Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Oct 24, 2022 at 6:12 AM
    #6201
    Hutch98
    Hutch98 Well-Known Member
    Nashville TN
    22 TRD OR AG
    Had a 98 Taco SAS'd with D-60's and 42 SX-II's
    Where are you in TN? I'm in Nashville debating on running the 6112/5160 set up
  2. Oct 24, 2022 at 3:38 PM
    #6202
    AnonymousHairyTacoma
    AnonymousHairyTacoma Member
    Brady
    2022 TRD OR
    Alright guys I have done a ton of research on the forum since getting my new 2022 TRD OR DCSB, and have been on the fence about a suspension upgrade but I am sold on the Bilstein upgrade. Below are my plans for the truck in the next 12 months as funds allow, and just want to make sure I am thinking this all through correctly. This truck is a daily driver that is also used for hunting frequently on rocky 2 track trails, so looking for a good compromise between on and off-road.
    I plan on adding a caliraised stealth bumper with light bar in the front, no winch. I also intend to add a Leer 100XR shell in the rear. Currently running Method 312 17 x 8.5 0 offset wheels on 265/70R17 K02 tires, as well as TRD front skid plate.
    I want to run the 6112 at 10/8 notch to give about 1.5"-1.75" of lift after front armor is installed, with 5160 rear shocks and Icon RXT leaf pack on option 2 to maintain 0.5"-1" of rake. I will more than likely also opt for ECGS swap while truck is apart to be safe.
    Is there anything that I am missing or need to be aware of?
    71tattooguy likes this.
  3. Oct 24, 2022 at 3:50 PM
    #6203
    Ffej
    Ffej Well-Known Member
    Evergreen, Colorado
    '22 TRD OR DCSB
    Bed mat
    you nailed it. The only other thing to consider is extended brake lines, mine are stretched with 5160s and stage 3 icons. You’ll love that set up!
  4. Oct 24, 2022 at 4:25 PM
    #6204
    Brady
    2022 TRD OR
    Are you running 600# or 650# spring in the front?
  5. Oct 24, 2022 at 5:43 PM
    #6205
    Ffej
    Evergreen, Colorado
    '22 TRD OR DCSB
    Bed mat
    600lb spring
  6. Oct 24, 2022 at 6:24 PM
    #6206
    Brady
    2022 TRD OR
    Will UCA be necessary with this setup?
  7. Oct 24, 2022 at 6:39 PM
    #6207
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    More positive caster will decrease bump steer. Aftermarket upper control arms with added caster should help. I have had the light racing style and JBA-i prefer JBA. You also need an alignment tech that is willing to go outside of Toyota's specs. You should be able to get around 4* caster, stock calls for about 2.5*.
    CemenTRDgen likes this.
  8. Oct 25, 2022 at 7:38 AM
    #6208
    SilverBullet21
    SilverBullet21 Member
    21 Silver SR DLCB 4x4
    3" lift, Fuel Blitz 16x8, 285/75r16 Nitto RidgeGrapplers, Cali Raised Ditch and Fog Lights, Empyre Offroad Grille, Rough Country Bed Molle Panels, Cheap Bedcover, Carven Cat-Back, Mishimoto Intake Tube
    Im about 40 minutes west of Knoxville in Kingston, i have no regrets so far, but obv if i move to a 35 ill probably have Remote Reservoir Kings all around
  9. Oct 25, 2022 at 7:45 AM
    #6209
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    We only recommend a new UCA at anything north of 2" of front lift. Even up to 2" is generally OK though. A new UCA can give you more opportunity to dial in alignment to your desired specs or sharpshoot where in the wheel well that your tire sits, but an OEM UCA can usually get you back to good numbers at <2".
  10. Oct 30, 2022 at 7:00 PM
    #6210
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I see that with the 650lb coil you can expect to have an added .5" of lift vs the 600lb. What is everyones thoughts on using the 650lb coil in order to obtain the same amount of lift but being able to set the clips at 9/7 instead of 10/8 with the 600lb coil. Would the stiffer coil offset the benefits of less preload and basically come out the same as ride quality?
