Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jan 29, 2017 at 12:27 PM
    #401
    Laoturk
    Laoturk Well-Known Member
    Huntington Bch
    2013 tacoma LB
    285-65-18 I will get pictures for you.
  2. Jan 29, 2017 at 12:28 PM
    #402
    Laoturk
    Huntington Bch
    2013 tacoma LB
    No rubbing also.
  3. Jan 29, 2017 at 3:14 PM
    #403
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    @avitaco Where are the third gen 6112s?
  4. Jan 29, 2017 at 3:29 PM
    #404
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    I'm about to order new suspension parts this week.
    I'm looking to get the 6112 for the front and set them at the 4th notch.
    And in the rear, I was going with Dakars and probably the 5100 B110 shocks.
    Anyone have experience with this setup?
    I have 5100s in the front and rear now, front on the 1.75" mark and Icon 3 leaf AAL in the rear (had factory 3 leaf and removed overload when adding these 3). The rear is sagging now with the new ARE Z Series and Pelfreybilt Rear Bumper.
  5. Jan 29, 2017 at 3:31 PM
    #405
    DrFunker
    DrFunker Well-Known Member
    You are doing the B110 for the extended length?
  6. Jan 29, 2017 at 3:33 PM
    #406
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    If they're needed with the lift of the Dakars. If not, I'll replace my current regular 5100s with another set
  7. Jan 29, 2017 at 3:35 PM
    #407
    DrFunker
    I have 5125s in the rear with modified (top overload out) Dakars. They are great together.
    lynyrd3 likes this.
  8. Jan 29, 2017 at 3:44 PM
    #408
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    That's right, I forgot about that shock
  9. Jan 29, 2017 at 3:45 PM
    #409
    DrFunker
    The valving is better than the 5100.
    There may be an extended version too. Not totally sure on that though.
  10. Jan 29, 2017 at 3:46 PM
    #410
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Ok thanks.
    DrFunker[QUOTED] likes this.
  11. Jan 29, 2017 at 3:46 PM
    #411
    DrFunker
    :thumbsup:
    Good luck with the upgrade.
  12. Jan 29, 2017 at 3:50 PM
    #412
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Thanks!
  13. Jan 29, 2017 at 4:19 PM
    #413
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    DrFunker and Crom like this.
  14. Jan 29, 2017 at 4:55 PM
    #414
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes. I have that setup and it works very well for my uses.
    Which model 5125 are you running? There are like 20 variations.
    http://www.bilsteinus.com/uploads/tx_templavoila/5125_Applications_01.pdf
    The 5125 will specify valving in the specs, it's a universal series shock.
    Also there is no way to make a direct technical comparison of the valving between the 5100 and 5125 using Bilstein's literature. The reason for this is because Bilstein does not publish valving for 5100 shocks, because they are "custom tuned" for each vehicle. Same goes for 6112.
    Just went though all this earlier this month
    lynyrd3 and DrFunker[QUOTED] like this.
  15. Jan 29, 2017 at 5:12 PM
    #415
    Crom
    Nick
    San Diego, CA
    Millions
    6112 update.
    My second wheeling adventure. Probing further the characteristics of the 6112's during six hours of seat time.
    • Technical crawling
    • Fast Desert Running
    • Emergency evasive maneuvers
    • Vehicle stability in extreme wind at interstate speeds
    I'm extremely pleased with the 6112's performance on pavement and especially in the dirt. I air down to 19 PSI and the ride is very nice. If I could sum up my experience with these shocks in one sentence it would be "Comfort and control on and off-road"
    The 6112's are light years better than my old 5100/885 setup. So much so, I wouldn't recommend them anymore. Anyone comes asking me, I'm gonna tell them to save up for the 6112's For the money, can't go wrong. And even though my rig is purpose built off-road, I don't think I'd trade the 6112's for the 8000's series they got now. Very, very pleased with my new front end.
    TacomaOC714, Ruffus, ARCOVT16 and 7 others like this.
  16. Jan 29, 2017 at 5:14 PM
    #416
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Checking it out now, thank you.
    Great build sir!
    What setting do you have the 6112 at?
    In the rear, those isolators you had installed on the springs, do you have them on both ends of each spring?
    For weight I have a DCSB with a ARE Z series, a tool box, high lift, and Pelfrey rear bumper. I will probably be getting a hybrid front sometime in the summer... do you see the 6112 at 4th notch and Dakar with no AAL sitting even?
  17. Jan 29, 2017 at 5:16 PM
    #417
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    When I looked on Wheelers to order 6112s, they say they can be assembled with 600lb, 650lb, or 700lb springs. Obviously the heavier springs will give a stiffer ride, but any idea about ride height? Is it possible to use the 650lb spring on a lower setting and actually get a better ride than the 600lb spring on a higher setting?
    I currently have 650lb Eibach springs on 5100s and am very happy with them. I'm interested in getting the 6112s with the 650lb springs, but have no idea what effect they have on lift, if any, different from the 600lb.
    Anyone have experience with the heavier springs?
    SoJersey likes this.
  18. Jan 29, 2017 at 5:27 PM
    #418
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks.
    Yes isolaters on each ends.
    The Dakar pack was redesigned. New design has isolators now from what I've seen. If you haven't bought yet. I'd consider confirming details prior to shipping.
    With shell and steel bumper, I'd get the AAL for the Dakar.
    6112 at 3 on driver, and 2 on passenger.
    I tried setting 4 and did not like it. Too much lift for me. I like my truck to have some rake, and when I'm loaded out heavy for a trip it levels out.
  19. Jan 29, 2017 at 5:45 PM
    #419
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Thank you.
    Good to hear they may have isolators now, I'll be sure to check.
    I'm not a fan of a lot lift either, I'll have to see what setting I want to go with.
    Your UCAs... why did you go Ball joint over Uni?
  20. Jan 29, 2017 at 6:05 PM
    #420
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Chiming in here...
    I talked with Camburg before purchasing mine. The recommendation was since I live where it rains (and we have mud) the ball joint was a better choice.
    The uni-balls would work in a harsh environment, but they would squeak and require more maintenance than if they were run in the desert.
    Crom likes this.
