Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. May 18, 2019 at 4:39 PM
    #2241
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Why not go at it again :notsure:
  2. May 18, 2019 at 4:39 PM
    #2242
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Superdave1.0 likes this.
  3. May 18, 2019 at 4:42 PM
    #2243
    DrFunker
    DrFunker Well-Known Member
    Wait a second....you are stating it is for 2016+. o_O
    Is it the same for 2nd gen?
  4. May 18, 2019 at 4:46 PM
    #2244
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    You have your opinion and that's it. You are dead set on installing these in a manner that Bilstein does not recommend. In the instructions from Bilstein, no where does it say" OK TO INSTALL A SPACER." Spacers were meant for people installing OME spring or the like that do not have any other way of making the driver side taller. In Bilsteins case they created a way to do that. Without need for spacer. This is all FACT.
    The only assumption I have is why didn't bilstein create side specific shocks, one longer than other. Well, I feel it's because that would cost a hell of a lot more to create the machinery necessary to make 2 different shocks. In addition, people might accidentally order a pair of just one side. Also, like I am going through right now with damn 5160s, they might actually run out of one side, then no one gets shocks.
    PhishinTaco likes this.
  5. May 18, 2019 at 4:48 PM
    #2245
    Superdave1.0
    SoCal
    There are 05-15 and also 16+ specific 6112
    DrFunker[QUOTED] likes this.
  6. May 18, 2019 at 4:49 PM
    #2246
    DrFunker
    Wonder if the specs are the same as well.
  7. May 18, 2019 at 4:49 PM
    #2247
    Superdave1.0
    SoCal
    They are slightly different.
  8. May 18, 2019 at 4:51 PM
    #2248
    DrFunker
    I think I may take the spacer out and give this a try.
    I had thought about it and tossed the idea around in another thread. One guy had done it already and another advised against different notch settings.
  9. May 18, 2019 at 4:53 PM
    #2249
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    It’s clear your understanding of lift kits and companies instructions on lift kits is limited.
    They didn’t make side specific because as I stated above. SOME tacos have the lean, others don’t. So it would cause people without a lift to have one after that.
    Secondly, the only different between the part numbers on the 5160s is the way the reservoir bolt mounts to the truck. The valving is exactly the same. No other differences.
    And in terms of what Bilstein instructions say, again, is a recommendation, like most lifts, every aspect of someone’s lift can be different and have completely different “fixes” to get it right. Which is why, no matter how many instructions come with any lift, you always have guys coming in here confused or calling the vendor for info. Sometimes things just don’t work the way they should. Which is why Bilstein uses that notch difference as a way to correct lean
  10. May 18, 2019 at 4:54 PM
    #2250
    Superdave1.0
    SoCal
    I assume the spacer is fine. I just like to follow manufacturer instructions. Read the instructions. It states to install 1 notch higher on driver side.
  11. May 18, 2019 at 4:56 PM
    #2251
    DrFunker
    I have not run into any issues with it. But still have some lean.
    Was going to give the rear a little love too. :p
    Superdave1.0[QUOTED] likes this.
  12. May 18, 2019 at 4:56 PM
    #2252
    Superdave1.0
    SoCal
    I stopped reading at "SOME TACOS HAVE LEAN SOME DON'T." Who told you that??
  13. May 18, 2019 at 4:57 PM
    #2253
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Um, the god damn vehicles themselves. Simply take a measure of a bunch, you’ll see some are even. STOCK
  14. May 18, 2019 at 4:59 PM
    #2254
    DrFunker
    Mine had the lean stock and post-lift.
    Taconator_ and Superdave1.0 like this.
  15. May 18, 2019 at 5:02 PM
    #2255
    Superdave1.0
    SoCal
    I have ZERO lean following the instructions that Bilstein provided with these wonderful shocks.
  16. May 18, 2019 at 5:03 PM
    #2256
    Superdave1.0
    SoCal
    What I meant was, they ALL have lean. Not just some.
  17. May 18, 2019 at 5:04 PM
    #2257
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Now id have to ask you the same question. Who told you that? Have you checked every Tacoma in America? Have you personally got down and measured the ones you’ve come across? Or are you going off what you read on Tacoma World in your basement?
  18. May 18, 2019 at 5:05 PM
    #2258
    Superdave1.0
    SoCal
    The fuel tank. Battery and driver weight attribute to the taco lean. All 05+ tacos are heavier on driver side by design.
  19. May 18, 2019 at 5:07 PM
    #2259
    Superdave1.0
    SoCal
    No one. I used my own brain. Fact is, fuel tank is on driver side, battery is on driver side. Those factors do not change from Tacoma to Tacoma.
  20. May 18, 2019 at 5:07 PM
    #2260
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Agreed yes, but it’s rather close minded to make the statement that ALL Tacoma’s have a lean because of it. I’ve literally seen a handful of completely stock Tacoma’s that were level. Seen with my own eyes, with actual measurements
