted to order the 6112 but I am waiting cause I dont want issues down the road. I have been reading up and it seems like this pairing is giving the best bang for the buck. Soft plush ride on the street and great response off road. I was considering the 5100 with coil or moving up to fox/icon stage 1 but I heard they are more stiff and I dont want a stiff ride on the street. I am only going for a 1-2 inch lift so this should work well. and if I end up adding weight to the front, I can switch out the springs for a firmer set. On the rear, I am thinking about a 1 inch block to get a little height but not sacrifice ride quality or adding an aal for when I start towing more weight. I have done a lot of reading and this seems to be a great option for around 1100...
    DaVikes likes this.
  18. Nov 10, 2016 at 10:28 AM
    #218
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    @iK0NiK
    as with any shock, I personally wouldnt rotate it too much just to rotate it haha. if there is any grit in there, there is the chance rotating the body around could work it into the seals and damage them leading to leaks. I know its a small chance, just figured I'd add it as something to keep in mind.
  19. Nov 10, 2016 at 6:19 PM
    #219
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Blocks don't ride well
  20. Nov 10, 2016 at 6:32 PM
    #220
    avitaco
    A
    2017 DCSB 4x4
    Ive heard that, but I think an aal or sumo spring will be more stiff. I think a 1 inch block wont be a bad ride. Im gonna do the 5160 with out the block then add it to see if the ride suffers
