Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jul 22, 2020 at 10:29 AM
    #3881
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    OME springs are notched. 6112 springs are flat. The lower spring perch won't work with the OME's.
    toucan[QUOTED] likes this.
  2. Jul 22, 2020 at 6:34 PM
    #3882
    overlandozzy1
    overlandozzy1 Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    Any adive as for what springs to go with, when using 6112s? Looking to run some 6112s up front and some 5120s in the rears with an AllPro Expo pack in the rear
  3. Jul 22, 2020 at 6:46 PM
    #3883
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    6112 come with a 600lb spring assembled. You need 650/700 spring? Eibach and bilstein are the only coils that fit currently.
  4. Jul 22, 2020 at 6:47 PM
    #3884
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    yeah going to run an aluminum front bumper with winch and full skids
  5. Jul 22, 2020 at 7:40 PM
    #3885
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I would recommend the bilstein 650lb springs on the 5/6 notch
  6. Jul 22, 2020 at 7:44 PM
    #3886
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    That's what I have. It's a bit too high but I don't have my bumper, winch, skids and sliders yet.
  7. Jul 22, 2020 at 7:46 PM
    #3887
    crashngiggles
    Jared
    Hence the reason why I said it.....
    iK0NiK likes this.
  8. Jul 22, 2020 at 7:48 PM
    #3888
    OdiN1701
    Colorado
    I'm just agreeing with you
    iK0NiK likes this.
  9. Jul 23, 2020 at 4:52 AM
    #3889
    crashngiggles
    Jared
    Island Cruiser likes this.
  10. Jul 23, 2020 at 11:11 AM
    #3890
    weagle22
    weagle22 Well-Known Member
    Josh
    Birmingham, AL
    2018 Blue SR5 DCSB 4x4 2022 Lexus GX 460
    Bilstein 6112s/5100s Deaver AAL
    Tried getting a quote from the local shop here close to me and they said I'd need new UCAs. After reading this thread and coming to the conclusion that I wanted to upgrade my stock suspension to the 6112/5100 I was under the impression it was recommended but not necessary. I am only looking for 2' of lift in the front.
  11. Jul 23, 2020 at 12:41 PM
    #3891
    MemphisTaco
    MemphisTaco Well-Known Member
    Cody
    Nashville TN
    2018 TRD offroad Tacoma
    Kings 2.5 front/rear, ICON RXT, RR2-s, 285/75/17 KO2
    You don’t need them unless you’re lifting over 2 inches. The shop is probably just trying to squeeze a little more money out of you.
  12. Jul 23, 2020 at 2:44 PM
    #3892
    weagle22
    Josh
    Birmingham, AL
    That was my understanding. Guess I'll be putting these on myself!
    MemphisTaco[QUOTED] likes this.
  13. Jul 23, 2020 at 3:01 PM
    #3893
    weagle22
    Josh
    Birmingham, AL
    It's taken me a while to decide what I wanted (first time lifting a truck) so I'm sure they're sick of me asking questions. I've made up my mind and then they throw this at me.
  14. Jul 23, 2020 at 10:43 PM
    #3894
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Helped install 6112's, UCA's today. You don't need UCA's. But, I am really impressed at how much of an improvement they make.
    weagle22[QUOTED] likes this.
  15. Jul 24, 2020 at 9:24 AM
    #3895
    weagle22
    Josh
    Birmingham, AL
    It not something I want to do as of now, but will definitely do later.
    Superdave1.0[QUOTED] likes this.
  16. Jul 24, 2020 at 10:04 AM
    #3896
    crashngiggles
    Jared
    The only thing working against you if you do it later is that you will have to take things apart again to reinstall vs having everything all taken apart already and you will have to get the truck realigned again.
  17. Jul 24, 2020 at 10:29 AM
    #3897
    StealYourFace
    StealYourFace Well-Known Member
    Reno/Sparks
    2020 ORDC MBM
    Can anyone please list the approx. lift from each notch on 6112's? I have looked everywhere.
    I would have guessed assuming the normal spring and no extra weight should be listed somewhere, but I'm not having any luck.
  18. Jul 24, 2020 at 10:30 AM
    #3898
    weagle22
    Josh
    Birmingham, AL
  19. Jul 24, 2020 at 10:48 AM
    #3899
    StealYourFace
    Reno/Sparks
    2020 ORDC MBM
  20. Jul 24, 2020 at 10:48 AM
    #3900
    Superdave1.0
    SoCal
    Nah. The UCA is really easy and doesn't require touching anything else. Remove/cut the upper bolt. Disconnect at knuckle and it's off. Yes an alignment will need to be done again.
    tacocart762 and weagle22 like this.