  11. Oct 30, 2022 at 8:10 PM
    #6211
    BlackNBronze
    BlackNBronze Member
    Dylan
    2010 Tacoma TRD Off-Road
    Bilstein Lift, Bronze Artillery Wheels, Baja Designs Lighting,
    Just added 700# springs to my 6112's after adding something like 225 pounds of weight to the front. Gained more lift than I had originally with lighter springs and less weight, and the ride is once again excellent. No more bottoming out on the 34's either.. Settled an inch after, thank god, had just under 41 inches to the fender after install.
    I would not personally recommend using spring rate to change ride height over moving perch height. The difference in (detrimental) shock feel was minimal to gain lift with extra preload (moving perch up) but swapping springs made a monumental difference that I couldn't recommend without the added weight.
    jackn7, AJKlug1 and 71tattooguy like this.
  12. Oct 31, 2022 at 10:48 AM
    #6212
    memario1214
    Colton
    Missoula, MT
    Just a reminder that this is the last day for our 6112 assembly discount! :pumpkin:
    Further reminder that any Tacoma shocks ordered during this sale are getting the new 11-notch shocks. The pricing for these shocks goes from $770 to $826 effective tomorrow 11/1! Please reach out to us if you have any questions 406-936-0206.
    Tacoma Kits are HERE - The discount will automatically apply at checkout!
  13. Nov 1, 2022 at 7:22 AM
    #6213
    Stigman
    Stigman Well-Known Member
    2020 Cement TRD OffRoad
    Besides more clip options, are there any changes or benefits to the new 6112 model?
  14. Nov 1, 2022 at 8:40 AM
    #6214
    BugJuice
    BugJuice Well-Known Member
    Just the sticker on the shock body I believe.
    https://youtu.be/3lra8YCrvSM
  15. Nov 1, 2022 at 8:15 PM
    #6215
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    How does it ride on the highest clip? I want to retain a 2 inch lift. Would it ride better moving it to a lower clip and adding a top mount spacer?
    Dontkillzenkis likes this.
  16. Nov 3, 2022 at 11:16 AM
    #6216
    burzpaw
    burzpaw Well-Known Member
    Zuriel
    '22 Lunar Rock TRD Off Road 4x4
    Heard mixed reviews on riding on the highest clip. Can't say how it feels on the highest clip but I can say that I'm running #4/#5 on the 6 notch shocks with a 1/4" spacer on both sides and have exactly 2" lift-- ride quality is great for me.
  17. Nov 8, 2022 at 2:19 PM
    #6217
    Tacofromthe6ix
    Tacofromthe6ix Well-Known Member
    Sal
    GTA
    2016 Toyota Tacoma TRD Sport
    Bilstein 6112/5160 with Icon AAL on 285/70/17 Falken Wildpeaks
    I’ve been on the 6/6 with 1/4 lean spacer for over 55,000km (34,000 miles) on my 2016 double cab long bed. Originally had about 2.5 inch lift and now sitting at 2 inches after it settled. Ride has always been great to me since installing, way better than stock sport suspension. I would say it took about 10,000km (6200 miles) for the springs to settle in abit.
    overall if I were doing it again I would install the 650lb springs from the start and I would coat shock body’s with 2k clear coat since I live in salty winter conditions which the zinc coating doesnt like it.
    TacoEspecial likes this.
  18. Nov 9, 2022 at 4:47 AM
    #6218
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Does this actually work? I have some 6112s sitting in a box waiting to get installed and the springs aren't on them yet. can they be coated with clear to help save them from the road cancer effects?
  19. Nov 9, 2022 at 4:35 PM
    #6219
    BeRoyalKC
    BeRoyalKC Active Member
    I just ordered the 6112/5160 kit from suspension lifts.com. I chose the 10/8 clips which is supposed to get 1.7" of lift. They showed up today and were the old versions set on the 5/4 clips which is only shown at 1.5". My plan was to keep some rake, so I figured lifting the front the 1.7" and the rear 1.5" with an AAL would do the trick.
    I'm annoyed but is it worth making them swap it out? Do these things give more than advertised lift and not settle a whole lot?
  20. Nov 10, 2022 at 1:36 PM
    #6220
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    all depends on the person. is .2" going to make a difference for you? i personally wouldn't care.
    every truck is diffrent, but as i understand, you will get a little more lift, and then it will settle.
    BeRoyalKC[QUOTED] likes this.
