Bilstein 6112
Discussion in 'Suspension' started by KnoxTac0713, Mar 15, 2016.
  1. Mar 14, 2023 at 7:24 AM
    #6381
    tacotrdyota
    tacotrdyota Well-Known Member
    Kevin
    Lloydminster Alberta
    2018 Tacoma trd sport
    Top setting with .25” shim on drivers.
    So after about 1000km these are no what I expected. Coming from a 2017 tundra with 6112 top setting with .5” shim on both sides I thought I was riding on clouds. On the tacoma they just feel like big beefy hitachis. They soak up the bumps a bit better but then get ready for the aggressive down travel. I feel like bilstein could have figured out a better designed shock length for these on top setting to stop with top outs. When I get a chance I’m gonna drop to a 4/3 clip set and chuck a 1” spacer on each side. As for the rear with the 5160 and icon 3 leaf kit, it’s a little stiff but that’s expected and when I’m loaded up with rtt and gear i know it will be 100% better.
    This is just my review and opinion. I have nothing against bilstein and ain’t trying to start anything.
    pahaf and Tacolife5 like this.
  2. Mar 15, 2023 at 8:45 AM
    #6382
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    100% agree. Most kits do not allow for enough down travel. I have the ready lift 6112s where their top hat equates to about a 0.5"-5/8" spacer. I've reduced the clip setting to just under 2" lift and rides like a dream. From my measurements I have just over 3" down travel. As this is more full droop than stock you may want to measure if you could get that extra inch down with a 1" spacer, you might get in to binding ball joints or stressing the uca/lca bushings.
    This set up with one 111 leafs and swaybar delete allows the front and rear to flex out completely and evenly. With the sway bar it was restricting flex by a couple inches total. Lowering the preload with the spacer will also help flex as the compressed spring force will be lower.
    tacotrdyota[QUOTED] likes this.
  3. Mar 16, 2023 at 5:38 AM
    #6383
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    Anyone running 6112s on a 2012-2015(double 4x4 v6)? I currently have 5100s set at 1.75" sits level no issues, They have 75K miles on them so I am looking to replace them soon. Should i go with the #9/#7 clip settings for 1.8" of lift? Or should I go next higher and allow for settling (it shows 2.2" which seems too high)? I assume I still will not need new UCAs going over to the 6112 and staying under 2"?
  4. Mar 16, 2023 at 7:16 AM
    #6384
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Any of you doing mostly daily with a mild lift on the 6112’s? (Aka not high enough to have to replace the UCA’s)
    Looking to keep my truck under 2” lift with factory-ish rake. I dont tow anything but I do camp w 4 adults and a loaded bed w camping gear.
    Been going back and forth between Bilstein and Dobinson. (Truck is currently bone stock) Budget is approx $1700 with AAL or replacement pack if needed. Just trying to get the best bang for my buck, and last at least 10yrs plus.
  5. Mar 16, 2023 at 7:48 AM
    #6385
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Daily , weekend warrior etc. great set up IMO. Replace leaf pack if possible. UCA’s I would do them but that me.
    Oskie_78 and VTi EG6[QUOTED] like this.
  6. Mar 16, 2023 at 7:52 AM
    #6386
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    @Backdoc recently got this lift on his truck and it’s his daily. Colton, @memario1214 can help out too.
    Backdoc and VTi EG6[QUOTED] like this.
  7. Mar 16, 2023 at 8:02 AM
    #6387
    Backdoc
    Backdoc Well-Known Member
    Harford County, MD
    2021 SR5 DCLB
    Bilstein 6112/Eaton Truetrac/RCI sliders Some other stuff
    Colton is the man. I told him what I was looking for. Slight lift with a near level look. 10/8 setting on the 6112's and a 1" block in the back with 5160's. Rides like a dream and its my daily driver. You will be in your budget with that setup. No sleeve, no control arm issues, no rubbing, no vibrations or weird noises. I couldn't be happier with it. Took me a friend about 3.5 hours to install and I am far from a mechanic.
  8. Mar 16, 2023 at 10:41 AM
    #6388
    Steadfast Rocky
    Steadfast Rocky Well-Known Member
    Rocky
    2012 DCSB TRD BAJA
    The problem is, tundras have like 11inchs of travel stock, and tacoma's have 8ish stock. The Tundra can't be lifted beyond a certain point just like the tacoma, the difference is the tundra as less of its travel available to ride height largely due to the CV angles, and the steering racks.
