Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Aug 12, 2022 at 8:36 AM
    #6041
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    you will be hard pressed to get a (non shop style) spring compressor in between the coils and coils, and coils and shock body.
    They can be pretty easily assembled by loosening the LCA bolts to allow the arm to swing freely. a jack can then be put under the uca to compress the assembly and get the top hat nut on. In my experience the amount of jacking will just start to lift the corner of the vehicle if you are on the higher clips. If the nut doesnt go all the way down just remember to check it once the truck is back on the ground.
  2. Aug 12, 2022 at 8:38 AM
    #6042
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    Thanks
    somebody[QUOTED] likes this.
  3. Aug 12, 2022 at 8:38 AM
    #6043
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    It's a game that I personally don't like to play (but I also have a compressor at my disposal), but this is probably the method you're referring to.
    https://youtu.be/jr0v63Q7CQs
  4. Aug 12, 2022 at 8:44 AM
    #6044
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I installed my 600 lb springs using the truck as a spring compressor. It worked OK - it was safe, but one side was a little funky.
    I don't know that you can compress 650 springs, and I seriously doubt you install 700 lb springs this way.
  5. Aug 12, 2022 at 8:49 AM
    #6045
    GeoTaco
    Freeda Feltcher
    Denverish
    Car seats
    Thanks for the quick responses. That is what I recall and I will be getting 600 lb springs.
  6. Aug 12, 2022 at 9:44 AM
    #6046
    ksimms92
    ksimms92 Well-Known Member
    Kevin
    West of Chicago
    2020 Silver TRD OR DCLB 4X4
    I can confirm you can use this method with 650# springs, because I ended up adjusting my preload from the 8/6 that I had the clips pre-assembled with.
    Not sure about 700# springs, but I would think so. The 650# easily compressed enough to get the nut on without the truck leaving jack stand.
  7. Aug 12, 2022 at 9:51 AM
    #6047
    Suspender
    Suspender Well-Known Member
    Colin
    IE, CA
    I'm getting ready to install (6112s on the way from @memario1214 !).
    I'm expecting 1.7" lift up front, and just wondering about the needle bearing and UCAs. My plan is to leave the Toyota needle bearing and stock UCA for now, I mostly just drive freeway and forest roads on weekends and it's under 2" lift. I should be able to get away with it for a while, right?
    The plan is to replace the LCA bushings, go for ECGS, and put in new UCAs in 6-12 months when the truck will be around 25k miles, so time to look at new LCA bushings anyway. Just saves some work and money today.
    Obviously if I get vibrations that go away in 4HI, I'll have to go back in earlier for the ECGS bushing.
    Am I on the right track?
  8. Aug 12, 2022 at 9:57 AM
    #6048
    Scott B.
    Scott
    Georgia
    Interesting.
    On one side, with 600# springs, the truck lifted off the jackstand.
  9. Aug 12, 2022 at 10:02 AM
    #6049
    memario1214
    Colton
    Missoula, MT
    You're on the right track. You'll likely be back sooner than later for the ECGS bushing as pretty much all 3rd gens get a little bit of vibe with a lift, but you should be A-OK with stock UCAs moving forward. I'd love to sell you all kinds of things, but if you can get into proper alignment with the stock UCAs now there's no rush with changing them... maybe ever.
  10. Aug 12, 2022 at 10:10 AM
    #6050
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    You've really got to appreciate this kind of honesty.
    Suspender likes this.
  11. Aug 12, 2022 at 11:44 AM
    #6051
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    Question for those who have a SSO Slimline/Versa winch bumper type of front bumper. Will I do better to upgrade the springs to 650# or 700#?
    Initially will be just the bumper at around 70# additional weight and after winch and light bar closer to 110#- 120#.
    I want 2” lift after install and settling.
  12. Aug 12, 2022 at 12:08 PM
    #6052
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    Honestly, Id just do the bushing. You'll likely have some vibrations and if the needle bearing fails, sending needles into your diff, you will be kicking yourself and spending a ton more money on gears. It'll also save you a whole bunch of time and it's a lot easier to take the front end of the truck apart once.
    Swapping that bearing to a bushing is basically maintenance that has to get done sooner or later.
  13. Aug 12, 2022 at 1:49 PM
    #6053
    Suspender
    Colin
    IE, CA
    I was afraid of this. I do plan to upgrade the UCA and replace LCA bushings in a few months, so was just hoping to do the ECGS bushing then too. Thanks for the input. Definitely don't want to jack up the gears or the CV rod or anything if I can avoid it.
  14. Aug 12, 2022 at 1:54 PM
    #6054
    Suspender
    Colin
    IE, CA
    Thanks for the input. Just received the last of my order today, I'll definitely be back when it's time for more parts... Thanks for the great service and quick shipments!
    memario1214[QUOTED] likes this.
  15. Aug 13, 2022 at 7:00 AM
    #6055
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    I had the same thing. I installed both 600lbs and 650lbs springs using the jack method but both times, the truck was coming off the jack stands. Little sketchy. Lifted the truck about an inch and a half.
    maybe because me have 2nd gens…which are a little lighter then 3rd gen. Idk. Just an idea
  16. Aug 13, 2022 at 11:26 AM
    #6056
    Maxx
    Maxx Well-Known Member
    Yeah, the truck comes off the jack stands when you’re compressing the springs but it’s not going anywhere. Just have to make sure you have a good perch on the LCA. Extra jack is nice to have in case the truck moves around a bit. Just go slow.
  17. Aug 13, 2022 at 12:08 PM
    #6057
    ksimms92
    Kevin
    West of Chicago
    I really don’t remember mine lifting off the jack stands. This was also the first time doing this sort of thing so I was extremely careful and observant. I guess it depends on how heavy the truck is.
  18. Aug 13, 2022 at 12:56 PM
    #6058
    Maxx
    Yea, depends on truck and spring weight. Heavier spring and lighter truck, it will come off the jack stands and it’s also an indicator that you might be using too much spring for your weight.
  19. Aug 14, 2022 at 7:25 PM
    #6059
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Can somebody explain why they say the ride is better when they also say it is stiffer? I understand the handling and control improves but I would think that the stiffer ride would rattle your brain? I understand the digressive system bilstein has as well I'm just trying to imagine what the truck would feel like vs the current OR setup I have.
    Thanks
  20. Aug 14, 2022 at 7:44 PM
    #6060
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The why's and how's of suspension feel hurt my brain. :cookiemonster:
    Keep in mind that you have a multidimensional spectrum - on one axis you have small bumps that don't flex the springs at all vs big bumps that max the travel limit, and on another axis you have rate of articulation, slow crawling vs a full send impact
    The Bilsteins and their digressive setup means that they are incredibly stiff on both the small bumps and the low speed articulation. So on the plus side, brake dive and steering roll are virtually eliminated. On the minus side, small potholes and 5 mph speed bumps suck.
    Where the digressive shock shines are on the big whoops and high speed impacts. The Bilsteins soak those up like butter.
    Does an expensive linear shock outperform a digressive? Absolutely. But I personally found the Bilsteins to be a reasonably good compromise for a truck that mostly lives on road and occasionally sees trail. It's stiff in that it doesn't roll and wobble down the highway like a worn out Jeep, but rather feels rather sporty. Try to punish it on a pockmarked trail however, and it magically loosens up while still keeping you planted to the ground.
    It's not perfect, as mentioned earlier the small chatter like highway seams and road imperfections are ignored by the billies, leaving that work entirely up to your tires to absorb. But that's a minor issue that I'm willing to forgive, because it feels great everywhere else.
    Hope that makes sense.
    jackn7 likes this.
