Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Nov 1, 2019 at 9:16 AM
    #2721
    Cash13
    Cash13 Well-Known Member
    Northern Colorado
    2014 Tundra
    Can anyone comment on the ride quality with front set at the 5th setting on a second gen?
  2. Nov 1, 2019 at 1:50 PM
    #2722
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Bump
  3. Nov 1, 2019 at 2:09 PM
    #2723
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    You might want to PM or contact Marie @HeadStrong Off-Road regarding this....she can give you the info that you need.
    DrFunker likes this.
  4. Nov 1, 2019 at 3:39 PM
    #2724
    QuicksandTaco
    Cody
    Oregon
    Can anyone with a 3rd gen tell me their lift gain that used the 2nd gen 6112’s??
  5. Nov 1, 2019 at 4:19 PM
    #2725
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    We actually haven't tested 3rd gen specific suspension on 2nd gens so unfortunately I can't help you with this.
    Thank you so much @crashngiggles for thinking of us though :)
  6. Nov 1, 2019 at 4:32 PM
    #2726
    QuicksandTaco
    Cody
    Oregon
    Do you have lift numbers of trucks with 2nd gen 6112’s? Like if a third gen truck is gaining 2” on the 5notch which claims 2.5” on a second gen. Would that mean ideally the 6/5 notch on a third gen claiming 2” of lift would get a second gen truck 2.5”?
  7. Nov 1, 2019 at 5:10 PM
    #2727
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Not sure about that. What it seems is the 3rd gen 6112's get a bit less lift because the trucks are approx one inch higher from the factory. But since your shocks are set at 6/5 and they have 650 springs that would net at least 2.5" maybe 3"on a 3rd gen assuming the front end doesn't have any added weight. So on a 2nd gen I would guess you will see 2-2.5" of lift with those. Basically if someone with a 3rd gen whose running that same setup can confirm then you'll be approx 1/2 to 3/4" less than theirs. Just an educated guess based on what I know about these. I've moved mine around a few times and have been in this thread since the beginning.
    QuicksandTaco[QUOTED] likes this.
  8. Nov 1, 2019 at 5:18 PM
    #2728
    QuicksandTaco
    Cody
    Oregon
    I’m all over the place trying to nail this down. Right now my thought is kind of here: 3rd gens are 1” higher stock. So if the 3rd gen 6112’s gain them 2” of lift, that would essentially mean its 3” higher than a 2nd gen truck. I’m confused why this wouldn’t mean the 3rd gen 6112’s dont just give a 2nd gen truck 2” of lift. This is assuming 600lb springs on the 6/5 clip setting.
    side question, where does the 3rd gen gain this inch higher when stock?
  9. Nov 1, 2019 at 11:19 PM
    #2729
    edgarcg2
    edgarcg2 Well-Known Member
    Edgar
    2018 cement Tacoma dcsb off road 4x4
    def will try that out!
  10. Nov 2, 2019 at 3:10 AM
    #2730
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    If you go on headstrong’s website and look at the product pages for the 3rd Gen and 2nd Gen 6112’s there are charts at the bottom of each product that are Bilstein’s estimated lift heights for each model. Use that as your guide. If my memory serves me correctly the 3rd Gen 6112s net about 1/2” less lift on those trucks so I would think they would potentially top out at 3” of lift at max settings on a 2nd Gen.
    This is all theory though, but should get you close.
    crashngiggles likes this.
  11. Nov 2, 2019 at 7:47 AM
    #2731
    HB Taco
    Curt
    It looks like you have a Pro model. So if thats true you already have 6112's set at 1.75" IIRC? Correct? Id just leave it alone if it was me. What are you looking to net out of this again?
    this^ - so basically since you have the 650 spring that will effectively compensate for the difference between the 2nd and 3rd gen shocks. So use the 2nd gen lift chart (over a basic 2nd gen not a pro). Damn you are making this very confusing. Just put them on and you will see about 1/2 to 3/4" over your pro setup.
