Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Nov 2, 2021 at 6:44 PM
    #5161
    Nymbus
    Nymbus Well-Known Member
    2021 TRD Offroad DCSB Cement 4x4 AT
    In my opinion it does ride better than stock. I know some people say that it rides stiff but I don’t think it does. For me it’s in the middle of stock ride and firm. Kind of hard to explain but its definitely a comfy ride.
    CLVol1255 and 71tattooguy like this.
  2. Nov 3, 2021 at 4:19 AM
    #5162
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    I used to ride 5/5 with a 1/4” spacer on DS. I moved them up to 6/6 with the spacer and didn’t notice a difference. Gained some front lift back from settling and it looks great!
    4xThad[QUOTED] and 71tattooguy like this.
  3. Nov 3, 2021 at 7:17 AM
    #5163
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    are you at about 2.5" of lift up front?
  4. Nov 3, 2021 at 12:40 PM
    #5164
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    I’m at 6/5 notches and 600# spring with half inch spaced on driver side and 1/4” on passenger side and I’m right at 2.3” lift from stock after almost 10 days since install
  5. Nov 3, 2021 at 1:06 PM
    #5165
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    6/5 with take care of the lean. So if I understood you put 1/2” spacer driver 1/4” passenger. I’m 6/5 for lean then 1/4” spacer driver / passenger to get back lift from armor. Level side to side.
  6. Nov 3, 2021 at 4:53 PM
    #5166
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    That’s correct I have 6 driver side 5 passenger side. 1/2” driver side 1/4” passenger side. I am right at a 1/4” higher on driver side after measuring so I would’ve been level with 1/4” both sides. I didn’t realize that when I installed
    71tattooguy likes this.
  7. Nov 4, 2021 at 9:43 AM
    #5167
    RedDeadTaco
    Andrew
    Aiken, SC
    I also have the 650lb springs so I have about 2.75”. I can re measure if you need exact measurements
  8. Nov 4, 2021 at 10:05 AM
    #5168
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    hows it ride with the 650's? im debating on going with 600lbs, 6/6 and a spacer or going 6/5 with a 650 spring.
    treyfive and 71tattooguy like this.
  9. Nov 4, 2021 at 10:21 AM
    #5169
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    I've got 650s at 4/5 and the ride is fantastic imo, but I prefer a "stiffer" ride
  10. Nov 4, 2021 at 10:51 AM
    #5170
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    you at 2.5" or a little less?
  11. Nov 4, 2021 at 11:05 AM
    #5171
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I’m running 600# that the 6112 kit comes with at the moment
  12. Nov 4, 2021 at 1:41 PM
    #5172
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
  13. Nov 4, 2021 at 1:43 PM
    #5173
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    memario1214 and 4x4cajun[QUOTED] like this.
  14. Nov 4, 2021 at 2:35 PM
    #5174
    r2pinter
    r2pinter Well-Known Member
    Green Bay, Wisconsin
    2017 Tacoma TRD Sport
    4x4cajun[QUOTED] likes this.
  15. Nov 4, 2021 at 2:55 PM
    #5175
    4x4cajun
    Fredericksburg, VA
    2014 Limited 4x4
    Ok thanks
  16. Nov 4, 2021 at 2:55 PM
    #5176
    4x4cajun
    Fredericksburg, VA
    2014 Limited 4x4
  17. Nov 4, 2021 at 3:15 PM
    #5177
    Brownmatthall
    2016 TRD OR DCSB
    Forgot to take before measurements but id say in the neighborhood of 2-2.5
  18. Nov 7, 2021 at 4:22 PM
    #5178
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    1. Ok, first I have to say this just to get it out of the way......I still love my 6112's that I put on 3 1/2 years ago.....no regrets and I would do it again......
    2. My setup: I have the bilstein 650lb springs with the settings at 4 on both with a 1/4" top hat spacer on the driverside. Dirt King lowers and JBA uppers. I am also running 285-70-17 toyo open country AT3's. For weight, I have a front bumper with winch, a skid plate trio, a X2 Power AGM battery,, and sliders.
    3. My plan for today: to move my clips from 4 to 5 on both sides for a little more height, to replace my top hats, and to replace my lower shock bushings... ( huge props to @Superdave1.0 for the part numbers and the "just do this" directions to change them out).
