Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Nov 4, 2019 at 12:44 PM
    #2741
    Tainted
    Tainted Well-Known Member
    Just wanted to update this. I ordered the Icon sway bar relocate kit and installed it. I “feel” safer with the sway bar on now.
    As others mentioned with or without a sway bar is a personal choice
  2. Nov 4, 2019 at 5:00 PM
    #2742
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    I'd love to hear what you think of it when you get it installed. I'm reluctant to remove it driving quickly in highway deer country
  3. Nov 4, 2019 at 5:42 PM
    #2743
    Tainted
    I already put the sway bar back on with the Icon spacers from Wheelers. I feel much safer with it on. It was too much lean for my likings without it.
    BRFab[QUOTED] likes this.
  4. Nov 4, 2019 at 5:59 PM
    #2744
    508Tacoma
    508Tacoma Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    Has anyone done height adjustments to their 6112? Mine are at the top setting and I’ve noticed it to be a very harsh ride. Any suggestions to help with this? Perhaps adding some weight up front? Thanks
  5. Nov 4, 2019 at 6:04 PM
    #2745
    Tainted
    Can you describe harsh? My truck rides so much better compared to stock. I set mine on the 5th perch.
    I did read from someone who owned both a Tacoma and a 4Runner running Bilstein 6112 on both of them. He swapped out the Bilstein on the 4Runner for Kings and he said it was night and day. So much smoother.
  6. Nov 4, 2019 at 6:16 PM
    #2746
    508Tacoma
    MA
    Yeah it just seems even going over speed bumps or unpaved roads it seems to bounce around a ton. Just was seeing if dropping to a lower setting might make a smoother ride
  7. Nov 4, 2019 at 7:01 PM
    #2747
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    If you max out the preload they can get harsh. Drop them a notch and try it out. Easy enough to do.
  8. Nov 4, 2019 at 8:33 PM
    #2748
    edgarcg2
    edgarcg2 Well-Known Member
    Edgar
    2018 cement Tacoma dcsb off road 4x4
    I have mine set at 6/5 and had them at 5/4 before and don’t notice a difference
    oscolivar1 likes this.
  9. Nov 5, 2019 at 7:25 PM
    #2749
    Antuhny
    Antuhny Active Member
    2019 Tacoma TRD Off Road
    Just ordered some 6112/5160 and waiting for it to be delivered. I'm going to have it installed with 650 LB springs on the 6/5 setting to have approximately a 2" inch in the front. Is having a AAL or a new leaf pack necessary? I'm trying to have the truck leveled or have the front a bit higher.
  10. Nov 5, 2019 at 7:41 PM
    #2750
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Your fronts going to be very high with 650# and no AAL or rear leaf setup.
  11. Nov 5, 2019 at 7:46 PM
    #2751
    Antuhny
    650 lb springs at a 6/5 settings would probably net me 2.5" inch with no weight, so I'll get after market UCA. Would having no Leaf pack or AAL be okay for this setup on a 3rd Gen?
    I plan to get a aluminum bumper with a winch a year from my lift.
  12. Nov 5, 2019 at 7:49 PM
    #2752
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    No rear setup is fine. But if I were you, I would start a little lower on spring perch, then go up a few rings as needed with the weight. With no weight, its going to ride like crap IMO.
    So, I'd start at like 4/3 or something. Its not hard to adjust if your mechanically able.
    slomoe likes this.
  13. Nov 5, 2019 at 7:51 PM
    #2753
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    To give context, I ran them with the stock springs they come with, 600# at 6/5 until I put on a SSO bumper. It was very rough until I added the weight.
  14. Nov 5, 2019 at 7:54 PM
    #2754
    Antuhny
    I appreciate the input. I'll probbly have my local shop install it at a 4/3 setting with the 650 lb spring, which would net me approximately a 2" lift and then have the shop adjust it once I get my bumper and winch. :)
  15. Nov 5, 2019 at 8:03 PM
    #2755
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Have em set that, drop the truck bounce it a few times. See where it settles, if need be move to 5/4 if your not happy. With jack stands, floor jack and a few tools. I cna move mine around within a hour in my garage. But I have the tools and have been wrenching for a while. If you dont have space available to work on your truck, maybe a friends house? Its really easy to install them outright once assembled. Can order them assembled ready to go from headstrong.
  16. Nov 5, 2019 at 9:12 PM
    #2756
    edgarcg2
    Edgar
    I have the 6/5 and aal on the rear, sits perfect. I would imagine with out the aal the front would be at least 1.5 higher
  17. Nov 6, 2019 at 8:44 AM
    #2757
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    I have 6112s with the 650# springs set at the 5/4 setting. I have a steel skid trio, sliders, SSO bumper and a 10K synthetic winch. Even with all this weight I got 1.5" of lift. I'd imagine without the weight and even still being at the 5/4 setting I'd get higher than 2" of lift. I agree with others and I would start at 4/3 with the 650# springs if you don't have any added weight. I think the ride would be too harsh and your lift too high.
  18. Nov 6, 2019 at 10:57 AM
    #2758
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Anyone running the 650lb spring on stock weight? Is there a ride difference or is it minimal?
    Thanks.
    Gunshot-6A likes this.
  19. Nov 6, 2019 at 11:25 AM
    #2759
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    The first question that you have to ask yourself is:
    Why would I want to put 650lb springs on a stock set up?
    Is it because you want to order them with the 650lb springs anticipating that you will add more weight in the future?
  20. Nov 6, 2019 at 11:30 AM
    #2760
    QuicksandTaco
    Cody
    Oregon
    I bought them off a guy that gave me both 600 and 650 and they have the 650 springs assembled already. I don’t anticipate adding weight but things change lol
