Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jul 31, 2020 at 10:52 AM
    #3941
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    100% necessary.....no. will they be very beneficial for better alignment numbers and more articulation.....yes
  2. Jul 31, 2020 at 10:54 AM
    #3942
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    There are some variables here that make this a difficult YES or NO answer.
    -If your lift height is over 2.5" from stock it is highly recommended.
    -If you plan on going off road frequently and/or you are hard on the truck while off road, then YES!
    -If your caster is so far off that it drives bad after setting the toe and camber, then it is recommended.
    It is recommended to get UCA's but not 100% necessary as 6112's maxed out generally don't raise the truck over 2.5" after settling, especially on 3rd gens. My 2nd gen is about 2.75" of lift but I expect it to settle. At this time I have the OEM UCAs because I don't get the opportunity to go off road often and I am pretty gentle and calculated when I do go off road since this is my main vehicle.
    Something to consider if you get UCAs is whether to get a Uni-Ball or Sealed Ball Joint style. If you are in an area that gets snow or heavy rain I would recommend one with a Sealed Ball Joint (like SPC or JBA) as it requires very little maintenance. Uni-Ball ones require regular lubrication and can squeak, though they offer more articulation in the joint itself.
    StealYourFace[QUOTED] likes this.
  3. Jul 31, 2020 at 2:36 PM
    #3943
    sandalglue
    sandalglue Well-Known Member
    BC Canada
    2010 4x4 AC SR5
    Hey all -
    I just ordered a set of 6112/5160 for my 2nd gen. It seems like the third gen folks are running different clips on the front - is that common on the second gens as well?
    Current setup
    - Rock sliders
    - Camper shell
    - Mobtown offroad front recovery bar (63 lbs)
    This is my plan:
    - 600lb springs on either 3rd clip (1.59" lift) or 4th clip (2.15" lift)
    - Stock leafs (thinking of going for an AAL, still deciding).
    Is there anything that I missed? I'm waiting to see if the ECGS bushing is required after the lift.
  4. Jul 31, 2020 at 3:05 PM
    #3944
    crashngiggles
    Jared
    I would do the ecgs bushing at the same time since you will have everything taken apart. The 600lb springs will give you a little lower than those numbers due to the weight. I would go with the 4th clip and with your 2nd gen, add a 1/4" top hat spacer for the lean on the driverside. An aal with the age of your stock springs would be a bad idea. Medium dakars might be a better option.
    E-Paz 732NJ likes this.
  5. Jul 31, 2020 at 3:16 PM
    #3945
    sandalglue
    BC Canada
    2010 4x4 AC SR5
    Thanks for the response. I'm looking to stay at 2" of lift or under so I think I will go with the 4th clip as suggested.
    Luckily the leafs were recently replaced under warranty + my truck only has 40k on the odometer. I will look into the med. dakars
  6. Jul 31, 2020 at 3:33 PM
    #3946
    crashngiggles
    Jared
    If your leafs are newer then you can go with the aal, i just was saying because you had a 2010.
  7. Aug 1, 2020 at 6:08 PM
    #3947
    pejhwm11
    pejhwm11 Member
    Ve
    Hello, does any one how does it take an till Bilstien 6112/5160 and spc uca settle and how much lower.
  8. Aug 1, 2020 at 6:14 PM
    #3948
    tacocart762
    tacocart762 Well-Known Member
    desert55gr
    Santa Clarita Valley
    2017 Tacoma TRD Offroad Dbl Cab Long Box
    1.5in Bilstein 6112 Front,1in Alcan Leaf Rear with Bill 5100's. Battle Armor side step,bull bar, and rear step.
    Ok so advice for you all would be awesome!!
    I have a 2017 4x4 long box double cab. As heavy as can be stock.
    All aluminum skids back to transfer case.
    120lbs sliders.
    And 90lbs front bumper.
    I run the 6112’s at 4 and 5 with the stock 600 lb springs.
    Do you all think that if I just throw a 650Bill spring in there I’ll be good to go at the same height I’m at now? I like where the truck sits as is right now.
    Superdave1.0 likes this.
  9. Aug 1, 2020 at 6:22 PM
    #3949
    overlandozzy1
    overlandozzy1 Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    I’ve decided to go with a fox setup. Non Remote Resivor Coilovers up front, and Remote Resi shocks in the rear. Trying to decide on a leaf pack as I will be adding a bed rack, RTT, maxtrax, a full size spare, 8+ gallons of fuel, a high lift, and a fridge in the rear. Going to go with Aluminum front bumper up front, full aluminum skids, sliders and a roof rack. 650 lb springs up front. Any advice on the leafs?
  10. Aug 1, 2020 at 6:49 PM
    #3950
    MemphisTaco
    MemphisTaco Well-Known Member
    Cody
    Nashville TN
    2018 TRD offroad Tacoma
    Kings 2.5 front/rear, ICON RXT, RR2-s, 285/75/17 KO2
    What?
  11. Aug 1, 2020 at 7:08 PM
    #3951
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    I think he is asking how long until it will settle and how much will it drop when it does.
  12. Aug 1, 2020 at 9:08 PM
    #3952
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I had a very similar set up also 4x4 DCLB. 650lb springs will make the truck handle better with all the extra weight you have. 650lb spring will give roughly .5in lift from where you are now.
  13. Aug 1, 2020 at 10:38 PM
    #3953
    WeDoPullups
    WeDoPullups Well-Known Member
    2020 TRD 4x4
    I’ve decided to go the bling route and go with either Kings or BP51’s haven’t decided yet.
    I have a set of 6112’s and 5160’s still in the boxes. I wanna get what I paid for them and will ship. PM if interested.
    GMAN62465 and E-Paz 732NJ like this.
  14. Aug 2, 2020 at 3:13 AM
    #3954
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Bling would be the King’s. What’s making you change your mind?
  15. Aug 2, 2020 at 5:40 AM
    #3955
    WeDoPullups
    2020 TRD 4x4
    Bling.
    oh and long travel :spending:
  16. Aug 2, 2020 at 7:13 AM
    #3956
    tacocart762
    desert55gr
    awesome thank you so much for the info! that is .5in overall after the springs settle?
    Superdave1.0[QUOTED] likes this.
  17. Aug 2, 2020 at 10:31 AM
    #3957
    Superdave1.0
    SoCal
    Happy for you. I'd delete the 2nd part of your post. Cannot sell anything on this site until you have 50 posts.
  18. Aug 2, 2020 at 10:36 AM
    #3958
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Thinking of going to 6112's and 5160's in the rear then selling my pavement princess adjustable Kings. I have 650 springs and I'm just about 3" inches front with armor. What springs and setting would I need with these top keep me where I am?
  19. Aug 2, 2020 at 10:36 AM
    #3959
    Superdave1.0
    SoCal
    Every set up is different, but yes after couple weeks of settling.
    tacocart762[QUOTED] likes this.
  20. Aug 2, 2020 at 10:37 AM
    #3960
    Superdave1.0
    SoCal
    With armor, 6112's likely won't get you to 3". They are really a 2.5" lift coilover.
