Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Mar 15, 2020 at 9:20 PM
    #3121
    primodude
    primodude Well-Known Member
    Tacoma Wa
    19 Cement DCLB TRD OR
    Are you running oem UCAs? If so does anyone know will aftermarket UCAs give him a little more drop that might fix maxing out the drop over speed bumps?
    bonifacio_629[QUOTED] likes this.
  2. Mar 15, 2020 at 10:20 PM
    #3122
    dirkupson
    dirkupson Active Member
    2020 Toyota dclb trd off road
    2.5 fox shocks ,trd 4runner wheels , toyo tires
    I just bought a 2020 Tacoma today and wanted to replace the shocks. The 6112 can be set to the stock height, correct. Also, how do they ride at the stock height? Thank you
  3. Mar 16, 2020 at 12:50 PM
    #3123
    usernotfound
    usernotfound Well-Known Member
    Brandon
    CO
    '20 4Runner TRD OR
    Yes, they can be set at stock height. My assumption is that they ride great at stock height. I say this because I'm running mine on the 3 / 2 setting (0.5" above stock) and the ride quality is excellent. It's also worth noting that this is on Cooper AT3 4S tires in a 265/70/17.
    dirkupson[QUOTED] likes this.
  4. Mar 21, 2020 at 6:31 PM
    #3124
    dhectorg
    dhectorg Well-Known Member
    Don
    2020 Toyota Tacoma TRD OffRoad
    Personally, I think using the same preload setting on both sides with a driver side spacer makes a helluva lot more sense to maintain uniform ride and performance.
    I just got a 2020 DCLB OR and I'm planning on doing 6112s with 650 lb springs set to level 4 with 1/4" driver's side spacer. I will pair those with 5160s, Deaver HD add-a-leaf kit and 1500 lb SumoSprings in the rear.
    I know this will create a pretty stiff ride, but the whole reason I'm doing such a heavy duty setup is to future proof my suspension, as I plan to add a camper, winch, sliders, skid-plates, etc over time. I actually want a sportier ride and handling anyway. Plus, I only plan to spend this much money once. I'm definitely not one of these guys who replaces their suspension every 6 months lol.
    toucan likes this.
  5. Mar 21, 2020 at 6:49 PM
    #3125
    dhectorg
    Don
    Does Headstrong give discounts for positive reviews? Maybe it's my bs detector being a bit overactive, but I get real suspicious when I see glowing reviews popping up all over forum discussions.
  6. Mar 21, 2020 at 7:26 PM
    #3126
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    No they do not......Marie @HeadStrong Off-Road is just that good. Educates you instead of sells you and always free shipping.
    Superdave1.0 likes this.
  7. Mar 21, 2020 at 7:35 PM
    #3127
    dhectorg
    Don
    Good to know!
  8. Mar 21, 2020 at 7:47 PM
    #3128
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Yeah bro I got free shocks. :jerkoff:
  9. Mar 21, 2020 at 9:21 PM
    #3129
    dhectorg
    Don
    That's a bit more lift than I would expect for the 4th setting, especially on a heavier DCLB truck. I thought the 3rd gen 6112s could only lift up to 2" max on DC trucks. I have a 2020 DCLB and I want to wind up with about 1.75" of lift after settling and loading, since I will have pretty heavy constant load. I was planning on going with the 4th slot, but now I'm not sure because I definitely don't want to go over 2" of lift.
    Will other DCLB OR owners please reply with their chosen 6112 preload setting and the amount of total lift they got?
  10. Mar 22, 2020 at 1:43 PM
    #3130
    crashngiggles
    Jared
    Keep in mind that I have a 2013 2nd gen dclb. Your 2020 is already 1 inch higher than mine is stock so yours with the same settings would go up 1.25-1.50 inches with the same things on it.
  11. Mar 22, 2020 at 11:12 PM
    #3131
    dhectorg
    Don
    Got it. I thought you had a 3rd gen.
  12. Mar 24, 2020 at 1:46 PM
    #3132
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    Anyone else experience very squeaky springs? I’ve had mine on for about 20k give or take and really only do on road driving with the occasional dirt road.
  13. Mar 24, 2020 at 1:50 PM
    #3133
    crashngiggles
    Jared
    Up front or in the rear?
  14. Mar 24, 2020 at 1:55 PM
    #3134
    Bigpat_ca
    Sacramento, CA
    Up front. I understand a little squeak can be normal but this seems excessive. Just going over speed bumps or up a rolled curb is loud AF
  15. Mar 24, 2020 at 1:55 PM
    #3135
    Superdave1.0
    SoCal
    Breaking the rules that I recommend against. I'm installing eibach 14" 650lb springs onto the 6112s this week. I added a front bumper and winch and lost about 3/4" in height. I was already at 6/5 clip.
    Bilstein 650lb spring for the 6112 is on national backorder. Verified with 4wp and Headstrong does not have them. So I ordered the eibach springs. I'll roll these for a while, will report with how they feel/ride.
    dhectorg likes this.
  16. Mar 24, 2020 at 1:58 PM
    #3136
    Superdave1.0
    SoCal
    Could be your radiator support body mount bushings. I also have a weird squeak up front. Please post back here if you figure it out.
    crashngiggles likes this.
  17. Mar 24, 2020 at 1:58 PM
    #3137
    crashngiggles
    Jared
    I have at least 45,000 miles on mine without any front squeak from the 6112's. I am wondering if it might be your BJ's, UCA's, or front bushings.
  18. Mar 24, 2020 at 1:59 PM
    #3138
    crashngiggles
    Jared
    I second this check...
    Superdave1.0[QUOTED] likes this.
  19. Mar 24, 2020 at 2:00 PM
    #3139
    Superdave1.0
    SoCal
    I'm going to replace the front body mounts with energy suspension bushings. Just haven't got around to it. I heard it's good preventative maintenance anyways.
  20. Mar 24, 2020 at 2:02 PM
    #3140
    Bigpat_ca
    Sacramento, CA
    I didn’t consider my UCAs. I’ll have to look into that for sure.
