Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jul 20, 2021 at 8:46 AM
    #4941
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
  2. Jul 20, 2021 at 9:01 AM
    #4942
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    great set up :thumbsup:
  3. Jul 21, 2021 at 9:23 PM
    #4943
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    What seems to be the general consensus on adding a very conservative spacer(s) paired with the 6112/5160's to add just a bit more height?
    Perhaps somewhere around a 1/2" spacer on front for an additional inch. What does that come to with 6112's on max, 3" to 3.5" total maybe in the front?
    What about a 1" block in the rear paired with the 5160's and an OME full pack? I believe their pack yields about 2.75" but would be nice to keep the rear a bit higher than front.
    JBA UCA's would be installed as well.
    Honest thoughts? Experience?
    TIA
    TacoGuySlo10 likes this.
  4. Jul 22, 2021 at 1:02 AM
    #4944
    TacoGuySlo10
    TacoGuySlo10 Well-Known Member
    Tristan Torres
    san luis obispo
    2019 MGM trd off road
    hey man, that’s what i’ve been thinking of doing. the 6112s definitely settled and i want to gain that 1inch back. i think i’ll be ordering the 1/2 spacer soon for both sides hoping to gain some lift. let me know what you do.
  5. Jul 22, 2021 at 4:21 AM
    #4945
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    1. The spacer in the front is generally used for the 2nd gen for the spacer lean, the 3rd gen is set with offset notch settings like 5 on the driver side and 4 on the passenger side.
    2. On your 3rd gen you wouldn't need a spacer in the front.,
    3. Your 3rd Gen is already 1 inch higher than a 2nd gen from the factory so at the max, it would give you another 2 more inches.
    4. I have the wheelers 1/2 spacer block for the driverside lean in the rear for years with my OME DAKARs. I honestly do not know why there are not a lot of people that do this. I can personally recommend it. 5. I have had JBA's for the past 3 1/2 years.......I love them.
  6. Jul 22, 2021 at 6:11 AM
    #4946
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    I don’t think we’re on the same page with the front. The spacer would be to boost the lift in general, not just for the taco lean. It would be a 1/2” spacer on both fronts with the 6112’s on 6/5 notch.
  7. Jul 22, 2021 at 6:42 AM
    #4947
    crashngiggles
    Jared
    Just be aware of your CV angles if you plan on doing that. Do you also have the ECGS Bushing in?
    71tattooguy likes this.
  8. Jul 22, 2021 at 8:38 AM
    #4948
    TacoGuySlo10
    Tristan Torres
    san luis obispo
    i think i’ll be doing that, 1/2 on both sides. the 6112s settled and i don’t think adding the spacer will be a huge problem….
  9. Jul 22, 2021 at 8:39 AM
    #4949
    TacoGuySlo10
    Tristan Torres
    san luis obispo
    Has anyone here done this? a 1/2 spacer in bother sides, the 6112s are set at 6/5. thanks for the help guys! just trying to get back up to 3 in
  10. Jul 22, 2021 at 9:38 AM
    #4950
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I'm in a 2nd gen, I did 1/4" spacers on each side and put the clips one notch down from the top, 4th notch on each side.
    I think you should do it, 1/2" spacers or go to bigger springs.
    Sounds like you want a lot of lift.
  11. Jul 22, 2021 at 9:46 AM
    #4951
    TacoGuySlo10
    Tristan Torres
    san luis obispo
    i’d go for bigger springs but i don’t think i’ll be getting a front bumper… thanks for the help boss!
    TacoEspecial[QUOTED] likes this.
  12. Jul 22, 2021 at 10:21 AM
    #4952
    CROM123
    CROM123 Love my Tacoma
    Garland
    Virginia
    2010 Tacoma 4x4 2.7 reg.cab. 27-k miles
    265/75/16 coopers at3 4s
    I am getting 6112's for my 2010 regular cab Tacoma will I need new upper control arms? I just got 5110's for the rear and cannot believe the difference (wow) also the control is much better I am very impressed.
  13. Jul 22, 2021 at 2:16 PM
    #4953
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    plus you better check full droop because your coils will hit the control arm
  14. Jul 22, 2021 at 3:48 PM
    #4954
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    Access cab here. Anyone have the SSO slimline hybrid bumper? I expect one in a few weeks. The one that just replaces the front valance. I have my 6112's set to 3/4 notch with a 1/2" spacer on both sides. Had some issues getting lift for some reason on that set up with just a 1/4" spacer so bumped it up a bit. Anyway, I ended up with around 2" of lift but it has settled. Curious as to how much I should expect it to drop with the new bumper. SSO says it only weighs 40lbs but Im trying to decide if I should bump up my springs to 650#. Not really interested in bumping up the preload since I can't go more than another notch anyway. Im probably overthinking it because I do that...
  15. Jul 22, 2021 at 9:52 PM
    #4955
    WestCoastMango
    WestCoastMango Well-Known Member
    Anthony
    Vancouver Island
    2019 DCSB
    Anyone got specs on the 6112. Looking to get numbers for the collapse and extended to see if it's worth upgrading to kings 2.5 extended shocks.
  16. Jul 23, 2021 at 6:29 AM
    #4956
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    anyone know of an online retailer that sells 6112s assembled with a 650lb spring?
  17. Jul 23, 2021 at 8:16 AM
    #4957
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Check shocksurplus.com I ordered my 6112 assembled from them. I did the regular spring though. I'm sure they will work with you. Build a cart and then email a snapshot of it to them with and questions. They were very helpful
  18. Jul 23, 2021 at 8:23 AM
    #4958
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    Only if you expect to get 2.5-3" of lift.
    I just did my 2010 with 130k. I redid the front end as a whole because of age. 6112s 1st notch, LCAs, cam bolts, inner/outer tie rods, and all the rusty nuts and bolts. I still need to do the CV.
  19. Jul 23, 2021 at 8:23 AM
    #4959
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    good to know, thanks for the tip.
    tattooedsnake[QUOTED] likes this.
  20. Jul 23, 2021 at 3:26 PM
    #4960
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    I haven't pulled the trigger on any of it yet, but yes. Will do ECGS bushing and JBA UCA's. Just looking for the safest way to get a full 2.75-3" of lift all around (and don't want it level)
