Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Nov 24, 2022 at 7:45 PM
    #6241
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I'm on 9/7, but that's without the over load, icon three leaf add a leaf and 265/70/17 tires. Sits level.
  2. Nov 25, 2022 at 8:52 PM
    #6242
    guest_707
    guest_707 Well-Known Member
    This may sound like a dumb question but it is Friday so...here goes! If I were to lift the front 2" and add a 1.5" AAL for the rear, would that just level the truck or would there still be a bit of rake/higher in the back?
    TacoEspecial likes this.
  3. Nov 25, 2022 at 9:15 PM
    #6243
    Bishop84
    Bishop84 Well-Known Member
    Easiest way to find out is to measure your fenders to the ground and see where you're at now.
    Rear springs are all different and react differently to AAL's depending on age.
    2 and 1.5 would retain a factory rake. But its hard to say how your springs are to start with.
  4. Nov 25, 2022 at 9:23 PM
    #6244
    guest_707
    Thanks. I was gonna go ahead with the 6112/5160 for a 2" front and the icon 1.5" AAL for Black Friday and then I suddenly realize, "would a 1.5 AAL even work with a 2" front? What if there's something I completely missed?" I tend to overthink things, anyways lol.
  5. Nov 25, 2022 at 9:28 PM
    #6245
    Bishop84
    I think its perfect, good setup and if you can get it on sale go nuts.
    I hate level trucks, 1" rake is perfection lol.
    guest_707[QUOTED] likes this.
  6. Nov 26, 2022 at 12:55 PM
    #6246
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    Think that would be a great setup :thumbsup:
  7. Nov 26, 2022 at 1:59 PM
    #6247
    sigrude
    sigrude Well-Known Member
    Northern CA
    2018 Cement TRD Off Road DCLB 4X4 AT
    So the 6112s need to be set at 11/9 in order to get the 2” lift? Will 285/70/17 fit?
  8. Nov 26, 2022 at 2:17 PM
    #6248
    BeRoyalKC
    BeRoyalKC Active Member
    I would try and confirm with them which version of the 6112 you'll get. I just installed this setup, but I had ordered the 6112s on the 10/8 setting for the 1.7" of lift, which is the updated version of the shock. Wanted to keep a little rake, but not all of it. I received the old version on the 5/4 clip setting that gives about 1.5" of lift.
    They were a huge PIA to get the 6112s swapped out for the correct/new version so I just installed what they sent me. Still looks good, but I could've used a bit more lift up front. They did at least update their description to note that they'll send whichever version of the 6112 they have in stock, though.
  9. Nov 26, 2022 at 2:55 PM
    #6249
    TRDORKY
    TRDORKY Well-Known Member
    2022 TRD OR MT MGM
    I had already read your post about this issue and that gave me even more cause for concern lol. I rolled the dice and pulled the trigger earlier today on a 10/8 setup. We shall see what arrives. I couldn’t pass up the current pricing for Black Friday. Thanks for the response regardless. Now to decide on tires….
    BeRoyalKC[QUOTED] likes this.
  10. Nov 26, 2022 at 3:35 PM
    #6250
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    I would suggest that you read around on this forum more.
    285 70 17 most likely will still rub. It depends on your offset of the rims.
    most likely will need a fender liner trim, or heat them up and melt them out of the way.
  11. Nov 26, 2022 at 3:35 PM
    #6251
    pahaf
    paul
    NorCal
    Going to try this. Thank you.
  12. Nov 28, 2022 at 1:54 PM
    #6252
    Chicago77
    Chicago77 Well-Known Member
    So today I was told that the new 6112 (10 clips) are not compatible with gen2 regular cab tacomas, and could only be run if there was alot of weight in front. Seems odd to me. Is anyone running them?
    I have a 4cyl with a regular cab so it will be lighter than the numebrs bilstein puts out for their clips. Advice on how to get to 1.75-18 front lift. My thought is these trucks are a good bit lighter.
  13. Nov 28, 2022 at 2:51 PM
    #6253
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
    From https://www.autoblog.com/buy/2008-Toyota-Tacoma/
    Base 4x2 4cyl Regular Cab 3,140 Lbs.
    PreRunner 4x2 4cyl Regular Cab 3,315 Lbs.
    Base 4x4 4cyl Regular Cab 3,315 Lbs.
    PreRunner 4x2 4cyl Access Cab 3,635 Lbs.
    Base V6 4x4 Access Cab 3,950 Lbs.
    Base V6 4x4 Double-Cab 4,035 Lbs.
    Weight difference from PreRunner 4x2 4cyl Access Cab to Base V6 4x4 Double-Cab is 400 Lbs. and at clip #8/#6 that is 1" difference in lift
    Weight difference from 4cyl Regular Cab to PreRunner 4x2 4cyl Access Cab is between 320 Lbs. and 495 Lbs. so I would expect about an additional 1" of lift on the same clip settings so #5/#3 will lift about 2" instead of 1.1"
    I say fuck around and find out. Also might be possible to use 550 Lb. springs instead of the 600 Lb.
    71tattooguy likes this.
  14. Nov 28, 2022 at 3:22 PM
    #6254
    pahaf
    paul
    NorCal
    Who sells 550lbs springs? Is it from bilstein? I would love to try them.
  15. Nov 28, 2022 at 3:45 PM
    #6255
    Chicago77
    Genious way to think about it I should have thought of. I am thinking based on weight difference between the two in the 05 chart is ~250lbs and .3 inch change that would come to .1 inch per 100lbs with a constant spring rate.
    SO, .81" gain compared to 4x4 V6 and .52" over prerunner. ~4/6 for 1.7 gain.
    Id still love to know if anyone is running this and if the spring is too heavy. My other options are 5100 which are certainly cheaper, but I would like some better ride quality.
  16. Nov 28, 2022 at 10:56 PM
    #6256
    agent4573
    agent4573 Well-Known Member
    2015 Xtra cab, TRD O/R
    None yet
    From the pics I've seen online, it looks like the 6112 uses a spring with ground flat ends, which is very much different than the unground stock springs. If that's the case, you can get a pair of king or fox springs for a 2.5" shock in almost any length or spring rate. Just verify that the springs ends are the same and you should be good to go. If you don't like king, eibach has an entire catalog of springs to choose from as well.
    http://www.kingshocks.com/products/springs/coil-springs-3-0/
  17. Nov 30, 2022 at 3:49 PM
    #6257
    tacotrdyota
    tacotrdyota Well-Known Member
    Kevin
    Lloydminster Alberta
    2018 Tacoma trd sport
    Does anyone on here have something they have rigged up to protect the rod on the rears from stone pitting? Like boots or deflectors?
  18. Dec 2, 2022 at 7:11 PM
    #6258
    guest_707
    I'm gonna get my 6112/5160s installed at a local truck shop. If I were to replace the needle bearings with the ecgs one, do I need to order the install and removal tool with the part or should the truck shop have tools for these?
  19. Dec 2, 2022 at 7:14 PM
    #6259
    MGMDesertTaco
    Unless it's a place that works on a lot of Toyota's I doubt it, but don't quote me on that. There's a thread somewhere where members are loaning out these tools. You just have to mail them back. It probably wouldn't hurt to just go ahead and order what you need.
  20. Dec 2, 2022 at 7:29 PM
    #6260
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Do you or anyone know the toyota part number for these? wouldnt mind having a pair on hand.
