Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Apr 22, 2022 at 11:58 AM
    #5641
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    Im at 6/6 with a 10mm spacer and she rides great. scroll up for pics
  2. Apr 22, 2022 at 12:03 PM
    #5642
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
    I saw that and thanks for the info on your setup. Do you have a hub to fender measurement at 6 with the 10mm spacer? I'm thinking at 6/6 with the driver spacer I will only be at 22" with all the weight. I guess that will be OK. When I tow the rear with the RXT on option 2 comes down 1" from 24" to 23" and the front comes up 0.5" If that stays the same then towing I will with the new setup I will be at 23" rear 22.5" front so still a slight rake which I prefer.
  3. Apr 22, 2022 at 12:12 PM
    #5643
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    Im at 23 3/8" up front and 23 straight up in the rear. I dont have any weight light you do... yet. I am planning on tossing in a full leaf pack in the rear for a bit more lift and to compensate for the RTT and topper I have on order
  4. Apr 22, 2022 at 1:50 PM
    #5644
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    @memario1214 Are they in stock?
  5. Apr 22, 2022 at 2:50 PM
    #5645
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yes we have 2 16+ taco kits on hand right now.
    @CemenTRDgen ill get your numbers Monday. I had to leave for the day before I got to it. You can call on Monday as well at 406-936-0206 so there’s no way I forget!
    CemenTRDgen and OmahTako[QUOTED] like this.
  6. Apr 23, 2022 at 10:13 AM
    #5646
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    What made you go with the 650 pound spring? It doesn't look like you have much weight? What net lift did this setup give you?
    I am looking to do the same but with the 600# springs and an Icon RXT option 2 in the back. I have about 250 pounds on the back with a camper shell and some odds and ends and and 150 pound sliders and a Prinsu roof rack. So about 450 pounds generally 2/3rd distributed to back and 1/3 up front. I am torn on 600# or 650#. I read the 650 are for 100 to 150 pounds extra weight "on front bumper". I figure with my weight distribution, the front and back should sag just about equally.
  7. Apr 23, 2022 at 10:22 AM
    #5647
    BattleKat
    San Diego
    Great, just when I had settled in on clip 5/4 for 1.5" on the Offroad DCLB. Now do I go for 1.7" or 1.4"?
    I am leaning towards sticking with the 600# springs despite some extra weight but 2/3rd towards back. So if I stick with 600# at 1.7" and it sags a bit, I should get around the 1.5" I am looking for.
  8. Apr 23, 2022 at 2:03 PM
    #5648
    Jadamjr
    Jadamjr Well-Known Member
    Jonathon
    Phoenix,AZ
    2017 DCLB TRD OR
    Hey guys, so I was curious what you guys thought. I carry a tool box with about 300 pounds of tools daily in the bed of my truck. I purchased an Icon RXT leaf pack and plan to do the second setting. Now my issue is, does having the 6112’s in on 5/6 have any downsides or should I look at Fox 2.5 coilovers without reservoirs for about $400-$500 more? My goal is to get 2”-2.5” of lift in the front.
  9. Apr 23, 2022 at 2:08 PM
    #5649
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Wonder why so many settings that can’t be used on the low end on any model…
  10. Apr 23, 2022 at 2:19 PM
    #5650
    BattleKat
    San Diego
    My understanding is the max you will get with the 6112s is 2". Maybe if you go 650# spings instead of the 600# it will get you another 0.5". You might need new UCAs if you do that.
    71tattooguy likes this.
  11. Apr 23, 2022 at 9:38 PM
    #5651
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    I got 2 inches on the 6112’s on the 4/5 setting.
  12. Apr 24, 2022 at 11:53 AM
    #5652
    GONE FISHIN'
    GONE FISHIN' Well-Known Member
    northern front range CO
    21 ORAC
    So, what is the consensus on the accuracy of the 6112 circlip setting guidance from Bilstein install instructions (for 3rd gen trucks) ? some seem to come in considerably higher ... of course there could also be msmt accuracy issues..
  13. Apr 24, 2022 at 12:13 PM
    #5653
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    In my case I got more lift than advertised. I set mine to 5/5 with a 1/4" spacer on the driver's side for lean. I got 2 1/2" after allowing for settling. Around 5000mi since the lift. Hope this helps.
    GONE FISHIN'[QUOTED] likes this.
  14. Apr 24, 2022 at 1:20 PM
    #5654
    BattleKat
    San Diego
    What does "msmt" stand for?
    I think part of the challenge is there are other factors than just the circlip settings used"
    • Additional weight that people don't always report or report accurately
    • What model since there is a difference in what B publishes
    • Before and after measurement accuracy
    This is anecdotal based on all the damn threads I have read, but most people at stock weight appear to get a little more at first and after settling they get about what is published.
    The challenge I am having is trying to estimate based on added weight on my OR DCLB. While I have no added weight on the bumper (stock front bumper and no winch and don't plan to add one), but I do have rock sliders, a prinsu rack, an ARE shell, a bed mat, and some tools and recovery gear in the backseat storage. It is hard to gauge the final result.
    If you are 100% stock I would expect slightly more than published.
  15. Apr 24, 2022 at 1:49 PM
    #5655
    GONE FISHIN'
    21 ORAC
    thanks BK - good thoughts. and by msmt I meant measurement . same challenge, I'm an OR AC with sliders and a Leer 180 aiming for 1" up front and 1.5" rear (via progressive AAL) realtive to how it sits now. Probably add another 200 + lbs when loaded for extended camping. back n forth between 2/3 and 3/4.
  16. Apr 24, 2022 at 2:08 PM
    #5656
    BattleKat
    San Diego
    Got it. My challenge as well. Trying to get ~1.5" up front with a 1" rake with the weight I have added so it is level when I add in camping gear. My mind changes daily. The new version of the 6112s with the 11 ciclip positions certainly didn't help! If you don't pull the trigger soon you will likely end up with the new version with new settings.
    Assume current version, I am leaning towards the 5/4 setting but really torn on the 600# springs or going up to the 650#. Afraid with the weight I won't get the advertised 1.5". But worried if I go 650# I get too much!
    I'm not the handiest of people so I need to pay for labor and would like to do it just once, but am realizing I have to take a swing and accept that I may need to make adjustments.
  17. Apr 24, 2022 at 5:39 PM
    #5657
    Fedup13
    San Diego
    2021 OR DCSB 4x4
    Like I posted above I’m on old 6112’s on the 4/5 setting and got 2 inches on stock weight with 600 lb coils. It’s been well over couple thousand miles and hasn’t changed yet. I’m fairly new to all this and originally wanted only 1.5 up front but am actually happy with the 2. I’ve read others say they got more than 2 with the top settings so I’m sure this will add to the confusion.
  18. Apr 24, 2022 at 9:28 PM
    #5658
    dagsom
    dagsom Active Member
    San Diego
    So I ordered a pair from Wheeler's Off Road a week ago and told them to put the clip at the max setting #6/#5 because I wanted to get a decent lift without adding UCAs. I just installed them yesterday and I didn't gain that much height but I didn't realize until after I read about these new styles to realize they didn't put the clip as high as I wanted it. Looking at pics I took before the install definitely shows more grooves to go higher. Any ideas what I should do? IMG_5939.jpg IMG_5901.jpg IMG_5963.jpg
  19. Apr 24, 2022 at 9:31 PM
    #5659
    GONE FISHIN'
    21 ORAC
  20. Apr 24, 2022 at 10:01 PM
    #5660
    dagsom
    San Diego
