Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Mar 2, 2022 at 9:23 PM
    #5441
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  2. Mar 2, 2022 at 9:37 PM
    #5442
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    you realize you just purported another opinion before you could even had enough time to watch the two videos I provided
    the second video is 15 mins and you replied in 5 mins after I posted.. LOL
  3. Mar 2, 2022 at 9:40 PM
    #5443
    crashngiggles
    Jared
    I was actually responding to the statement that your 2021 AC has done more wheeling then my 2013 dclb
  4. Mar 2, 2022 at 10:41 PM
    #5444
    Fast1
    Minneapolis, MN
    I've had 3 Tacomas with over 475,000 miles of use over the last 22 years and a good percentage of those off-road. That 21 AC may have more off-road miles than yours too..
    Assumptions make ass-holes
    and for the record,, my 1st gen with 211,000, my 2nd gen with 236,000 and 3rd gen with 26,000 have never worn out the OEM ball joints on the upper control arm with aftermarket front suspension installed. Last offroad stint in the 3rd gen covered near 1000 miles on the Colorado back country discovery route with some Moab stuff.
    https://theadventureportal.com/the-colorado-backcountry-discovery-route/
    21 in action
    244405520_10223519955319994_681737752280_b68d18cfe389bcdf34e7efc3d29257709d7c2e68.jpg
    243564962_10223505671322903_247412861700_9a366fa6b8089abfa77614f94c0cf3aa10f285cf.jpg
    244053369_10223498558545088_904500030248_708b6a915e3756f5f2968d6ae40d3ef3f9318609.jpg
    242912539_10223481118869107_920378048134_4033de5874aa8a97d07b0414dbccdde9084d622e.jpg
    some 2nd gen
    This was back in 2001 with the 1st gen
  5. Mar 3, 2022 at 4:44 AM
    #5445
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  6. Mar 3, 2022 at 6:32 AM
    #5446
    Maxx
    Maxx Well-Known Member
    1. Your picture is wrong. The blue line would be higher caster and in real life the wheel moves forward and back in the wheel well based on adjustments made from the top and bottom. That picture assumes the geometry is changing but the wheel position is not, that is not reality. When you increase caster using the UCA, you are moving the wheel back in the wheel well and reducing clearance. If you use the LCA to increase caster, you’re moving the wheel forward to create more clearance.
    2. Show me people killing stock ball-joints, they aren’t.
    3. Yes, you did.
    4. All aggressive driving puts extra stress on ball joint, on or off road. No one is killing ball joints though.
    For the 1,000th time. More caster does not equal more clearance without understanding where you’re getting that caster. Stop spreading bad info.
  7. Mar 3, 2022 at 11:47 AM
    #5447
    71tattooguy
    Dino
    Petaluma , Ca (707)
    All I know is I’m loving my set up :cheers:
  8. Mar 3, 2022 at 1:14 PM
    #5448
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    There’s no point in arguing. Tbh just get new UCA’s. Your changing factory geometry. If stock work for your application, just keep on rolling
  9. Mar 3, 2022 at 2:21 PM
    #5449
    crashngiggles
    Jared
  10. Mar 4, 2022 at 5:43 AM
    #5450
    crashngiggles
    Jared
  11. Mar 4, 2022 at 5:44 AM
    #5451
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :cheers::rasta: Happy Frihigh Day!!
  12. Mar 5, 2022 at 7:30 PM
    #5452
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Sorry. Quick question. I have the 3rd gen 6112/5160 set up on my 2nd gen Tacoma. It’s fine but a little stiff for me. It’s on 600lbs springs.
    I have an option tommo to buy the trd Baja set up. Thinking about it. It was made for the 2nd gen. But….it does come with 650 springs from the factory. :/
    anyone have any input? Do they think the trd Baja 6112 will be smoother?
  13. Mar 6, 2022 at 8:04 AM
    #5453
    RedDeadTaco
    Andrew
    Aiken, SC
    What clip are you at on your 6112’s?
    71tattooguy likes this.
  14. Mar 6, 2022 at 10:46 AM
    #5454
    pahaf
    paul
    NorCal
    the highest clip.
    i was lower before and didnt really notice a diffrence.
  15. Mar 6, 2022 at 1:40 PM
    #5455
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    For anyone who assembled their own and bought new top hats:
    Did you buy OEM or KYB?
    Did the top hats come with the nut, washer and bushing to secure the top hat to the strut?
  16. Mar 6, 2022 at 2:48 PM
    #5456
    RedDeadTaco
    Andrew
    Aiken, SC
    3rd gen 6112’s have 6 clips. The 2nd gen version only have 5 clips. I wouldn’t recommend being on the 6th clip with a 2nd gen. If you went lower and didn’t notice a difference, I guess your going to have to try a different set up since the Trd Baja are basically 6112’s
    pahaf[QUOTED] likes this.
  17. Mar 6, 2022 at 4:12 PM
    #5457
    pahaf
    paul
    NorCal
    my only thinking was that the 3rd gen is heavier and they are valved differently compared to the 2nd gen.
    plus, the baja 6112 were even more "tuned" by Toyota. but seems like the deal fell thru on me getting the baja kit. the seller is being super slow to respond and doesn't want to text to set up a meet. only emails once every 2 days.
    ill just lower my springs to the 3rd clip. maybe get some better mpgs that way. and hopefully little softer.
    im on the 6th setting on both sides, plus a 1/4" spacer on drivers side. rear has the meduim OME leaf pack. sitting pretty level.
    og_BgMIFkBvSsSLh4wAxjGXzUbVQz6Rf26ajzAb7_967836615f671f3ff49c912076ceaf8dab0bb736.jpg
  18. Mar 6, 2022 at 4:46 PM
    #5458
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Looking good :thumbsup:
  19. Mar 6, 2022 at 5:03 PM
    #5459
    RedDeadTaco
    Andrew
    Aiken, SC
    You can try and find some 3rd gen pro fox shocks. I bet that’s a nice ride.
  20. Mar 7, 2022 at 6:58 AM
    #5460
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    KYB from Amazon for $22
