Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Sep 20, 2020 at 3:33 AM
    #4201
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Thanks for this. All the more reason i need to be sure before i install. I am swapping the 700# coils to 650s but time would be the same. Thanks again
  2. Sep 20, 2020 at 11:33 AM
    #4202
    Stadoo
    Stadoo Member
    Austin, TX
    2015 AC 4x4
    Did anyone end up installing a diff drop with this? Or a carrier bearing drop? Not sure if its needed
  3. Sep 20, 2020 at 1:42 PM
    #4203
    weagle22
    weagle22 Well-Known Member
    Josh
    Birmingham, AL
    2018 Blue SR5 DCSB 4x4 2022 Lexus GX 460
    Bilstein 6112s/5100s Deaver AAL
    I did neither. Was told I didn’t need a diff drop as it really didn’t do anything and was waiting to see if I got any vibes before carrier bearing drop. Did buy shims in case too. Also bought ECGS bushing and tool. Haha
  4. Sep 20, 2020 at 1:53 PM
    #4204
    AllTacosFloat
    Boston ish
    I did carrier bearing drop with 2" lift and it made the vibes go away. I didn't do diff but plan on it to help the angles
    crashngiggles likes this.
  5. Sep 20, 2020 at 6:00 PM
    #4205
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I just lifted a Tacoma this morning. Took me 2.5 hours to remove, disassemble, reassemble, then install 5100's. Same process for 6112. If it takes you 4-6 hours. you are doing something wrong.
    pahaf likes this.
  6. Sep 20, 2020 at 6:07 PM
    #4206
    weagle22
    Josh
    Birmingham, AL
    I tend to agree. Shouldn’t take more than 3 tops.
  7. Sep 20, 2020 at 8:06 PM
    #4207
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Not going to argue that you can’t do it faster. Shop quoted 3 hours so if you done it before and have a well equipped garage, than I’ll believe 2.5 hours is feasible. I didn't do it wrong, but never did this particular task, had no reason to rush, so I took it slow to do it right and inspect other items while everything was apart. Since the question was asked by someone who apparently also never done it before and being unaware of their experience I gave my perspective and now they have yours.
    Castle 4, se_matt, MtnFisher and 2 others like this.
  8. Sep 20, 2020 at 8:57 PM
    #4208
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Just keep in mind, that if you add a diff drop, you will not be able to ever mount an aftermarket front skid plate.
    iK0NiK likes this.
  9. Sep 21, 2020 at 2:33 AM
    #4209
    AllTacosFloat
    Boston ish
    Thank you sir, kit comes with it but I'd rather have full skid and spare parts. Thanks for saving me from myself
    crashngiggles[QUOTED] likes this.
  10. Sep 22, 2020 at 3:26 PM
    #4210
    Buttermilker
    Buttermilker Well-Known Member
    Danny
    Bishop, CA
    '16 ACOR
    Sierra pinstriping Eibach stage 1, 3 leaf AAL
    Does anyone know why an access cab shouldn't use the 6/5 setting? I've read through the first 50 or so pages of this thread and didn't see it mentioned.
  11. Sep 22, 2020 at 4:28 PM
    #4211
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    My guess would be the weight difference up front from the extra doors, seats etc or an extended plastic box.
    The frame is the same. Well, on the short box anyways
  12. Sep 22, 2020 at 5:08 PM
    #4212
    crashngiggles
    Jared
    Due to it being less weight you front end would be so high that you front axles would be at a crazy angle. You would go though front axle boots every 3 months.
  13. Sep 24, 2020 at 7:48 AM
    #4213
    JK
    JK Well-Known Member
    Northern California
    2018 Super White Tacoma TRD Off Road
    Headstrong's Bilstein 6112/5160 kit, set on the 6th/5th clip and I'm happy with it, though I don't really have much to compare them with, besides the stock OR suspension that was replaced. Wishing I would have gone with a taller tire. 265's look a little small now lol.
