Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Jul 12, 2022 at 4:49 PM
    #5861
    tacopeter
    tacopeter My truck isn't modded. It's well optioned.
    Peter
    Washington State
    21 DCLB TRD OR
    OEM+
    I rub on the pinch welds on hard bumps. Pretty sure if they are pounded or cut and welded, I would be fine.
  2. Jul 12, 2022 at 5:03 PM
    #5862
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    SOON. I got your PM. We'll get them out tomorrow :cool:
  3. Jul 12, 2022 at 6:16 PM
    #5863
    Dirtyleg
    Dirtyleg "Don't wanna Taco bout it!"
    Aaron
    Chesapeake, VA
    2018 SR5 4x4; CAB-4 Full Doors, BED-Standard 6' 3.5"
    El Taco Blanco
    Hahah… No rush man! However this new rear end setup has me questioning whether or not to put my sway bar back in cause it’s so cush! Can’t imagine how it’ll be with the new front coilovers!
    71tattooguy likes this.
  4. Jul 12, 2022 at 8:06 PM
    #5864
    WA7
    WA7 Well-Known Member
    Craig
    PNW
    2021 Trail Edition
    I had to search all over but found them at Off Road Warehouse. Their Mesa, AZ store had a couple left. They all show out of stock now, though.
    Dirtyleg[QUOTED] likes this.
  5. Jul 14, 2022 at 11:47 AM
    #5865
    TacoTwoDay
    TacoTwoDay Well-Known Member
    David
    Western PA
    2021 Tacoma TRD OR
    which OME leafs are these? standard or heavy duty?
  6. Jul 14, 2022 at 1:40 PM
    #5866
    Dirtyleg
    Aaron
    Chesapeake, VA
    El Taco Blanco
    These are Heavy Duty with Medium(4th) leaf and 2nd overload removed.
    TacoTwoDay[QUOTED] likes this.
  7. Jul 15, 2022 at 7:29 AM
    #5867
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Aye @memario1214 when you get online can you shoot me a DM. I need some professional advice.
  8. Jul 15, 2022 at 7:47 AM
    #5868
    memario1214
    Colton
    Missoula, MT
    I live online. Incoming
    Superdave1.0 likes this.
  9. Jul 17, 2022 at 1:32 PM
    #5869
    Suspender
    Suspender Well-Known Member
    Colin
    IE, CA
    My time to ask a question, after reading at least 100 pages of this thread and still not sure exactly what I need.
    3rd gen 4x4 DCSB. Only permanent weight right now is sliders, but I add RTT+camping gear when we go on trips that's probably ~300-350lbs over the rear...
    - 6112 up front on 5/4 for 1.5" lift, 600# springs.
    - 5160 with Icon RXT Option 1 for 1.875" lift.
    Shouldn't "need" UCAs, but probably upgrade down the road for increased droop. Probably don't need new bumps either. Might as well do the ECGS bushing at the same time though.
    I don't want to increase my rake over 1.5", and if anything I'd prefer to be closer to level. I also don't want to slam off the bump stops with a couple hundred pounds in the bed, even if that means being a bit stiff empty.
    Am I on the right track? Missing anything?
  10. Jul 17, 2022 at 3:23 PM
    #5870
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Imo I would go option 2.
    BattleKat likes this.
  11. Jul 17, 2022 at 5:17 PM
    #5871
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    you are on the right track, but…
    you said sliders is only weight for now? What else you planning to do? I would add what you plan to do than do the upgrade last.
    RTT? Where do you mount it? You must have some rack that adds weight? Do you only put it in when going camping or is it going to be permanent?
    Bump stops. An upgrade like durabumps is relatively I expensive. Get them now.
    UCAs are debatable. I only did 1.5” as well but I read enough reviews where others did the same but called the ride squirrelly. The replaced UCAs and rode much better.