  12. Nov 2, 2019 at 9:54 AM
    #2732
    QuicksandTaco
    Cody
    Oregon
    So the guy that I purchased them from, had them on his third gen and told me he got about 2 3/8” of lift with the 650lb spring.
    @oscolivar1 said the same thing basically and recommended keeping them at 6/5. I think I will install them and see what I end up with.
    Yeah, I have the pro with the 6112. The passenger front has a leak. My stock leaf pack is shit so currently I’m at 21.75-22” front and 21 rear from hub to fender. I want it to sit level or with a slight rake so I have a new leaf pack with the icon 3 leaf all. Keeping the OL leaf in should put me at 23-24 correct? So then with the new 6112’s hopefully gaining me 2-2.5 will put my front at 22.5-23?
  13. Nov 2, 2019 at 10:50 AM
    #2733
    iK0NiK
    West
    Columbus, GA
    If you can at all afford to do it, skip the 3 leaf and go straight to the Dakar Mediums. I promise you won’t regret it. I wasted a lot of time and money trying to band aid my sorry factory leafs with the 3 leaf AAL.
  14. Nov 2, 2019 at 10:55 AM
    #2734
    QuicksandTaco
    Cody
    Oregon
    I just never have any weight back there other than my dog or dirt bike so I didn’t think a full leaf pack would ride that great for me. Am I wrong? I have this leaf pack already so I will go with that for now. At least the rear is super easy to change things.
    iK0NiK[QUOTED] likes this.
  15. Nov 2, 2019 at 11:50 AM
    #2735
    iK0NiK
    West
    Columbus, GA
    Ah I misread your post. You’ve already got a new leaf pack on hand. Gotcha, good deal. That setup with the 3 leaf will ride really nice. I loved the ride quality the 3 leaf AAL gave. It just didn’t handle weight well.
  16. Nov 2, 2019 at 11:53 AM
    #2736
    QuicksandTaco
    Cody
    Oregon
    I’m hoping that refreshing the suspension all around plus the clamshell bushing will significantly improve the ride of my truck. New tires soon and then possibly UCAs if needed down the road and I should be set. My main concern is figuring out this clip setting situation lol
  17. Nov 2, 2019 at 2:26 PM
    #2737
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    skip the 3 leaf AAL. I tried to justify that I didn’t need them to but ended up not liking them. stock leaf pack sucks PERIOD!
  18. Nov 2, 2019 at 10:12 PM
    #2738
    RocRan26
    RocRan26 Well-Known Member
    Randy
    Rochester NY
    2017 Black Tacoma Limited DCSB AT
    I installed 2nd gen 6112s on the top(5th)notch and 5160/HS 3 leaf AAL with overload in. I got 2.5” in front (which is exactly what the chart says to expect)and 2” in the back which puts me at 23” hub to fender all the way around. For reference the only extra weight I have is a extang solid fold tonneau and sliders.
  19. Nov 3, 2019 at 6:19 AM
    #2739
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    With the added weight of the Mobtown skids, bumper and winch, sliders. I upgraded my front springs to 700#, Eibach's. Preload was set at 5/4.
    Ride on the street is nice and smooth, offroad have been good.
    Here's a short clip you can see them moving nicely without so much preload that I climb the front needlessly into the sky.
    It was a slick mess in that clay btw:
    slomoe and cubie like this.
  20. Nov 3, 2019 at 6:06 PM
    #2740
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    So ive had 6112s on for about half a year now, pretty much all of it with BAMF skid trilogy on. recently i put on a BAMF front bumper and the ride became unbearable. swapped in 650 lb springs yesterday and i couldnt be happier. so now, with the dakar medium duty leaf pack and 5160's in the rear, im at about 22.5" in front and 24" in the rear, hub to fender. fronts are set on the 4th notch with a 1/4" spacer on driver side. couldnt be happier. well, thats a lie, ill be happier when i get a rear bumper and level it out a little more.
    DavesTaco68 and crashngiggles like this.