  14. Sep 24, 2020 at 10:04 AM
    #4214
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
    I have read through this thread and there isn't a lot of talk about towing and leaf pack choice with the 5160s. I have a camp trailer with 3500 GVWR and a tongue weight of 500lbs all loaded up. With the stock suspension I have about 1.5” sag with the trailer hooked up. I will be getting sliders and skids soon after the lift, and the SSO front slimline plate bumper and winch in the future. I will probably only go to 265/75R16 tires to avoid the need to re-gear. I’m thinking to upgrade to the Bilstein 6112 on 3/2 with 650lb coils up front for 1" lift, and the 5160 in the rear. I want to be close to level with the trailer, and another 500-600lbs of passengers and cargo in the truck (me and the wife, ice chest, 2 bicycles, maybe some luggage. For the leaf pack I'm trying to decide between OME Dakar HD, or Deaver U402 stage 2, or Icon RTX stage 3. I am hoping to not have a WDW so I can take some fire roads without needing to disconnect the WDH and then having the rear sag when I need the clearance the most.
  15. Sep 24, 2020 at 11:24 AM
    #4215
    crashngiggles
    Jared
    Let me refer you to something that I wrote a couple of pages back.
    https://www.tacomaworld.com/threads/bilstein-6112.421995/page-210#post-24191839
    It is one thing to be towing all of the time or just once in a while. While a leaf pack will offer help with tongue weight, it will also give you lift in the rear all of the time without towing anything. An Icon RTX might be good then you can always stay on the stage 2 and move up to stage 3 if you are towing something and then back again when not. It will be a lot of work though. Maybe a DAKAR med with airbags as a better option.
  16. Sep 24, 2020 at 11:58 AM
    #4216
    Superdave1.0
    SoCal
    The title of this thread is 6112, which is on the front. The rear end has so many options that can be paired with 6112 fronts.
    For your situation my vote is OME Dakar Heavy. Cost effective and will handle loads amazingly better than stock or aal.
  17. Sep 24, 2020 at 12:08 PM
    #4217
    CemenTRDgen
    Joshua
    Concord, CA
    Yeah, I read that and came to the conclusion a full leaf pack is my best option for towing and moderate off road without the trailer (air bags are a no go)
  18. Sep 24, 2020 at 12:15 PM
    #4218
    CemenTRDgen
    Joshua
    Concord, CA
    I understand the 6112 is on the front, but the entire thread is filled with what to pair it with in the back: 5100s, 5160s, AAL ect.. so I didn't think it out of place to ask here. Also this is an active thread, and I thought I would get a response. Thank you by the way, as I am leaning toward the OME Dakar HD for the same reasons you mentioned. I don't mind the additional rake of lifting the front 1" and the rear 2", and I'm not looking for a plush ride so the HD pack, while stiff when empty, wont bother me. I could take a leaf out to make it a med pack if the HD is really awful.
    AllTacosFloat and iK0NiK like this.
  19. Sep 24, 2020 at 12:34 PM
    #4219
    MrNineAndAHalf
    MrNineAndAHalf Apocolypse Taco
    Texas
    2013 ACLB TRD Sport Taco 4x4
    Bilstein 6112's & 5160's with OME MD Dakars
    Anyone here put 6112s & 5160s and/or Dakar Medium duty leaf springs on a 2nd gen (or 3rd) Access cab? I just purchased a kit (6112s with the 650lb spring on #1 setting, not looking for much lift & really want a comfy ride) and I'm still curious what kind of lift I'll get in the front & the rear.
    Talked to a few people and everyone mentions the Access cab gets lifted way more than the double cabs because the access cabs are so light weight. I currently don't have any additional weight but plan on adding a bumper & winch up front & bed/headache rack and maybe rooftop tent or camper shell in the back.
    Trying to soak up as much info as possible! Thanks!
  20. Sep 24, 2020 at 3:42 PM
    #4220
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    Anyone know of 6112s in stock anywhere? @HeadStrong Off-Road, You have an ETA on these by chance?
    I’m about to pull the trigger on the Elka 2.0s or the 6112/5160s. Can’t make up my mind! :frusty:
