Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jul 30, 2021 at 6:28 PM
    #5001
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Your eyes are correct - I got about 2 inches of lift.
    If you relook at the chart you will see it says #3 = 1.59inches on a 2nd Gen. So, it was reasonably close. I had expected it to settle a bit more and it's pretty much held.
    Good luck. I'm quite pleased with them and my medium Dakars. Headstrong sells a full kit of 6112/5160 and Dakars.
    Strongly recommend you have whoever you buy the 6112's from that you have them assemble them.
    HandOfGod likes this.
  2. Jul 30, 2021 at 9:04 PM
    #5002
    Cricket-0
    Cricket-0 Well-Known Member
    Whoops! I forget that 2nd gen #3 gets that much lift on #3.... #6 gives 3rd gen 2" of lift, and many people say it is extremely stiff.. Trying to decide which route to go now.
    My plan was to have the vendor build the 6112's... Out of curiosity why do you also suggest it?
  3. Jul 30, 2021 at 10:16 PM
    #5003
    taco_rhyno
    06 DC 4x4 Sport
    The shock body diameter is so big and spring clearance so limited that hand tool spring compressors won’t work / are really iffy.
    So, if you don’t buy them assembled you end up having to find and then pay a shop anyway. I made that mistake.
    Simple answer, buy them assembled.
    Cricket-0[QUOTED] likes this.
  4. Jul 31, 2021 at 12:23 AM
    #5004
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    For the Icon AAL. Did you keep the overload in or out?
  5. Aug 1, 2021 at 6:55 PM
    #5005
    corprin
    corprin Well-Known Member
    corprin
    I’ve been running the Baja kit w/touted spacers for a few years now. Found two failed nylocs in valley of the gods, mangled the top threads trying to get them tightened enough to get me home. Lower bushings and top hats are shot, and need to destroy parts to fix.
    So. I’ve been digging in this thread and the search is vague lots of conflicting info. Need to order new front shocks ASAP.
    Anyone know the actual differences between the 6112 vs pro vs Baja in terms of valving? Debating which version I’ll replace my current Baja with.
  6. Aug 4, 2021 at 7:10 PM
    #5006
    xKryToN
    xKryToN Well-Known Member
    2019 TRD OFF ROAD
    Bilstein 6112/5160 ICON 1.6 AAL Tacoma TRD Pro Wheels 285 75 16 KO2
    i kept it in
  7. Aug 8, 2021 at 10:31 AM
    #5007
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Have you seen the new 8100 Bilstein's. Wowza!
    71tattooguy likes this.
  8. Aug 8, 2021 at 11:18 AM
    #5008
    Maxx
    Maxx Well-Known Member
    Tocamo[QUOTED] likes this.
  9. Aug 8, 2021 at 11:56 AM
    #5009
    corprin
    corprin
    Yeah. You can PayPal me the additional $1k to get them onto my truck!
  10. Aug 9, 2021 at 8:40 PM
    #5010
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Sorry. Newbie chiming in here guys. Maybe this info will be helpful to some.
    I have a stock-ish 2015 trd off road DCSB. No extra weight beside a camper shell.
    I bought the 6112 used already assembled with 650lbs springs. I rode on this set up for….1 year and 1 month, and it was ok. I didn’t love the ride quality. Off roading was fine but still bumpy. Always had to air down to 14-15psi.
    skip forward to today. I installed the 600lbs coil springs. What a difference. Truck feels so much smoother. And I’m maxed out on the perches. 6/6 on both sides with 1/4” spacer on the drivers side.
    so my advise is…..get the right spring rate. I honestly didn’t love the shocks with the 650lbs spring rate, but now….wow
  11. Aug 9, 2021 at 9:04 PM
    #5011
    corprin
    corprin
    No armor/bumper/winch/etc, yea 650lb/in are too hard.
    pahaf[QUOTED] and 71tattooguy like this.
  12. Aug 10, 2021 at 2:37 PM
    #5012
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    FWIW 600lb springs 2” or so of lift. No complaints here.
    grayfrog likes this.
  13. Aug 12, 2021 at 12:12 PM
    #5013
    coopsauce
    coopsauce Well-Known Member
    Denver
    2019 TRD OR
    Hey y'all,
    I recently installed 6112/5160 w/ Wheeler's 3-leaf AAL. Front is set to 6/5 passenger/driver. 2019 TRDOR DCSB.
    When I first installed them, truck was just about dead-nuts level. Now, 3-ish months later, the rear has settled and I'm nose high.
    Has anyone else experienced this? Should I keep waiting, or go ahead and lower the front a notch each side?
    FWIW - I don't have a bumper/winch (yet), and unlimited alignments so I'm not worried about having to keep doing alignments.
  14. Aug 12, 2021 at 12:25 PM
    #5014
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Add overload if you don’t have it in will add 1/2” of lift.
  15. Aug 12, 2021 at 12:27 PM
    #5015
    coopsauce
    Denver
    2019 TRD OR
    Yeah, forgot to add that I took them out, based on everything I read about it making it a rough ride.
  16. Aug 12, 2021 at 12:32 PM
    #5016
    71tattooguy
    Dino
    Petaluma , Ca (707)
    No ruff ride. Overload engages when leafs can’t hold weight then compress and overload holds leafs
    Fedup13 likes this.
  17. Aug 12, 2021 at 12:36 PM
    #5017
    coopsauce
    Denver
    2019 TRD OR
    Interesting, thanks man. I'll give that a shot
    71tattooguy[QUOTED] likes this.
  18. Aug 12, 2021 at 6:54 PM
    #5018
    lukerutherford
    lukerutherford Well-Known Member
    Luke
    San Marcos, CA
    Following. I have the bilstein 6112/5160 plus icon 1.5” aal on the way. I have a 2021 TRD off-road DCLB. Been debating on putting the front at 5/4 or 6/5.
    Superdave1.0 likes this.
  19. Aug 12, 2021 at 6:56 PM
    #5019
    Bishop84
    Bishop84 Well-Known Member
    Interesting, I just did a 4runner and it was 7/5 or 6/4 2 clips seperation.
  20. Aug 15, 2021 at 10:02 AM
    #5020
    Vorra65
    Vorra65 Well-Known Member
    So finally have all my pieces from wheelers. I’m thinking about leaving the overload in when I do the rear AAL on my 2021 DCLB. On my 2014, I left it out …but I had adjustable Icons in the front - so it was easy to change the rake after it all settled.
    71tattooguy, you left yours in right ?