    4. Parts:
    a. The top hats that I ordered - https://www.amazon.com/gp/aw/d/B00C7S0KA8?ref=ppx_pop_mob_b_asin_title
    b. The lower bushings that I ordered from McGeorge Toyota - 90389-A0001 (put them in the freezer at least 48 hours before you decide to press them in and don't pull them out until the last moment.
    c. The press that I fought so hard not to buy and tried literally EVERYTHING ELSE, before I broke down, bought it, and used it (if you have someone that has a press just use theirs, if not, just buy one.....it will save you 3 hours, tons of swearing and hours of regret for not listening - d. A 1-1/8" deep well socket to use to push in and out the bushing....it really is the perfect size.
    5. The hell that was my day living in the northeast:
    Ok, the day started with a brisk 24° day out in my driveway, all the tools (that I thought I would need) next to me, and hope in my eyes. I hit the top hat studs and Nuts with PB blaster each day for a week to prepare. I have had issues taking off the rear nut on another members truck, where it wasn't sprayed, and the nut was so frozen that it stripped the stud inside the top hat (THAT WAS A REALLY BAD DAY). So the nuts came off ok today and the I was able to take the shock out fine. The 650lb springs are a BEAR especially with the 60 mm shock body, so we used a pair of the best spring compressors that we could find and compressed the middle four coils since the higher end compressors will not fit around the 60mm shock body.
    The hell starts now.......the top hats were.....let's just say....very rusted and falling apart. I was a little surprised at just how bad the needed replacing. After I got the spring out, then I started to work on the spring seat. Ummmm.....yeah....it was pretty much seized to the shock body (aluminum to aluminum which made no sense to me). We had to rig 2 6x6's on cinder blocks to hold the shock body, while putting a 2x3 inch ingut of aluminum that I had lying around on top of one side of the spring seat, hitting ingut with a 3 lb hammer....hit and turn, hit and turn, hit and turn, just to move the spring seat millimeter by millimeter, to finally getting it below the last clamp ring hole. This also involved cleaning the shock body and using tons of pb blaster btw. Then finally cleaning out the last groove, and moving the split ring down the last groove (which moving the split ring was a lot easier than I thought). Then finally putting the spring back in attaching the new top hat.
    Now on to the lower bushings.......Holy fuck ....they were fucking destroyed! I mean I really didn't notice them until I took out the shock, but this is most certainly the biggest failure point of these shocks. For anyone having a lot of weight like me or using 650lb springs (or even, God forbid, 700 lb springs, which are not recommended at all for this shock due to premature failure) check the lower shock bushings AT LEAST once every 6 months. Soooooo.....now onto pressing the old ones out and pressing the new ones in. Ok, I really tried the cheapest way I could do it. I tried to set up a bottle jack under the weight of the frame......a 1/2 grade 8 carriage bolt with washer setup through the 1 1/8" deep well socket.....searching YouTube for easy ways without using or purchasing a press.....Well just let me stop you there. There isn't one. Just bite the bullet, go to harbor frieght, and get a 12 ton press or go over to a friend's house that has one. I wasted so much time trying to get them out....heat and all, and even if I did get them out.....I was not going to get them in the same way. We ran to harbor frieght, put the press together (took 5 minutes) and it literally took 2 minutes to get the old ones out and 3 minutes to get the new ones back in. @Superdave1.0 showed me this YouTube video and it really is the easiest thing to use the get them in and out.
    https://youtu.be/oAVdOhvpBbg
    Start at the 1:30 mark
    Afterwards, my truck now rides like the shocks were brand new again.
    Moral of the story.....
    1. even if you think you have the right tools the first time....listen to others that have done it and just spend the money to get the right stuff even if you think you want to be cheap....Don't.
    2. Really.....really.....really.....watch the lower bushing for failure, especially if you have a lot of weight and/or wheel your truck. I was BLOWN AWAY at how bad the were, but didn't really notice until I took off the shock because the damage was being covered up by the lower shock mount tabs. I would recommend changing them out every 2 to 3 years.
  19. Nov 7, 2021 at 5:12 PM
    #5179
    Brownmatthall
    2016 TRD OR DCSB
    Same bushings as before or a different compound? Definitely gonna keep an eye on mine
  20. Nov 7, 2021 at 5:14 PM
    #5180
    crashngiggles
    Jared
    The part numbers that I put in there is the Toyota OEM equivalent of the TRD PRO ones which are the exact same ones that bilstein uses for their 6112's. They really are a fantastic shock, just start checking the lower bushing after 2 years.
    Brownmatthall[QUOTED] likes this.