    So with a spacer, and being at the top perch, you get, really aggressive dampening, no down travel left in the suspension, a ton of preload, and a other suspension components that are not intended to work well in that range of the travel arc.
    If you want it to ride well, drop the truck to the middle range and loose the shims, or get an actual lift kit to bring the factory geometry back.
  9. Mar 16, 2023 at 10:45 AM
    #6389
    Steadfast Rocky
    Rocky
    2012 DCSB TRD BAJA
    I am running 6112s and 5160s on my Baja set at the Baja height. I daily the truck and do a good bit of dirt blasting into areas that require the locker and low range. I like the ride. I will say I agree about new leaf packs. And would also say, mileage and use will be more of factors then years for durability.
    VTi EG6[QUOTED] likes this.
  10. Mar 16, 2023 at 11:14 AM
    #6390
    VTi EG6
    TX
    2017 Taco TRD Sport
    Going to have to dig around and see what would be the best setting. Usually summers and road trips is where Id pack my gear. Spent a few years trying to make sure all my stuff was packable, considering the small bed and I wanted to be a minimalist. (Only other gear Id carry is 2-3 bikes, coolers, work gear) nothing too extreme or heavy duty. No 4x4 just a peasant RWD w LSD.
  11. Mar 16, 2023 at 11:31 AM
    #6391
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    did you do the ecgs bushing that everyone replaces?
  12. Mar 16, 2023 at 11:42 AM
    #6392
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Yes, I did.
    Inexpensive, and not hard to install. Well worth the peace of mind.
  13. Mar 16, 2023 at 2:51 PM
    #6393
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Just want to say... my 6112/5100 setup is still going strong after 45K miles. Best $$ I ever put into the truck.
  14. Mar 16, 2023 at 7:29 PM
    #6394
    Steadfast Rocky
    Rocky
    2012 DCSB TRD BAJA
    I would still recommend at least an add a leaf. My truck struggled doing a weeks worth of gear, food, the wife, and our other equipment, on the stock springs with just a covered bed full of stuff. All of our camping gear was UL stuff for backpacking.
    gilligoon and VTi EG6[QUOTED] like this.
  15. Mar 16, 2023 at 7:53 PM
    #6395
    VTi EG6
    TX
    2017 Taco TRD Sport
    Im going to search around and see who offers the best deal, if I have to wait a little longer. I may as well just replace the leaf pack while Im at it. I dont mind waiting. Hell the truck has been stock since date of purchase in 2017 lol.
    98_3RZ_NIC likes this.
  16. Mar 16, 2023 at 7:59 PM
    #6396
    Steadfast Rocky
    Rocky
    2012 DCSB TRD BAJA
    My stock baja suspension (basically at 6112), went a 140k, and there were a lot of smiles made that way.
    VTi EG6[QUOTED] and 71tattooguy like this.
  17. Mar 16, 2023 at 7:59 PM
    #6397
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Icon rxt leaf pack is a great option
  18. Mar 16, 2023 at 8:12 PM
    #6398
    Oskie_78
    Oskie_78 Well-Known Member
    Texas
    1998 4Runner, 2016 4Runner, 2023 Tacoma
    Yeah icon RXT is 600 bucks shipped on Amazon
    VTi EG6 likes this.
  19. Mar 17, 2023 at 3:45 AM
    #6399
    VTi EG6
    TX
    2017 Taco TRD Sport
    Is that option 1 or 2 on their chart?
    3 would be out of the question since I donny plan on getting a topper.
    Also apologies for all the questions. Are these the most reliable cost effective leaf replacement pack people are running? As opposed to OME/Dakar, Deavers etc…
  20. Mar 17, 2023 at 4:13 AM
    #6400
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    There is a great thread over here on the RXTs if you are looking for more info. I have a 2nd gen DCLB with a toolbox in the bed, high lift, and full size spare on option 2 and I love the RXTs. Im moving up from 5100/887 to 6112/650 as soon as it warms up. my 5100s are getting soft with all the weight I have added since lifting.
    https://www.tacomaworld.com/threads/icon-rxt-leaf-pack.505580/
    71tattooguy and VTi EG6[QUOTED] like this.