    I would also go with option 2. I do have 200#s permanent in the bed with a topper shell, but when I camp I camp light. I would say about 150-200 pounds added weight for 350-400 total. I am not level but aomewhat close. I think with option 1 you will sag.
    there isn’t any sure fire way to get this right on the first try. If you removed your camping gear from the equation I would say you were spot on. Add the camping gear and that is where option 1 vs 2 comes into play as well as upgrading the bump stops.
    for the record I had to do it twice in the front . I did 10/8 (new version) and didn’t get 1.7” as advertised in front. Had to upgrade to 650 springs to get it where I wanted.
    if you really only add 300+ pounds when camping, you can do option 1 but just be prepared for it to end up sagging a little. You just never know for sure until you do it.
    if in doubt research some more and think about other weight you might add.
  12. Jul 17, 2022 at 7:46 PM
    #5872
    Suspender
    Colin
    IE, CA
    I feel like the rake would be too intense, as that would be +2" in the rear +1.5" in the front, adding .5" to the existing factory rake. I guess the benefit is I can just go up to Option 2 if I bottom out a lot.
  13. Jul 17, 2022 at 7:50 PM
    #5873
    Suspender
    Colin
    IE, CA
    Thanks for the feedback. Realistically the only new weight would be a skid set. Would love bumpers + tire carrier and winch but probably not any time soon in reality. I figure if I end up getting those in a couple years, I can get 650# or 700# springs then and enjoy a couple years of better fit with 600#
    RTT is mounted level with the cab on custom bed bars that only weigh ~40# total, and none of that weight stays on permanently. Just for camping season.
    How did you even get the "new version" of the 6112s? Every dealer I see apparently only has the old ones because you don't even get an option over perch 6.
  14. Jul 17, 2022 at 7:51 PM
    #5874
    71tattooguy
    Dino
    Petaluma , Ca (707)
    There is no difference in ride they just accommodated more settings to dial in ride height a little more.
    jackn7, memario1214 and Suspender like this.
  15. Jul 17, 2022 at 10:43 PM
    #5875
    BattleKat
    San Diego
    I’m Batman! I wanted the extra settings because I was afraid of the end result so I found a dealer that had them in stock.
  16. Jul 18, 2022 at 7:21 AM
    #5876
    BattleKat
    San Diego
    Go for it. I don’t know that anyone is 100% certain they are going to be happy with the end result in the first try. As long as you are open minded to know you may need to redo it, you are good.
    Suspender[QUOTED] likes this.
  17. Jul 18, 2022 at 10:29 AM
    #5877
    memario1214
    Colton
    Missoula, MT
    We've got the 11-position ones here in stock at Hotshot Offroad which is where @BattleKat snagged his from :cheers:
    I'm not sure what Bilstein is doing with the 2 different SKUs, but they use the exact same spring, and we got a hold of Bilstein's valving spec sheets and the shock is spec'd the same except for one having 11 notches and another having 6. I'm assuming they'll phase out the 6-notch variation as they run out of 6-notch bodies, but not completely sure :notsure:
    Here's the fitment sheet for the new ones - This leads me to believe that down the road they won't even have a 2nd and 3rd gen specific 6112 kit.:
  18. Jul 18, 2022 at 12:32 PM
    #5878
    Suspender
    Colin
    IE, CA
    Awesome, thank you! It sounds like the 10/8 perch would be perfect to retain the factory rake with Icon RXT Option 1 and no extra weight in the bed...
    Any negative reports about ride quality or lack of downtravel being at 10/8?
    I am just waiting on my bonus check to get it all ordered and it looks like I found my supplier!
    grayfrog and memario1214[QUOTED] like this.
  19. Jul 18, 2022 at 12:37 PM
    #5879
    memario1214
    Colton
    Missoula, MT
    We honestly haven't had anyone circle back and indicate that they were experiencing issues with that at all.
  20. Jul 18, 2022 at 1:06 PM
    #5880
    Maxx
    Maxx Well-Known Member
    Can you share the valving specs for the 6112’s? I’ve been curious since I got mine and have never been able to find the data.
